Question about Acer 90.00012.30B Computer Speakers
No sound Ok..here's your laugh for the day...are my speakers built in or do I have to buy them ..new to the world of computers ...my acer is just 2months old. Thanks N-Jo
  • Suresh babu
    Suresh babu May 11, 2010
    I think latest desktop like DELL provides inbuilt speakers. read the computer manual or contact ACER to know this...
  • 42 Answers
If it is a desktop then you need to purchase speakers & if a laptop then 90% there would beinbuilt speakers.
Before anything check if the sound is working on the system
Double Click on the speaker icon on the right bottom of the screen>>make sure in none of the mute boxes should be checked>>Now try to play any audio >> this can be tested by playing a song on the system
click the pearl sign on the left bottom>>click programmes>>Click windows media player>>put a cd and try playing it>>Play a file>>
Posted on May 26, 2008
Computer has no sound. Took hard drive to Best Buy. Geek said according to the computer, the sound card is ok, don"t know why there is no sound, oh and by the way you have a high fidelity sound card, and...
Yes you should be able to fix this. First do you have external speakers for this computer or is it internal? Next has this worked before and stopped working?
Aug 14, 2010 | Dell Dimension 4700 PC Desktop
Speaker in the Monitor?
It looks like there are no speakers according to:
http://support.acer.com/acerpanam/monitor/0000/Acer/X193/X193sp2.shtml
You should be able to use any external speakers to your system. The question is looks and power. You will likely have to buy speakers that have power in order to get enough volume.
Most speakers that come with monitors are of very, very low quality. You now have the option of buying good speakers (if you want to pay for them). If you are in a hurry you can likely pick up cheap speakers at the drugstore or Walmart. Another option is headphones.
Good luck finding the right sound.
May 24, 2010 | Acer X193W LCD Monitor
I've just bought an ACER X193HQB moniter and there's no sound, can you help?
Thats because Acer X193HQB does not have built in speakers. To get sound you have to buy external speakers.
Aug 22, 2009 | Computers & Internet
I have an acer cpu connected to my hp monitor with built in speakers...but I have no sound?
That is a common problem. You need to purchase some new speakers from your local Radio Shack or computer store.Plug them into your cpu. Very cheap fix about $10. The mix and match connection of the HP and Acer never seems to work. The HP monitor will work with the Hp computers but not others.
Aug 15, 2009 | Acer (90.18612.36B) Computer Speakers
Just bought a acer x193w lcd monitor no sound
I assume the monitor has speakers built in . Have you plugged the sound card in to the monitor?
Jun 03, 2009 | Acer X193W LCD Monitor
Flat sceen monitors, no sound
did you hook up the sound cable to the computer? and is the sound not muted in the on screen display?
check and advise
Jan 20, 2009 | Acer AL1715 17" LCD Monitor
No sound through external speakers
Although some monitors have built in speakers, most people have stand alone speakers. If the old monitor had built in speakers and now it is unplugged you won't hear sound. Even if the speaker cable is still plugged into the sound output on the back of your computer, the monitor must be plugged into an electrical outlet to have power.
I'd recommend buying a new set of external speakers if this is the situation.
If you never had speakers built into the monitor then normally changing monitors would make no difference whatever. The only explanation that makes sense under those conditions is that in the process of replacing the monitor, you dislodged the speaker jack from the sound output on the back of the computer.
Make sure your external speakers have electrical power plugged in, the power is on (green light on at least one speaker lights up) and the volume on the speakers is at least half way up.
Unplug the speaker from whatever hole it is plugged into and plug it firmly back in and test sound.
If still no sound other than some static on the speakers, try every single hole on the back of the computer that the jack will fit properly and test for sound.
Let me know if you have further questions.
Honest1abe
Jan 10, 2009 | Acer Computers & Internet
Acer V223w monitor
Hello Cricket,
Sound/Speakers that are built into monitors, typically are pretty poor. I suggest purchasing some speaker from your local electronics store, or www.newegg.com. (New Egg has very good deals on computers and accessories, like speakers.) Here is a link to New Egg's speaker section. http://www.newegg.com/Store/SubCategory.aspx?SubCategory=60&name=Speakers
On the back of your computer, you will see little holes (3.5mm). They are usually color coded, Green is the typical speaker output jack/hole/port. When you buy your speakers, you will plug the cable with Green Head Plug (3.5mm) that is attached to your speakers, into this Green Jack. Turn them on, and you should have audio! Now, if the volume seems weak, you can double click the speaker at the bottom right of your Start Bar in windows. It looks like a little silver circle. This is your volume control There are multiple slide bars to adjust your audio.
Good Luck!
Dec 12, 2008 | Acer V223WBD Monitor
Speakers have not worked since purchased
Hi Monde
Happy Holidays,
As you said, you have warranty yet, use it! but, if you don't wish to use ti, you can buy a new pair of speakers, and use with montego bay or creative labs, USB sound card, and see if work fine, this should fix the problem.
Dec 29, 2007 | Logitech R-20 Computer Speakers
93 people viewed this question
Top Acer Audio Players & Recorders Experts
NOEL
NOEL
Are you an Acer Audio Player and Recorder Expert? Answer questions, earn points and help others
