Question about Microwave Ovens
G.E. Profile Spacemaker XL1400 will not heat food
  • 4 more comments
  • velkluth May 30, 2008
    just not what i wanted to hear, but thanks
  • mrao3 Jul 12, 2008
    My microwave doesn't heat but everything else is working fine. I troublehot many of the components, HV capacitor, transofrmer, magnetron and the diode. The only fault I can detect is the diode as I am getting an infinite reading in both directions. What is the possibility this is actually the problem. I used two different high end meters, one of them Simpson. The microwave is the GE Spacesaver 1400.
  • dickorray Jan 23, 2009
    I have the same problem as mrao3 (posted July, 2008). Did he ever find a fix? If so, what was it and how much did it cost?
  • marbelae Mar 21, 2009
    I have same problem. Did you fix yours or just buy a new one?
  • aj_acts Apr 11, 2009
    I have the very same problem. Has anyone answered if there is a fix for this or do I just need to buy a new microwave?
  • Anonymous May 21, 2009
    does not heat
    Genius:
  • 1,689 Answers
This can be the magnetron power supply area, the controler for the magnetron power supply, or the main control board itself.
If the turntable is spinning, the countdown timer is working, and the fans are going, this leaves out the possiblity for a defective safety switch.
I suggest you send the microwave oven out for an estimate if it is out of warranty. I would not suggest you try to fix this yourself.
Jerry G.
Posted on May 25, 2008
  • Jerry Greenberg
    Jerry Greenberg May 30, 2008
    It is impossible for the best of techical people to tell you the exact fault for any device without going inside and taking readings and tracing down for the exact failure. In your microwave oven there are many possible fault areas that will cause it to not be able to function.
    You will have to send your microwave in for service or buy a new one. I would suggest to not fix this yourself. The voltages employed in the power supply are lethal. There are also dangers of radition leak if re-assembly of critical areas is not correct.
    Jerry G.
GE Profile Spacemaker 2004 JVM3670BF02 doesn't Heat up
Ensure that you have select the correct range of temperature.
Sep 11, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
I have a ge spacemaker XL1400 model # JMV1440WD. Everything works fine but it will not heat anything. Any suggestions?
The magnetron (the part that heats the food) may be bad or the circuitry to the magnetron may have burned out. Basically my advice is that if you have no electrical expertise, it isn't worth fixing. The magnetron if bad, costs almost as much as a new microwave. If you open it up (make sure it has been unplugged for a few hours and don't seen any obvious burnt parts (including a fuse), then most likely the magnetron is done and a new microwave is the way to go.
Let me know how this works out for you.
Benjamin
Aug 20, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Spacemaker LX1800 that is not heating up the food. It acts like it was working normal but is not heating the food.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101==]---=]
May 11, 2010 | GE Profile Spacemaker Over-the-Range...
I have a ge spacemaker XL1400. It was manufacture
it sounds to me like the magnetron is shot in it. this is the part that creates the heat. not worth repairing on a 10 year old unit. Sorry.
Nov 08, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
MIcrowave doesn't heat up food
Microwave Oven Basic Troubleshooting Tips
heatman101
fdyjhd
Jul 18, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL1400 microwave doesn't heat anythting
Magnetron may be defective. Replace the magnetron by a new one.
Apr 30, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Spacemakerxl1400 suddely stopped heating,all other functions are working.is it due to some small problem
GE Spacemaker model XL1400 not heating. Everything else works on it, but no heat. What could be the problem? Can it be fixed reasonably?
Jan 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave stopped heating
The magnatron capaciter is burnt out (this is what heats the food!) it can be replaced but it may be cheaper to buy a new oneYjis should fix ya!
Dec 13, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Spacemaker XL1400 GE Microwave
my xl1400 spacemaker ,it just won't heat, everything else works
ok, can you all advise me what to do, what could be causing it to not heat.
wendell
Dec 08, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
1,317 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
