Question about Brother Multi-Function Center MFC-8870DW All-In-One Laser Printer
MFC 8870 DW I tried to scan a document in order to fax, it would not then the red light came on and the message was------ Document Jam -- Clear the Scanner jam then press the stop sign.
  • 5 more comments
  • saxena275 Oct 01, 2010
    Hi Tim,
    There is no paper jammed, I have tried shutting it on & off, still the same message & the red light on.
    Let me unplug it & I will get back to you.
    Thanks
    Raj
    We have tried Unplugging
    Yes the Black Lever is in Place.
    Thanks Elix0411
    Raj
    OK, thanks
    Hi Tim,
    Someone is also trying to help.
    To reply to your comment again, yes we have tried what you suggested - unplug then plug - still the same message.
    Thanks
    Raj
  • saxena275 Oct 02, 2010
    No Unusual sound
    It was not that helpful to solve the problem. A repair were suggested, which I knew before I asked the question on fixya. Thanks anyway
    President:
  • 2,777 Answers
Ok, so did the document actually jam in the scanner feeder? Did you remove the jam? If it did not jam just turn off the copier / printer and try turning it back on. Does it still say jam? If so then turn it off again, unplug it this time and leave it unplugged for at least 2 minutes. Replug it in, then turn it back on. Of course only do these steps if you are CERTAIN there is nothing jammed in the scanner feeder.
Thanks
Tim
Posted on Sep 30, 2010
  • Tim Grayson
    Tim Grayson Oct 01, 2010
    Was that in response to me or someone else, can't tell if someone else is on here now...
    Thanks
    Tim
  • Tim Grayson
    Strange, I didn't realize two people could help at once, must be something new they are doing. It sounds like the sensor for the scanner area has failed to me personally. If it's detecting a jam where there definitely is no jam, it must mean the sensor itself is having issues. It may need some repairs to get it to scan again :(.
    Tim
  • 3,530 Answers
Check if something is stuck. Lift the top cover where the sheets of paper go through when you fax. On the right of the black rectangular piece with grey roller there is a slot in the tray with a black lever inside. Check if the black lever is in place.
Also, you can use a can of compressed air and give the machine a good spray.
Posted on Oct 01, 2010
  • 4 more comments
  • Jose Cada
    Jose Cada Oct 01, 2010
  • Jose Cada
    Ok let me see what else we can do. Let me get back to you in a few.
  • Jose Cada
    Do you hear any unusual sound when trying to operate it?
  • Jose Cada
  • Jose Cada
    The sensor might be dirty or dislodged.
    1. Check all sensor flags and make sure they are moving freely.
    2. Remove the transfer roll cartridge and clean the density sensor.Clean it with a soft cloth.
    If this still persist, it is possible that sensor is already defective that is why it is showing a faulty message.
  • Jose Cada
The fax is received by the other party but we receive an error code J72. There is no jam
Dear
If you are sending the fax using ADF, there may be the document jam, Open the ADF cover check the path for any foreign objects.
Also you can send from platen glass without document jam.
Also this may happen to the other end fax machine, better you do a test copy from ADF and Platen glass. and confirm your fax machine is ok.
Thanks.
Mar 05, 2015 | Panasonic PanaFax UF-8000 Laser Fax
My mfc240c says to replace the yellow ink cartridge but I don't want to spend money on that if the 'light bulb' is ruined. When I turn on the machine, I don't see any light for scanning or copying. ...
By the "light bulb," do you mean the scanner lamp? That lamp should only turn on when you are actually scanning, faxing, or copying a document. You should be able to still use the machine to scan and fax, even with the yellow ink empty. Try scanning a document to see if the scanner lamp comes on.
As far as printing or copying goes, you won't be able to print or copy anything until you replace the yellow ink, even if you try printing in black and white only.
Apr 19, 2010 | Brother Multi-Function Center MFC-240C...
Overheats when printing pictures on transfer paper and now it will not print anything.
hi
i have problem with my brother prinetr MFC-8460N
IT SHOWS DOCUMENT JAM
ALSO MESSAGE ON SCREN
CLEAR THE SCANNER JAM THEN PRESS THE STOP KEY
STATUS SHOWS RED LIGHT
WE ARE NOT USING SCANNER WE ONLY USE FAX AND COPY
RIGHT NOW BLUE LIGHT IS ON FAX AND WHEN I PRESS COPY BUTTON IS NOT ALLOWING ME
PLEASE ADVISE
Nov 10, 2009 | IBM Infoprint Color 1357 Led Printer
Brother fax machine Fax-2820 MFC-7225N
Hi. Open the document control panel and look in with a flashlight and see if the jam switch is stuck. also look for a small piece of paper that might be stuck in there. The jam is in where you put documents in to fax out. Lawrence
May 08, 2008 | Brother IntelliFax-2820 Laser Fax
Document Jam Error Message on Brother MFC-8660DN
I had the same problem with a Brother MFC-8460 and called Brother's support line. The solution that worked for me was to lift the top cover where the sheets of paper go through when you fax. On the right of the black rectangluar piece with grey roller there is a slot in the tray with a black lever inside. The black piece was stuck down inside the slot and had to be popped back out. Once it was out I hit the stop button and it was fixed!!
Mar 03, 2008 | Brother MFC-8660DN 5-in-1 Laser...
Scanning / faxing problem
you will need to replace the adf assembly or the portion of adf roller which was dameged.
typically one should open th ecover and take out the jam inth direction of papermovement only
happy faxing
omnipresent
Oct 17, 2007 | Samsung SCX-4216F All-In-One Laser Printer
Brother Multi-Function Center  MFC-8870DW All-In-One Laser Printer Logo
193 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
