Question about Microsoft Xbox 360 Console
I have red lights come up when i turn my xbox on instead of green
  • 4,102 Answers
Hi you have got the dreaded red ring of death, this is very common with all xboxes and their are people out their that will fix them for you for a fee.
their is nothing you can do yourself to solve this problem as its a case of taking the xbox apart and removing the heat sinks and the x clamps and fitting new parts and new heat sink paste, this is a big job and requires special tools. so its not for the novice to do.
i do the repairs to these on a regular basis and 8 out of 10 i fix work again but others tend to be to far gone.
any way the reason you are getting this warning light is due to it over heating, check the date on the sticker on the back of the xbox as it is covered by warranty for 3 years for this exact fault so if its less than 3 years old go to the xbox website and get them to replace it for you, if its outside this time then you have 2 options you could either repair it or sell it.
you can buy repair kits and get the instructions off the net but without having done it before it can by really hard to do and you could do more harm than good.
when they built these they used cheap parts and cheap heat sink paste now over time this causes it to over heat and then you get the dreaded red ring of death and this shows you the either the gpu or cpu chip has over heated.
now the repair involves taking the xbox apart which is not easy but can be done you need to then remove the x clamps and then remove both heat sinks. once their removed you need to clean them up and remove all the old heat sink paste and use new paste, you also need to get xbox rrod repair kit as you wont be using the cheap x clamp bits anymore these will go in the bin as this is what caused the problem in the first place.
let me know what you would like to do or if you need further assistance ok
i also be damaged xbox's but im based in UK
if you are going to do this yourself then make sure you have no warranty left as this fault is covered for 3 years by microsoft so if the date on the sticker on the back of the xbox is within this time all you need to do is go to the microsoft webiste and tell them and they will give you a replacement.
i charge 25pound to do the repair so you should be looking around this price if you are paying someone also their is no guarantee the repair will work as the damage caused by the over heating could have destroyed the cpu or gpu chip but you wont know this till after the repair work has been done.
if you are doing the work yourself then you need to get a erpair guide off the net so just google rrod repair guide and this will list loads of sties with these guides, you will also need to buy an xbox 360 rrod repair kit, you can get these off ebay for next to nothing, then you need to get some heat sink paste and some special torque screwdrivers to remove the xbox case.
this is not an easy job to do and getting it wrong can do a lot more harm than good if you put to much pressure on the heat sinks when you put them back on this will destroy the gpu and cpu chip so be warned.
make sure you get a guide and correct tools or if you are unsure get someone to do it who knows what their doing.
plz rate this solution as i have a whole page of unrated posts, thanks
rr1
Posted on Sep 30, 2010
  • 225 Answers
If you have this problem you can fix it by stopping the amount of heat that the system is taking and the best way to do this is send it in or you can use a good repair guide to fix it.
Posted on Oct 07, 2010
    Problem Solver:
  • 13 Answers
No pauldonp thats not how you do it
first you will need a work area screw driver any kind will work a shank a 45magnum
and a hammer first use the hammer to open the xbox be careful when duing this because you need the chip thats under the heat sink
now once youve done that use the screw driver and cut out the chip under the heat sink then use the shank to put three holes in the dvd drive now that you got the chip i told you about now its time for the 45magnum shoot at the xbox yelling F-CK YOU BILL GATES and there you have it now try to put the xbox back together yea good luck with that now your xbox should work if it burst into flames afterwords my bad
Posted on Oct 06, 2010
  • Rod Sims
    Rod Sims Oct 12, 2010
    Interesting repair procedure. I'll consider this a last resort I also found a drop
    from a tall building , seems to cause the console to self disassemble and it's
    actually quite satisfying ( therapeutic ) to see this happen. all kidding aside
    with the right hardware ie Google" Conformal Compression Assembly"
    and a solid reflow the console will become quite durable and dependable.
    Just avoid screwing down the G.P.U. and The C.P.U. with a repair kit this will distort
    the P.C. board and produce scrap. Trust me I have seen many 360's destroyed
    by this procedure.
    Rob
  • alan burns Oct 14, 2010
    lol you just brightened my day
4 Suggested Answers
SOURCE: red light on my xbox 360
Turn console of, hold sync button down wich is the small white button next memory card slots, while holding turn on console and wait till it boots. If this does not work go to system blade, select memory, press y on the HD symbol, press xx left bumper right bumper xx, select yes. This will restart your console from scratch though all profiles and saved data will be lost, but it will clear any corupt data.
Posted on Sep 16, 2007
SOURCE: The xbox 360 red light flash
turn it on and wrap it with 2 towels for 20 minutes(the idea is to overheat it), then unrap the towels and let it cool down for 20 minutes. Then, walla it works.
Posted on Dec 30, 2007
  • 35 Answers
SOURCE: xbox 360 power supply light turns yellow when xbox
make sure your xbox is in an open area where it can breathe, otherwise the one red ring means there is a hardware failure, if it is under warrenty send it back into xbox, otherwise there are some diy fixes on youtube
Posted on Mar 02, 2010
Thier is the red light that is shown instead of green
You have a problem with your hardware. This happens to about 30% of xbox's over time. It is called the red ring of death. You need to reflow the solder under the GPU chip to fix it, find an xbox repair place on ebay.com
Mar 23, 2009 | Computers & Internet
Red light instead of green
http://www.squidoo.com/xbox-troubleshooting-red-ring-of-death-fix
go here and scroll down the page to find some guidance on how to troubleshoot your problem
I hope this helps
Nov 17, 2008 | Microsoft Xbox 360 Console
Red lights
Microsoft has extended the warranty on the XBox 360 for a few more years for this specific problem. Contact Microsoft's XBox support, they will have you ship the XBox out and will repair it free of charge.
See here: http://support.microsoft.com/kb/907534
Aug 08, 2008 | Microsoft Xbox 360 Console
Console flashes red instead of green
3 x flashing red lights,everytime i turn xbox on
Jul 08, 2008 | Microsoft Xbox 360 Console
I have an xbox 360 which is defaulted wen i turn on instead og green light there is a red light too.
turn off xbox, unplug the av cord from back of xbox.. power up unit without av cord.. wait til unit shuts off by itself.. reattach the av cord and turn it on..
Jun 30, 2008 | Video Game Consoles & Games
Xbox 360
okay its called the red lights of death. there are 2 ways to fix it. one go to this website. www.xbox360-fix.com orif you are under warranty send it to microsft for a free fix.
Feb 18, 2008 | Microsoft Xbox 360 Console
Xbox 360-Red to Green
Look on the back of your tv and make sure that the red and blue cables are plugged into the right slot on the back of your tv. This would be the most common cause for something like this that you are describing.
Feb 09, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
217 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
