Question about Dometic Rooftop RV Air Conditioner
What size of unit is this model number - 59516531
What is the cubic ft size of my GE Refrigerator?
On the inside wall of the refrigerator there will be a model number for unit. Usually the model number indicates the cubic size of unit.
Jun 12, 2015 | GE Refrigerators
Comfortmaker 10 HVAC output size?
Comfortmaker 10 means simply it is a 10 SEER system. Unable to determine the OUTPUT size without the Model Number. Go to the Outdoor Unit Nameplate and locate the Model No. Here is an easy way to determine the "SIZE" of the "Comfortmaker 10 HVAC" Systems:
Model No.: OUTPUT Size (Nominal Tons of A/C):
NAC015 1.5 Ton Unit
NAC024 2.0 Ton Unit
NAC030 2,5 Ton Unit
NAC036 3.0 Ton Unit
NAC042 3.5 Ton Unit
NAC048 4.0 Ton Unit
Aug 30, 2014 | Heating & Cooling
What size capacitor do i need for a 2.5 ton compressor
Each brand of unit uses different sized capacitors I need a model and serial number of your unit to actually cross reference that part. You could also call the manufacturer of you unit and find out.
Aug 26, 2014 | Heating & Cooling
Ac blower motor attic
that is a model number for the outside condensing unit. to find the motor size for the inside unit, you will need the model off of the inside unit, gas furnace or electric air handler.
Aug 15, 2013 | Ruud UAKA048 Air Conditioner
Please advise heating/cooling capacity for carrier quietline air conditioner vertical through wall model 25 years old model number unknown Thanks
Hello rgar919,
It is imposible to tell you the capacity of the unit without some kind of numbers to find out what it is. They made more than one unit 25 years ago. The numbers off the compressor may help to find the size of the unit. Please try and find some sort of model or serial number, compressor number, fan motor number something that can be cross referenced.
Thank you for choosing FixYa.
Mar 06, 2011 | Heating & Cooling
Please advise wire and breaker size for this unit. Thanks Doug
On any piece of equipment look for the model number tag and check for something that looks like M.C.A. and/or M.O.C.P. (with or without the .'s after the letters) The MCA is minimum circuit amps which indicates the minimum wire size and therefore minimum breaker size as well. The MOCP is maximum over current device. This is the Maximum fuse or breaker size recommended for the unit. However, both numbers are more importantly linked to the wire size feeding the unit. You must be certain that the wire size is large enough to provide proper voltage without overheating and not put too large a fuse or breaker for the wire size. A good electrician or an electrical chart for wire sizing is very important.
Dec 11, 2010 | Heating & Cooling
Would like to replace need to know size of unit and age.
this unit is a 3 1/2 unit...the 42 the model number...possible its a 89 or 97 model...this is a 42,000 btus unit...hope this helps...michael 843-384-8474..
Mar 27, 2010 | Heating & Cooling
How do i find coil size for a armstrong central air unit
Are you asking what indoor coil size you need to match your outdoor unit? If so the model number of the outdoor unit will have a number divisible by 12. example an 036 is a 3Ton a-c an o42 is a 3 1/2 Ton. Probably the numbers right after UAMB.
Aug 27, 2009 | Ruud UAMB Air Conditioner
Need to know unit size
ckl60 5 ton about a 2003 model on most ac heat pumps the model number reflects the ton sized by 12000 btus per ton also as for the indoor unit cfm rating 400 cfm per ton
May 14, 2009 | Goodman CKL60AR60 Air Conditioner
Air conditioner replacement--new size required?
567C024RCU In this model number is the # 24. That stands for 24,000 btu's. This is a two (2) ton unit. Has this two ton unit cooled ok in the past? if so replace with the same size. But make sure yo change the indoor coil to match the size "and" efficiancy of the ew unit.
Apr 14, 2009 | Carrier 38CKC042 Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
173 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
