Question about Kenmore 31913 Progressive Direct Drive Bagged Upright Vacuum
Kenmore Progressive issue
The dirt sensor red and yellow lights stay on all the time now. I've had the vacuum for two months. The suction is still fine, so I assume it's a sensor problem. But if this is a main feature of the vacuum and it goes on the fritz this fast, that's now good. Any suggestions? Cleaning of a sensor? Where is the sensor located?
  • 2 more comments
  • rbbrian May 29, 2008
    I have the same problem but I've had the machine longer than you have...
  • vjblather Jun 02, 2008
    This was really helpful. Guru broke it down to brass tacks. Thanks!
  • Anonymous Mar 10, 2009
    Same problem red indicator  light problem and have tried resetting agitator, replacing bag, cleaning filter, cleaning hose. Nothing works. A lot of money for a shoddy machine that didn't make it to the second bag . I used to like it.
  • Anonymous Mar 13, 2014
    Dirt sensor light stays red
I started by replacing the bag. No change.
I opened the bag compartment and noticed that the dirt sensor went to clean, but only when the compartment was open.
I cleaned out the foam filer at the bottom of the bag compartment. No change.
I took off the air outflow filter and cleaned it (Should have replaced it, but don't have a spare right now.). No change.
Unscrewed the hos from the back of the vacuum. The dirt sensor again went to clean.
I had isolated the problem to the hose. I hooked the hose back up and the dirt sensor went to dirty again.
The problem was that the hose was dirty on the inside. To clean the hose, I stretched it out little by little and banged it a little to loosed the dirt with the vacuum running. After the hose was cleaned, the dirt sensor had no problems.
Posted on Nov 30, 2008
In manual it tells you how to clean the dirt sensor
Posted on Aug 03, 2008
    President:
  • 1,673 Answers
Without the model number, I can't tell you where the sensor is, alot of times it is where the hose goes into the vac. If your hose comes off, look in the duck there, you should see a circle or disc that is covered over with dirt. But there maybe a circuit board that is giving problems.
But you have a 1 year warranty on this, if you can't figure it out, take into Sears for service.
Posted on Jun 01, 2008
We understand that your problem is: I currently own and use on a regular basis the Kenmore Progressive upright bagged vacuum. Model number 116.35923500. The headlight flickers and the intelliclean light...
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
Jan 17, 2011 | Kenmore Progressive 35922 Bagged Upright...
My Kenmore bagless intelliclean vacuum is making a loud noise mainly when it is vacuuming on the highest setting (when the light is red). We have taken it apart and cannot find a clog. It has also lost...
This might help, it was posted on a previous problem but is the same issue you are having it seems: "Here is a possible solution. If the vacuum sounds normal when the green light comes on, then the issue is a suction bypass. Kenmore built a suction bypass in to help cool down and protect the motor should someone either never clean the filter, empty the canister or somehow manage to clog the hose. There is a spring holding the bypass closed and is overridden by vacuum suction. I guess the spring becomes weak, allowing high suction to pull it open which in turn reduces suction so it closes again. It can do this several times per second making a loud racket and slightly affecting performance until the sensor goes green, then the vacuum suction is too low to overcome the spring tension thus why it sounds fine then. The trick? The very hard way (what I did) was to open the vacuum, open the casing where the spring is and pull it apart slightly to increase the spring tension. The easy way is to put tape over the hole where the bypass is. The inlet is under the hose track on the back on the right side as you're looking at it. The hole is about the size of a quarter and you'll see fins across the hole. The tape would keep the suction. The motor would still pull back the bypass but since tape is applied, there would be nothing to reduce the suction thus keeping performance and reducing the noise. However, this circumvents the intended design so you do so only at your own risk."
Dec 27, 2010 | Kenmore Progressive Bagless Upright with...
Kenmore InteliClean 116.35923502 Two, I believe unrelated, problems. 1) The InteliClean sensor lights stay amber and red even when the machine is in the upright position and the suction line is...
I had the same problem with the amber inteliclean light continually on. I found the problem to be in the plastic housing that connects the suction hose to the back of the upright section. You have to remove three screws and gently pull the hose housing off the vacuum. Inside I found a hairy clump that was caught on the inside of the hose. The optical "dirt sensor" is just inside the fitting on the upright section. When dirt or other stuff blocks the optical path of the sensors, the amber light will illuminate. My vacuum had an uneven cut on the hose which caused a snag point for hair, dirt and debris. Once this was removed, the vacuum worked like new.
Regarding the roller, this unit has an integrated motor in the roller. I would guess that you will need to take it apart, and hopefully only clean it up. If you need bearings, that will likely be expensive.
Dec 24, 2010 | Kenmore Progressive Bagless Upright with...
When on the carpet setting, the dirt sensor stays on red all the time.
two possibilites can be thought of , either there is dirt on the system filter reducing the vacuum or the said vacuum level is low.
It will be good to remove and clean up the bag, the pump and reset . Use a good air jet spray but do it out of the house please, use a good face mask as there canbe fine dust within.
Sep 18, 2010 | Kenmore 25812 / 25813 Progressive Bagged...
Loud noise from Kenmore Progressive Bagless Inteli-Clean
Jul 04, 2009 | Kenmore Progressive Bagless Upright with...
No suction
If the motor is running and is not full of dirt, and the hose is not plugged, the canister must be cracked or open somehow.
May 08, 2009 | Kenmore 22812 Bagged Canister Vacuum
Sensor
There is an optical sensor inside the port where you attach your vacuum bag. Take the bag off and take a clean soft cloth and wipe inside the port to remove dirt from the sensor. Don't wet it! Do this every time you change your bag and you shouldn't have a problem.
Nov 08, 2008 | Kenmore 31912 Progressive Direct Drive...
Kenmore progressive Direct Drive Vacuum w/Hepa
Check the hose and dirt inlet for a blockage. Also the brush roll, check it to see if you can turn it or not by hand. If not, then something may have jammed it.
May 03, 2008 | Kenmore 31913 Progressive Direct Drive...
Getting suction to use attachments
When the vacuum is in the upright position, it should give you suction thru the hose.
Dec 02, 2007 | Kenmore 31913 Progressive Direct Drive...
Red light on top is on
If you have something like a metal ball, drop it down one end of the hose to see if it comes out the other side. The hose, wands or the inlet in the power head, if any of these have a clog, that red light comes on and suction is low.
Oct 24, 2007 | Kenmore 25512/ 25513 Progressive Canister...
Kenmore 31913 Progressive Direct Drive Bagged Upright Vacuum Logo
539 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
