Question about Microwave Ovens
I purchased the set of pot and pans for my parents 10 years ago. the 6' sause pan coating has come off. I bought the set from QVC. can you replace the pan? you can call me Ms. demandel at 404-788-0700. thank you for your tome
    Master:
  • 473 Answers
Look Carefuly under or handle for number factory anything can identified those pan Then From QVC.com check for service repair then fill up the form for order.. Good Luck
Posted on Sep 30, 2010
Is it possible to restore the teflon surface of teflon coated pans on which the surface has become scratched (in this case Jamie Oliver Tefal Frying pans)
No. There is no effective repair procedure for the pan once the teflon coating has become scratched down to the bare metal or begins peeling off.
You can continue to use the pan safely, but the non-stick surface will not be as effective as an undamaged coating would be.
Never use metal forks / spatulas / utensils on a teflon coated pan.
Instead try using thermal rated plastic, teflon, or wooden spatulas which will not scratch the pan coatings.
Good luck.
Jun 12, 2011 | Microwave Ovens
Can i refurbish my non stick pan. Some of my friends used a knife and made some nasty marks. can i get this fixed
At best you can recycle. Once the skin of the coating is compromised, there is little or nothing you can do to re-coat the surface with a coating such as the factory coating.
I use pans with compromised seals as a double boiler when making candles. I put my wax pot in the frying pan, fill with water, then melt my wax. I do not care of the pan gets wax on it because I no longer use it for cooking.
I also use larger frying pans pans with compromised seals under the car when I drain oil. I allow the oil to drip (provided it is less than 4 qts.) into a plastic milk container that I cut the top off of. I set the plastic container into a large frying pan that I no longer use. The handel on the pan makes it easy to slide out the plastic container once it is full of oil. I then take a funnel and transfer the oil into another milk jug or old 164 oz laundry detergent bottle that still has the threads for the plastic cover in tact. I mark it used oil and set it aside in the corner of the garage for when our community allows for the annual oil and chemical waste pick up.
My dad was an avid hunter...he used old frying pans for target practice when on the country land...he'd hang pans from the handel and shoot at the pans he hung.
Sorry this is the best I could do.
Being a mom that has gone though this enough times....I removed all my metal utensils from the drawer next to the stove with plastic ones hoping my kids would grab the closest which are now plastic that is heat tolerant.
Mar 20, 2011 | Microwave Ovens
I have the cooks essentials cookware (2008) purchase from QVC & the coating is coming off. Can I have these replaced. and how do I start the process to return them?
Contact QVC directly. Most of what they sell is shoddy tat so they're pretty used to dealing with warranty claims.
Feb 16, 2011 | Microwave Ovens
I have a black sticky residue on the non stick surface of my cooks essentials 12 inch frying pan. I can not clean it off and the non stick properties of the pan is gone, I think due to this surface...
Go to epinions.com, type your product and find you are not alone. Besides, as there is no cure to baldness there is no such thing as a perennial non stick pan. All coatings invented eventually succumbs to the wear and tear produced by temperature changes, contact with food and related chemistry, detergents, scrapping, etc. Consider the possibility that some of that non stick material may be ingested unconsciously.
Dec 18, 2010 | Microwave Ovens
I am having problems with the coating on the inside of my pans. It is coming off. What can I do?
If you are referring to the teflon coating, the only thing you can do is throw them away because that teflon is very cancer causing and toxic. How old are the pans? Just go to walmart and buy another set.
Thanks,
Lee
Oct 19, 2010 | Microwave Ovens
I have a new induction cook top. When using for the first time I found an F or P appeared next to the element I was using. I have bought stainless steel cookware specifically to use. The user manual...
Stainless steel (or Aluminium) cookware will not normally work with an Induction cooker: Induction cooker need cookware that have a certain amount of metal especially at the bottom of the pot or pan.
An easy way to check if the cookware is suitable is to use a small (fridge) magnet: if it stick to the pot/pan then it is very likely that the pot/pan is suitable for induction 'magnetic' cooking!
Hope my small hint is of assistance and if so, vote accordigly!
Oct 03, 2010 | Westinghouse Microwave Ovens
I bought (2) complete set of cooks Essentials pots & pans quite a few yrs,ago. One set was returned for defects, along with the orig.sales slip from QVC. Now my set is loosing the Teflon along the...
Dear Mary:
There is not a way to do that. You have stated that the set is several years old. The set is far out of warranty and the manufacturer has no interest or responsibility to replace it. I am sorry to be the conveyor of bad news, but it is time to shop for a new set of pans.
It is very unsafe for you to continue to use the pans as consuming the loosened teflon material is proven to be a health hazard. Sounds like they had a good run and are ready to be retired.
Best regards, Farmerbear at FixYa.com
Sep 14, 2010 | Microwave Ovens
Microwave starts on its own and displays PAN
You have a shorting membrane keypad.
I'm contacting you directly.
May 22, 2010 | KitchenAid KHMS155L Microwave Oven
A WESTPOINT WQP12-9011E DISHWASHER, USER MANUAL
Try:
https://www.2instructions.com/results_mm.php?marque=WESTPOINT&materiel=Dishwasher
Jan 12, 2009 | Westpoint TV-201 Microwave Oven
Microwave Ovens Logo
46 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
