Question about Genius 32200103101 Web Cam
I want drive - Genius 32200103101 Web Cam
    Master:
  • 473 Answers
Well Go on Google....Type Download genius 32200103101 Web Cam drivers for XP... ! or the One you use ...Good Luck
Posted on Sep 30, 2010
Aspire one can not detecthard drive
Repair laptop hard drive is not detected
Solution 1
1. Open the hard drive cover (remove two screws)
2. Remove the hard drive screws, then slide the hard drive (see the arrows)
3. Wait 15 minutes, then plug the hard drive
4. Turn on the laptop.
Solution 2
1. Remove the hard drive
2. Clean the gold layer with a pencil eraser
3. Plug the hard drive, then turn on your laptop
Solution 3
2. Plug jumper on the hard drive
Solution 4
1. Remove the hard drive, plug the external cable.
2. Connect the hard drive to another computer, with USB connection
3. If the hard drive can be detected, eject the hard drive
4. Plug the hard drive to the laptop, then turn on
Intended to make the hard drive can work with the help of another computer
Solution 5
1. Remove the laptop hard drive
2. Plug the laptop hard drive to my PC.
SATA1 - PC hard drive
SATA2 - Laptop hard drive
3. Boot the computer from a PC hard drive
The purpose of using a PC computer main-board as drivers of the laptop hard drive.
I hope this information helps. Thank you for using FixYa!
Oct 15, 2011 | Acer Aspire One PC Notebook
I have photos files etc in my pen drive of Kingston DT 101 G2, what do i have to do to run ur Drive to see my files and photos ? can some one help me? thanks, Janaka
Insert the pen drive into USB port, then open My Computer. You will see some drives. Hard disk drives, CD Room drives, and removable media drives. Example: Your hard disk (drive C, D, E), CD Room (drive F), Removable media (drive G). So, each time you insert a tool such as pen drives, memory cards, etc, you can see it on drive G.
To view the data pen drive, double click My Computer, click the drive G. If you want to move files from pen drive to your hard disk, open the drive G, block all files, copy and paste to drive C / D / E.
hopefully help
Sep 25, 2011 | Kingston 4GB Secure Digital High Capacity...
How to unlock a sandisk cruzer usb flash card 16 gb
If you cannot open your usb drive, you will need to open your drive management. Sometimes, drive letters that the usb drive looks for, usually F, G or H, are taken by other drives. You can change drive letters on other network drives to different letters, therefore, allowing the usb drive to access the letters it is looking for, and effectively, unlocking it. Below are directions on using the Disk management utility in windows:
Disk management utility will help you see all the drives that are connected to your computer, including internal hard drives, CD or DVD Drives, and removable storage like USB sticks and external hard drives. Using this utility, you can check for attached drives that are not visible in windows when attached to your computer. You can also format drives, change drive letters, mark a partition as active and delete partitions. A word on caution about using the Disk Management Utility: This utility can cause destruction of data. If you are not sure of what you are looking at and uncomfortable with using this utility you should consult with an advanced user before making any changes to drives using this utility. Also, drive '0' is usually your main hard drive.
Right click on you "My Computer" Icon
A menu will open
Chose "Manage"
The Computer Management window will open
The Computer Management window is broken down into 3 sections.
The first section on the left side of the window shows a menu. Disk Management is on the lower portion of the menu.
The right side is separated into two sections, top and bottom. The top portion shows a list of active drives on the computer. The lower portion shows all drives connected to the computer. CD or DVD drives that have not disk will not show as active drives on the top section, but can be seen in the lower section.
The lower section will show the drive description, drive size and drive condition (online or off line) in small box on the left side of that section. Disk drives will designate a "Drive" and a number. Drive 0 is usually your internal hard drive. Then it would list drive 1, drive 2, etc, depending on how many internal and external drive sources you have connected to your computer. Then it will list your CD drives and generally show their drive letter assignments.
Next to the smaller section described above, is a larger section which shows the driver letter, size of the driver and condition (if working correctly will show "healthy")
This is the area you can right click and get a menu that will allow you to open, explore, mark the partition as active, change the driver letter, format the drive or delete a partition. (A note of caution here. Changing the driver letter on your main hard drive partition will cause windows to stop functioning. The main hard drive, or hard drive partition, is normally given the letter "C".) A hard drive may show two or more partitions with separate drive letters designated for each partition.
A drive this is having a problem may show that it needs to be formatted (status as Unformatted). This can be done from this window. An external drive, whether it is a hard drive or CD/DVD drive, can have the letter designator change done if you want to organize your external drives. There are times when a drive will not show up because the drive letter that they are programmed to use are taken. Most USB drives are programmed to us the letters "F" or "G". In this area, you can assign the USB drive any drive letter that is not being used and this will make it visible in windows.
Jan 04, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Unable to access files
To access the files off the hard drive another way - remove the hard drive from the case and connect it to an USB hard drive adapter and then plug it into a working computer's USB port. If the computer see the hard drive as an external hard drive/storage device and you can open the folders and files then backup your data. This also indicated the hard drive is OK and the Western Digital case/electronics is faulty.
To use this as an external USB hard drive, put the hard drive in an USB adapter case.
Sep 09, 2010 | Western Digital 320GB MyBook External USB...
How can I turn my netork hard drive into a External hard drive
Network hard drive is also an external har drive but its shared over a network. If you want it to be used a external hard drive connected directly to you computer, read below.
Your WD drive should have a USB port on it. You need to plug the drive into your laptop directly to be used as a external hard drive.
Please rate if helpful.
Thanks
Apr 19, 2010 | Western Digital My Book Essential 1TB...
Want to remove wd2500 drive from HDD enclosure and
OK your hard drive is an ATA drive.
You motherboard will have two hard disk controllers, on the 1st controller the ATA cable will have two connectors - a connector will have the C drive hard disk attached to it and the jumper on the hard drive will be set as the Master drive. You may also have a CD or DVD drive connected to this cable, if so then the CD or DVD drive will be jumpered as a Slave drive.
If the second connector does not have a drive connected, then you can connect the second hard drive to this connector BUT it needs to be jumpered as a Slave drive.
You may elect to connect the second hard drive to the second IDE controller instead on the first controller. If there aren't any drives on the second ATA cable then the second hard drive can be jumpered as either a Master or Slave drive.
If there is a drive on the second ATA cable you need to determine the jumper setting of that drive and then set the jumper on the second hard drive to a different setting. BOTH drives on the same cable CANNOT have the same drive setting.
After installing the second hard drive, check the BIOS configuration of the second hard drive, if the hard drive is detected then when Windows boots up you will see the hard drive and its contents.
Dec 08, 2009 | Western Digital Caviar WD2500BB 250 GB...
How do i remove a belt from a 2001 hyundai xg300 car
Removal & Installation
  1. Raise and support the vehicle.
  2. Remove the engine splash shield.
  3. Rotate the drive belt tensioner clockwise to release the drive belt tension.
  4. Remove the drive belt from the alternator.
  5. Slowly release the drive belt tensioner.
  6. Remove the drive belt from the accessory drive pulleys.
To install:
  1. Install the drive belt to the accessory drive pulley.
  2. Rotate the drive belt tensioner clockwise.
  3. Install the drive belt to the alternator.
  4. Ensure the drive belt is properly aligned and seated into the grooves of the accessory drive pulleys.
  6. Install the engine splash shield.
  7. Lower the vehicle.
Accessory drive belt routing—1.5L engine
Accessory drive belt routing—2.0L engines
Accessory drive belt routing—2.4L engines
Accessory drive belt routing—2.5L and 2.7L engines
Accessory drive belt routing—3.0L and 3.5L engine
Oct 17, 2009 | 2001 Hyundai XG300
How to make Seagate ST3200822AS 200 GB Hard Drive
If you are using the drives in a fairly new computer, the drives have a setting called "cable select" If these are EIDE drives, then they have jumpers on a set of pins on the power side of the drive. Look on the drive and use the power plug as a reference for how the jumper fits on the pins to make the drive "cable select" and what that means is the drive will conform to which cable is plugged into it. If you have the slave cable plugged into the drive, that is how the motherboard will recognize it.
Sep 25, 2009 | Seagate ST3200822AS 200 GB Hard Drive
How do I change the timing belt on a 2003 Tiburon
2003 Hyundai Tiburon 2.7L MFI DOHC 6cyl
Inspection
Inspect the drive belt for signs of glazing or cracking. A glazed belt will be perfectly smooth from slippage, while a good belt will have a slight texture of fabric visible. Cracks will usually start at the inner edge of the belt and run outward. All worn or damaged drive belts should be replaced immediately.
To install:
Fig. Accessory drive belt routing-3.0L and 3.5L engine
Fig. Accessory drive belt routing-2.5L and 2.7L engines
Fig. Accessory drive belt routing-2.4L engines
Fig. Accessory drive belt routing-2.0L engines
Fig. Accessory drive belt routing-1.5L engine
Fig. Accessory drive belt routing-3.0L engine
Fig. Accessory drive belt routing-2.5L engines
Fig. Accessory drive belt routing-1.8L and 2.0L engines
I hope help you with this (remember rated this help) Good luck.
Sep 15, 2009 | Hyundai Tiburon Cars & Trucks
Cant find 97 ford taurus serpentine belt diagram
Drive Belt Replacement ani_caut.gif WARNING: IF EQUIPPED, DO NOT ALLOW DRIVE BELT TENSIONER (6B209) TO SNAP BACK AS DAMAGE TO DRIVE BELT TENSIONER OR PERSONAL INJURY COULD RESULT.
NOTE: Minor cracks in the V-grooved portion of the serpentine drive belt (8620) are considered normal and acceptable. If the drive belt has chunks missing from the ribs, the drive belt should be replaced.
NOTE: Conditions requiring drive belt replacement are excessive wear, rib chunk-out, severe glazing, frayed cords or other conditions. Replace any drive belt exhibiting any of these conditions.
NOTE: When installing drive belt on pulley, make sure that all V-grooves make proper contact with pulleys.
Drive Belt, Serpentine—Except SHO
Removal
  1. ani_caut.gif WARNING: USE CAUTION WHEN REMOVING OR INSTALLING DRIVE BELT TO MAKE SURE THAT TOOL DOES NOT SLIP FROM DRIVE BELT TENSIONER OR PERSONAL INJURY AND/OR DAMAGE TO DRIVE BELT TENSIONER AND DRIVE BELT MAY OCCUR.
    Using a 15 mm socket or wrench on bolt attaching drive belt tensioner pulley, rotate drive belt tensioner clockwise on 3.0L (2V) and 3.0L (2V) FF, rotate the drive belt tensioner counter clockwise on 3.0L (4V) to remove drive belt from pulleys. Make sure spring keeper engages into slot.
    Drive Belt Tensioner—3.0L (4V)
Installation
  1. Install drive belt over all pulleys (except drive belt tensioner).
  1. Rotate drive belt tensioner as described under the removal procedure and install drive belt over drive belt tensioner pulley. Make sure that all V-grooves make proper contact with pulleys. Make sure spring keeper releases or improper belt tension will occur.
    Pulley, Routing—Accessory Drive Belt 3.0L (2V)/3.0L (2V) FF Engine
    Item Part Number Description 1 10300 Generator 2 6C348 Idler Pulley 3 3A674 Power Steering Pump 4 19703 A/C Compressor 5 6312 Crankshaft Pulley 6 6B209 Drive Belt Tensioner 7 8501 Water Pump 8 8620 Drive Belt
    Pulley, Routing—Accessory Drive Belt 3.0L (4V)
    Item Part Number Description 1 3A674 Power Steering Pump 2 8501 Water Pump 3 19703 A/C Compressor 4 8620 Drive Belt 5 6312 Crankshaft Pulley 6 6B209 Drive Belt Tensioner 7 10300 Generator
3.4L SHO Engine
Removal
  1. Remove the right front wheel and tire assembly. For additional information, refer to Section 04-04.
  1. Remove the inner fender splash shield.
  1. Remove the alternator shield.
  1. ani_caut.gif WARNING: USE CAUTION WHEN REMOVING OR INSTALLING DRIVE BELT TO MAKE SURE WRENCH DOES NOT SLIP FROMDRIVE BELT TENSIONER OR POSSIBLE PERSONAL INJURY AND/OR DAMAGE TO DRIVE BELT TENSIONER AND DRIVE BELT MAY OCCUR.
    Using a 3/8 inch ratchet on the lifting lug, rotate drive belt tensioner counterclockwise (upward) and engage spring keeper. Remove drive belt from drive belt tensioner.
  1. Lower vehicle.
  1. Remove drive belt.
Installation
  1. Install drive belt over all pulleys (except drive belt tensioner ).
  1. Raise vehicle on hoist.
  1. Rotate drive belt tensioner , as described under Removal procedure and install drive belt over drive belt tensioner pulley. Make sure all V-grooves make proper contact with pulleys. Make sure the spring keeper is released or improper belt tension will occur.
  1. Install the alternator shield.
  1. Install the inner fender splash shield.
  1. Install the wheel and tire assembly. For additional information, refer to Section 04-04.
    Pulley Routing—Accessory Drive Belt, 3.4L SHO
    Item Part Number Description 1 3A733 Power Steering Pump Pulley 2 6B217 (RH) Idler Pulley 3 19703 A/C Compressor 4 8620 Drive Belt 5 6312 Crankshaft Pulley 6 6B209 Drive Belt Tensioner 7 10346 Generator 8 6B217 (LH) Idler Pulley 9 6B217 (Center) Idler Pulley
Drive Belt, Water Pump
Removal
  1. NOTE: If removal of the water pump drive pulley is required, refer to Section 03-03.
    Rotate drive belt tensioner clockwise by hand and remove drive belt from drive belt tensioner .
  1. Remove drive belt from water pump drive pulley and water pump pulley.
Installation
  1. Position drive belt onto water pump drive pulley and water pump pulley.
  1. Rotate drive belt tensioner clockwise by hand and install drive belt over top of drive belt tensioner pulley. Make sure all V-grooves make proper contact with pulleys.
    Pulley Routing—Water Pump Drive Belt
    Item Part Number Description 1 6B209 Drive Belt Tensioner 2 6A312 Crankshaft Pulley 3 8501 Water Pump 4 8620 Drive Belt
Jun 01, 2009 | 1997 Ford Taurus
Genius 32200103101 Web Cam Logo
20 people viewed this question
Top Genius Computers & Internet Experts
micky dee
Mirca Sekosan
Mirca Sekosan
Are you a Genius Computer and Internet Expert? Answer questions, earn points and help others
