Question about Aquabot Pool Rover Above Ground Robotic Pool Cleaner
What do i do to prevent the cord from twisting i know it has something to do with the pin in the wheel i just dont know what to do with it.
Why does cord on steam iron always twist any help suggestions ? What is the little thing for on the cord ?
The cord twists constantly because it is the wrong type for the intended use.
The little thing on the iron end of the cord prevents twisting at the point where it enters the iron.
Feb 26, 2015 | Irons
Can't turn yellow wheel
Remove power and twist wheel in direction so ON pin hits lever first then OFF pin hits it.
May 21, 2014 | Intermatic T8845PV - Sprinkler-Irrigation...
The pins on the USB cord seems to be a bit twisted
Hi
you may need to replace the usb cord but be careful you dont damage your usb ports.
another option for you is to buy a hub which plugs into to your usb port and provided 2 or more usb ports for you to use.
this will help stop and damage to your laptop ports
cheers
Nov 28, 2012 | Computers & Internet
G 500 logitech freezes intemittently
I think i found the solution to the Logitech G500 mouse freezing problem: the 5-pin USB cable uses an embroidered thread of fine wire for the first pin on the left (black cable at the internal connector inside the mouse). These fine threads tend to break over time due to movement of the cord, it usually brakes by the point were the cord exits the mouse casing. what i did was actually very simple: I Opened the mouse (there's 5 screws you have to remove: 2 over the optical sensor, one underneath the sticker on the center, one on the right, and one at the bottom of the mouse), then remove the scroll wheel (and basically remove every screw you see on the inside of the mouse), there's also a pin holding the scroll wheel in place, remove that too. Now remove the circuit board and detach the USB 5-pin connector. Inspect the cable (you might have to remove some of the protective cover), if you find that the embroidered wire is broken, as i did, then proceed to twist the fine threads of wire on both ends, and then twist both ends of the broken cable togheter. Obviously the resulting cable is a bit shorter than the others 4... not a problem! simply align all cables and twist the excess wire forming a circle, and just tuck it in at the bottom casing of the mouse when you put it back together. This solution might not be the most clean and professional (perfect solution would be to replace the cord), but it only took me 15 minutes, and my G500 mouse is working perfectly since; hope it helps!
Dec 23, 2011 | Logitech G500 Mouse (910001259)
Hello, since i first bought my sawzall I have had trouble with the cord the first one blowup in my ear went pop and the cord had a hole in it at the saw end I got a new one from service as the saw was new...
unplug the tool, remove the cord and look into the end that plugs into the saw. Do all the pins appear the same depth if so look at the pin housing on the tool itself for a pin that is pushed in or bent.
Feb 12, 2011 | Milwaukee Tool 10 Amp Sawzall Plus with...
Hi have a bebecar travel city but dont know how to fold it down.help
To fold down a Tracker City, firstly make sure that the front wheels are locked into fixed, non-steering mode, and that the adjustable-height handle is in one of the middle positions.
Look at the twist-grip in the middle of the handle. Press the button and simultaneously twist the collar in the direction of the arrow. The chair should begin to close at this point.
Next, find the secondary lock device, which is operated by means of a lever/tab on one side of the handle. Pull this upwards, tilt the chair forwards and continue the closing action until it is fully closed.
Align the front wheel using your foot, if necessary, to prevent the rear wheel from hitting it. To store the chair, fold down the height-adjustable handle.
Don't forget to keep the pushchair well lubricated, preferably using a silicone spray.
Why not ask service@bebecar.co.uk for a user-guide for the Tracker City?
Nov 06, 2010 | Bebecar Tracker City U319 Stroller
What is the best way to replace a fog lamp bulb on a 2008 Santa Fe?
1. Turn tires away from car
2. There is a plastic covering in front of the wheel that usually goes around the wheel well. There are plastic thumb pins on the outer edges of this plastic covering. Remove the thumb pins and this plastic piece will come off.
3. Behind this you will find access to your fog lights.
4. Then you can remove the fog light by twisting the plastic cover (if it has one) or by twisting the bulb
Nov 10, 2009 | 2007 Hyundai Santa Fe Limited
Cord keeps binding rover not reaching far pool wall
This happens to me when I don't take care of the cord according to the instructions. By it's very nature the Rover likes to twist its cord. Are you certain you are removing all the twists in the cord before you start cleaning? Also, are you swapping the pin on the moveable axle every time you clean? Swapping this pin changes the direction from clockwise to counterclockwise (and vice versa) and keeps the cord in reasonably good condition.
Aug 17, 2009 | Aquabot Pool Rover Above Ground Robotic...
Aquabot goes in one direction
Find a looooong straight area and, starting from the Aquabot, hold the cord straight and straighten it out by letting the cord twist so it isn't all gnarled and twisted - move down the cord, always keeping one hand firmly on the end of the cord closest to the machine (to prevent it from re-twisting). You'll find that the cord will spin like a top as you get closer to the end. Once untangled, pull down on the metal rings under each end of the top floating handle (may require a pull and a slap against the handle). MAKE SURE THE HANDLE IS LOCKED IN A DIAGONAL POSITION.
Jun 17, 2009 | Aquabot Turbo Robotic Pool Cleaner
Sawzall quit working
With an ohm meter check the pins where the cord plugs in. Pull the trigger and check for a reading. If that's ok, then do the same with the power cord for a reading from the plug to the terminals on the other end. My guess is that you will need a new cord. Do Not Patch a power cord!! Frankster016
Oct 23, 2008 | Milwaukee Tool 10 Amp Sawzall Plus with...
Aquabot Pool Rover Above Ground Robotic Pool Cleaner Logo
143 people viewed this question
Top Aquabot Pool & Spa Experts
Robco Water
Robco Water
The Cover Guy
The Cover Guy
David Spradling
David Spradling
Are you an Aquabot Pool and Spa Expert? Answer questions, earn points and help others
