Question about Samsung CLP 300 Laser Printer
The paper is not feeding into the printer. I think there is a problem with the rollers.
    Scholar:
  • 78 Answers
If the paper does not make it out of the paper tray, this will be a pickup roller issue. This is the roller that initally feeds the paper up into the paper path. This can be replaced, but you may nee a tech to do it. It can also be cleaned. Turn off the printer, remove the paper tray, and look inside. The roller will be about 2 inches wide and is probably a grey color. Using distilled water only on a qtip, clean the roller, changing the qtip frequently. Allow to dry completely, or wipe gently dry with a lint free cloth. Reinstall the paper tray and try printing again. If this does not resolve the issue, contact a tech for replacement. Should probably cost about $50 total, including part.
Posted on Sep 30, 2010
The printer thinks there is a paper jam-when we ask it to print it doesn't "grab" the next piece of paper-it clicks and then give a "paper jam" message please help
Typically these failure-to-feed problems are due to worn rollers - the feed roller is so worn
that it fails to feed the sheet of paper, which the printer misinterprets as a paper jam (because a
sensor tells the print processor that the sheet of paper is not present where is should be, and
therefore the printer microprocessor software issues a "PAPER JAM" error message).
The printer repair tech solution to this problem is to install a "roller kit," which entails the
replacement of every roller in the printer (since they all wear at about the same rate, replacing
just one is less effective than replacing them all).
Your quickie (temporary) solution - get the roller damp (this makes it grip a little better), then
load the paper tray to its maximum (pushing the paper into the paper pickup roller), then print a
couple precious pages while you order the roller kit online, and text your handy geek friend
who can change out all the rollers in your printer for a pizza.
Feb 18, 2011 | Canon PIXMA iP1600 Printer
Ricoh Aficio 1515
is thera paper jam sensor wigle paper in and out unplug unit from wall 2 min ten back in hit sensor with paper hit reset on unit
Jan 22, 2008 | Ricoh Aficio 1515MF All-In-One Laser...
Feeding paper: how to fix the automatic feeding from the tray? I think the printer won't pick up the paper from the tray. we always have to manually feed the paper. How to fix it?
Pull out a paper cassette, lift up the printer and under you see paper feed roller (it is rubber), just clean roller with cloth and water or alcohol
Dec 13, 2010 | Xerox DocuPrint 203A Laser Printer
My canon printer/copier does not feed paper in machine. makes all the sound but wont feed. help
1. Try cleaning the paper feed rollers
Instructions how to clean the paper feed rollers.
If the paper feed rollers become dirty, they may not be able to properly feed paper due to the feed roller's slippage.
If paper does not feed correctly, perform the following to clean the paper feed rollers:
  1. Open the Printers folder.
    - For Windows XP Home Edition : Click/Select 'Start,' 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.
    - For Windows XP Professional Edition : Click 'Start' and 'Printers and Faxes.'
    - For Windows Vista : Click 'Start,' 'Control Panel,' 'Hardware and Sound,' and 'Printers.'
    - For Windows 2000 : Click/Select 'Start,' and 'Settings,' then 'Printers.'
  2. Right-click the icon of the printer for paper feed roller cleaning, and select 'Properties' from the displayed list.
  3. Click the 'Maintenance' tab and click 'Roller Cleaning'.
    Remove all sheets of paper from the rear tray, then click 'OK'.
  4. Confirm the message, and click 'OK'.
    Note: Clicking 'OK' will activate the paper feed rollers 30 times. This activation will take about 90 seconds. Do not perform other operations until this operation has finished.
  5. Confirm the message, and click 'OK'.
    After the continuous paper feeding operations in step 5 have finished, load three sheets of plain paper and click 'OK'.
  6. Confirm the message, and click 'OK'.
    Note: “Feed roller cleaning is completed” message is displayed when the paper is fed and ejected.
    Click 'OK'.
Roller Cleaning is completed.
Sep 06, 2009 | Canon PIXMA MP190 All-In-One InkJet...
Hi, i have a lexmark x4550. The pick up roller (the roller that grabs the paper and feeds it into the printer to get printed on), is not working, at least one of them isnt (there are two i think,,, but on...
Try the following: take an A4 sheet of paper and glue a 2 - inch strip of sanding paper onto the top of the sheet (full width of the page). sanding paper should be about 120 grain.
Now feed the page with the sand paper first (rough surface on top) into the paper inlet. grab and hold the paper, then press paper feed or send a print job. The printer tries to feed you special sheet, but you won't let go. This will sand off the gunk from you feed rollers and give a bit of rough surface to the rubber. Repeat if needed, it should cure the problem.
This works if the problem is the roller surface, it will not fix a problem with misalignment or a missing/broken spring in the feed roller mechanism.
regards, the perfessa
Aug 23, 2009 | Lexmark X4550 Multifunction Wireless Color...
Hp laserjet 1320 paper jams constantly. not even one page prints. what could be the problem?
could actually be the paper your using. make sure your using at the very least multipurpose paper or laser paper. check to make sure your settings for paper is also set to regular paper and not cardstock or special paper or anything else
Jul 30, 2009 | HP LaserJet 1320 Printer
Paper keeps jamming
Its right most of printer has 2 or more paper feed but when its feed the path will be one path its one roller path ,therefor i think roller has problem ,clean it ..
Jan 25, 2009 | Office Equipment & Supplies
Paper feeds into printer uneven
check for anything obstructing the path of the paper..usually something very tiny! and clean the rollers with toothbrush & water.
Nov 29, 2008 | Lexmark X2500 All-In-One Printer
Manual Feed Gets Jammed
It might be the feed roller. Sometime its the roller or the clutch if it isn't feeding.
Jun 12, 2008 | HP LaserJet 5200tn Printer
Samsung SCX-4216F feed wheel
Clean the Feed Roller In the middle of the printer. Take the paper tray out- you will see the roller in the middle. Send a print job with paper tray removed. Press the black thing to fool the printer that it has paper. You will see the feed roller move. When it is in the position you want to clean- open the toner door and it will stop moving so you can clean it. Isopropyl alcohol and LINT FREE CLOG.
Nov 07, 2007 | Samsung SCX-4216F All-In-One Laser Printer
Samsung CLP 300 Laser Printer Logo
832 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
