Question about Panasonic NN-T695SF Microwave Oven
Panasonic Counter top Microwave model # NNT695SF Often when I push the start button, the microwave will go for a few seconds and then cut out. I then open the door and then shut the door and push the start button, and the same pattern happens. We bought the microwave two years ago and it worked perfectly for the first 18 months. The problem described above does NOT happen all of the time. It is hit and miss. Sometimes it happens as described above and sometimes it works just fine. thanks for your assistance, regards, glen
    Master:
  • 473 Answers
Issue with your Main Panel Power Fail to innitiate ..Du to Component mal-functioning inside the unit ...Possibility Magnetron defect, Or main Transformer Over heat, Also check for safety swich on the door for bad connection...
Posted on Sep 30, 2010
Panasonic 1250w genius senor inverter less then a year old. Control panel lights up, works.microwave itself does not, control panel shuts off in a few seconds
When a Panasonic Inverter Microwave shuts off after a feew seconds, it is either a bad inverter which is the quite expensive circuit board that powers the magnetron that puts out the microwave energy, or a bad magnetron, Or BOTH typically this would be a costly repair, But since it is still under warranty. You need to find a Panasonic warranty service provider in your area. If it is a counter top unit, you may have to take it to them for repair.
Jul 05, 2017 | Panasonic Microwave Ovens
Panasonic microwave works but have to lightly tap the top of the door to make it work. Sometimes it works normally, but sometimes after the time is set, and the start button is pushed, it waits for about...
Troubleshooting your Panasonic microwave oven requires removal of the cover. There may be a loose or broken connection inside. Be sure to read and heed the dangerous voltage warning. As for the repair or replace issue, that depends on age (in appliance years) and whether parts cost and labor are reasonable.
Dec 12, 2013 | Microwave Ovens
Panasonic Microwave NNA883 cuts out after 20 seconds.
You need to replace the diode. Scratch that. The voltage let alone the radiation could kill you. Call a technician. If it is a table top unit, buy a new one. It will be cheaper,
Aug 27, 2012 | Misc - MFG Microwave Ovens
Panasonic microwave model #NN-SD697S stopped working. Timer works for 2-3 seconds without motor running(heating) then turns off. Push start button, nothing happens.
@William Miller - where are you located if i'm interested in your help with the microwave repair? I'm having the similar issue with the Start buton not working for my Panasonic NNSD697SS. Thanks
Feb 10, 2011 | Panasonic Microwave Ovens
Micro wave cuts out after 20ish seconds
Try this...
Press: Function 0 2 to turn off demo mode. For future reference, Function 0 1 should turn demo mode back on.
Feb 01, 2009 | Panasonic Microwave Ovens
Stopped heating, shuts off before time expires
My panasonic microwave model # NN-S540BFW stops after 4 seconds after you hit the start button and cuts off on its own. What is wrong with my microwave?
Jan 12, 2009 | Panasonic NN-S763BF Microwave Oven
The microwave does not turn on when pushing start.
You can download your Panasonic owner's manual here.
Dec 31, 2008 | Microwave Ovens
Panasonic NN-T695SF Microwave Oven Logo
436 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
