Question about HP PSC 2355 All-In-One InkJet Printer
My printer keeps telling me there is an error and to remove and check my color cartridge. I've been using this cartridge for several weeks with no problems. I've cleaned the contacts and nothing works, short of removing and not using it so that I can at least use the black cartridge. Are there any updates or hints you could give me so it works again?
  • 95 Answers
Please do a power drain- disconnect the printer from the computer and disconnect the power supply,press and hold down the power button for 30 seconds,connect the printer with wall socket directly and try a test page.
Still the issue remain same press and hold down the left arrow key and cancel button on the printer while it is powering on.
Posted on Sep 30, 2010
Hp psc won't print i have error ox8810869c
Posted on Oct 30, 2010
What to look for when it keeps saying ... Error .... Remove and check color Cartridge?
I suggest you run the 'Tap 10' diagnostic test pattern for your HP PS 2600 series printer model...this will display the electrical health of the ink cartridges and confirm that your printer is operational (I am guessing one of the ink cartridge control lines is open).
http://www.youtube.com/watch?v=RTFOBtdthAc
Good luck
www.inkjet411.com
Mar 06, 2013 | HP Photosmart 2610 All-In-One InkJet...
The magenta isn't printing correctly, and the printer keeps telling me to remove tape from the magenta cartridge. There isn't any tape on it. I've tried resetting it several times.
Its sounds as though the printer isnt picking up the cartridges properly, try removing it and cleaning the contacts on both the cartridge and the printer
May 05, 2011 | Dell 3130cn Color Laser Printer
Error message says "Remove and check cartridge on right" Its a new cartridge I've been using for a few weeks and it has been working fine. I have removed cartridge several times and even cleaned contacts....
The electronics on the cartridge have gone bad. Sometimes cartridges short. Take the cartridge back to where you bought it (they should give you credit for any remaining ink) and buy a new cartridge.
Aug 10, 2010 | HP Photosmart C4180 All-In-One InkJet...
Lexmark x7170 printer cartridge error
Remove the color ink cartridge and double check that the plastic tape, which you removed from the cartridge is completely removed. I've noticed that sometimes a small piece of the protective tape tears and stay stuck on the cartridge causing the printer to give a false error. When replacing the cartridge be sure its fully inserted into the color cartridge holder and the locking mechanism locks securely.
Jan 17, 2010 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
I have purchased several color cartridges this past week for my HP Officejet 85Xi and I keep getting the message to remove and check color cartridge. I do that and I've even cleaned it with a damp towel....
Did you remove the seal from the cartridges before you put them in? Double check each cartridge. Are these genuine HP cartridges? Many people believe you can substitute 3rd party cartridges or fill the original with brand X ink. My experience has been such that I will not waste my time with non-genuine cartridges.
Thanks for posting your question at FixYa.com
Dec 23, 2009 | HP OfficeJet G85 All-In-One InkJet Printer
I install a new ink cartidge color into my LexMark Printer is P4350. Its keeps telling me I have a error of 1203. What does this mean?
Bad or mis-installed ink cartridge. Open the printer and remove the ink. Clean around the ink carriage and the under the ink with alcohol and a cotton swab. Pay special attention to areas with copper contacts. If the printer has a cleaning option either on the printer itself through the menuing system or on the machine through the print driver, you can use that afterwards. Some printers will let you re-run the cleaning utility several times. Keep in mind too that some printers will not print, even with full ink, if the exact type of ink it expects you to have is not installed. This will give a similar error. Double check that the ink is correct against the manual or written instructions inside the printer. Not every cartridge that fits the printer necessarily works.
Nov 08, 2009 | Lexmark P4350 All-In-One InkJet Printer
Cartridge Error 50 C in manual A 960 No l
One solution is to replace cartridge snap-down levers  (the levers that snap down inside the dell printer to hold the cartridges, blue for color and black for black). This seemed to have work for several people with the same issue.
Nov 25, 2008 | Dell A960 All-In-One InkJet Printer
Hp psc2410xi
The following error message appears on the color graphics display after you insert a cartridge: Remove and Check Print Cartridges . The printer will not print. The message does not specify which cartridge has caused the error. Solution This error message indicates that the printer cannot determine which cartridge is causing the error. Follow the steps below to solve the problem.
  1. Remove the color cartridge from the left stall (which has a blue latch) and refasten the latch. Leave the other cartridge in place.
  2. Close the printer, wait 10 to 15 seconds, then look at the LCD display.
    • If the LCD display reads Insert Color Cartridge in Left Stall , the color cartridge may be causing the problem. Follow the steps below:
      1. Clean the color cartridge contacts.
      2. Reinsert the color cartridge into the carriage and close the blue latch.
      3. Close the printer and wait 10 to 15 seconds.
      4. If the LCD display reads Remove and Check Print Cartridges , replace the color cartridge.
    OR
    • If the LCD display reads Remove and Check Print Cartridges , follow the steps below:
      1. Reinsert the color cartridge.
      2. Remove the black or photo cartridge, depending on which one is installed in the right stall. The right stall has the gray latch. Be sure to refasten the latch on the empty stall.
      3. Clean the black or photo cartridge contacts.
      4. Reinsert the black or photo cartridge.
      5. Close the printer and wait 10 to 15 seconds.
      6. If the LCD display reads Remove and Check Print Cartridges , replace the black or photo cartridge.
  1. Remove and then reinsert the cartridge indicated in the error message.
  2. If the error is still displayed, clean the contacts.
    1. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. Remove both cartridges, lower the latches, and close the printer access door.
    2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
    3. Turn the printer back on by pressing the On button.
    4. When the message display reads Insert Print Cartridges , open the access door and replace the cartridges.
    1. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty
    Aug 12, 2008 | HP LaserJet 5L Printer
    Lexmark X6170
    There will be blue tape when turn the cart upside down please remove the the tape ...and check there no tape :if the printer states the same error remove the cart and check for the error if error is displayed turnoff and remove power adapter for 30 sec and reconnet it back and check for the error If displaye it printer problem..
    Feb 19, 2008 | Lexmark X6170 All-In-One InkJet Printer
    HP PSC 2355 All-In-One InkJet Printer Logo
    1,044 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
