I need the manual for crolsey player recorder model cr247-pa
How do you record a record to the CD
Posted on Apr 17, 2016
    Master:
  • 473 Answers
Download from Google Exemple type on google .. (download Crolsey player model CR247-PA manual & drivers Then take the one you need good luck
Posted on Sep 30, 2010
I have a crossley lp player cd recorder and dont know how torecord from lp to cd
Is The Lp Player Stand Alone Or Does Have To Connect To A PC Via USB Cable.Your Pc Should Store The Recording In A MP3 File.The Resulting MP3 File Can Then Be Downloaded To The Cd.
Apr 10, 2013 | Crosley CR-2402C-PA - CD Recorder...
Need a user manuel for a Crosley#CR247 where can I find one?
If you have the Crosley Composer CR247 CD recorder and turntable, the manual is available from the product page from Crosley: http://www.crosleyradio.com/Product.aspx?pid=1791 . The direct link to the manual is http://www.crosleyradio.com/Manuals/CR247_Manual.pdf .
I hope this helps.
Jun 04, 2011 | Crosley Audio Players & Recorders
I got a pre-amp (Focusrite Platinum Trakmaster Pro) with phantom +48v. i got an M-Audiophile 2496 installed to the comp. and a mic Rode nt1A. Eveything is plugged in and installed and iv'e...
the process of elimation will help you to solve your issue. first plug the rode nt1 (great mic by the way), into a good pa head or something you know works, of course you will need to have a pa that gives you phantom power. if the mic works then move on to the preamp. try it in the pa too, if it works move on to the m-audiophle and plug a line level signal into it (a cd player or mp3 player for instance) it this works then you have determined that everything works and you don't actully have a problem other than switching, Also try plugging your mic into the M-audiophle directly and see if thaat works ( don't know if that provides the 48 volts, if it doesn't than you will have to get a phantom supply to plug into first. good luck
Mar 17, 2011 | Rode NT1A Professional Microphone
Lost manual. I need to know how to hook a TDK-3826 dual recorder to a PA System at church to record the services and what CDs to use.
Hi wpless43!
The TDK-3826 supports analog input/output, digital coaxail input/output, and digital optical input/output. To connect a PA system, you'll have to determine what type of connection it uses. If your PA system uses an analog connection, it will have two audio cables, one for the left sound channel and one for the right channel. These are color coded and can be connected to analog connections on the back of recorder. Coaxail and optical connections are both single cable connections, and can be connected to their respective locations on the back of the recorder.
Regardless of the connection used, you'll want to connect one of the outputs of the PA system to the recorder if you want record. If you want to use the recorder to play back audio over the PA, you'll want to connect the output of the recorder to the input of your PA. Most PAs support multiple outputs and inputs, so you should be able to connect the recorder input and output at the same time.
You'll want to use CD-R/RW discs to record, but make sure they are audio discs (See image). joehaydu.jpg
You can find a copy of the manual for the TDK-3826 at http://audio.manualsonline.com/mdownloads/bd4c0d62-6f82-4bfb-bf83-8d832f3fe222.pdf. Hope that helps!
Mar 05, 2011 | Computers & Internet
Crosley CR247 never used, sat for almost year, display :"OPEN"
seems you need to go to the spesific mode, fono, or radio mode.
Sep 04, 2009 | Crosley CR247 Shelf System
How to play *.s16, *.s24, *.s48 files download from RCA RP5017A
For Windows, you can download "Data Conversion Tool for PA-VR Series" from an Italian website. It's a drop and drag feature than turns the .48s into .wav. I am looking for a solution that works on MAC. http://esupport.sharp-cee.com/html/software/DataOutputDetail.php?TemplateLang=it&ID=96 Click on 'Scarcia' to download it.
Feb 04, 2009 | RCA RP5010 Digital Voice Recorder
Record using emerson dve/recorder
try this
http://www.emersonaudiovideo.com/pdf/om/EWR20V4.pd
or if i didn't provide the right model, go to this page, and enter the model.
http://www.funai-corp.com/support/manuals.aspx
hope it helps
Jan 20, 2009 | Emerson EWR20V4 DVD Recorder/VCR
Adapting a 4 channel pa system to plug into a marantz cd310 digital recorder
What is the new Pa System Brand and Model. I am almost certain that every PA System sold has a stereo or mono out put and yes there are adapters to go from mono to left and right (stereo ) on your CD310 recorder. So, the simple answer is to look at the manual or even the back of the mixer to fins out where the audio is coming out of the mixer. The mixer on the pa system will mix the sources together for you. So, you might not need much of anything but a cord to get the audio to your recorder. You can send me the model number and I can give you the exact cord you need or you can take it to a near by store that sells audio pa systems and show them what you have and what you are trying to do and they will sell you a cord that will solve your issue.
Oct 30, 2007 | Marantz PMD670 Desktop Digital Voice...
63 people viewed this question
 Grubhead
Grubhead
