Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
My ice maker stopped making ice...is there anything i can check myself to correct this problem
    Brigadier General:
  • 3,513 Answers
If the ice maker has completely stopped producing ice :-
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahrenheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly:-
When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Check this link for your knowledge:-
http://www.partselect.com/refrigerator+icemaker-no-ice+repair.htm
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Posted on Sep 30, 2010
Frigidaire KSRA22 CNWHOO Side-by-Side refrigerator, Serial # SS1241434 I just changed the filter in my Frigidaire refrigerator. It had stopped making ice when the filter light came on. However, now...
Are you getting any water.
If you push the tab for water any you hear a buzzing or humming sound with no water then it could be you water pump which is located at the back of the fridge.
Just follow the water line and you will find it .
It's a small pump
May 26, 2017 | KitchenAid Superba Architect KSCS25INSS...
Our ED5SHAXM ice maker is intermitant. It will make ice for several weeks and then suddenly stop making ice, the water flow to the ice maker stopes and the bin empties it's final time. Then weeks later it...
Either the freezer temperature is too high or the internal thermostat inside the ice maker is faulty.
The freezer temp must be 5 degrees or less for the ice maker to work correctly.
If the freezer checks out OK you will need to replace the ice maker.
Apr 10, 2011 | Whirlpool ED5SHAXM Side by Side...
The ice maker in my Whirlpool Gold refrigerator has stopped making ice. There is ice in the tray, but it won't empty itself.
If the " tray " you are refering to , is the ice maker mold , then clean the coils in the front , under the refrig ( condensor coils ) . Also check the fan behind the refrig , to make sure it is working . An ice maker has to be 5 degrees to cycle . Bothe the coils and the fan , have to be checked to be sure the freezer is at the correct temp for the ice maker to opperate properly . If both are ok , then replace the ice maker .
Sep 23, 2010 | Whirlpool Refrigerators
The ice-cube maker on our Sub-Zero 650 has stopped making ice.
try replace the cheapest part first.( vater valve). you only need 2 components to make ice. water valve and ice maker.is simple and easy water valve located in the bottom part of the unit. remove the kick plate. left side. and color blue. ice maker inside the freezer. (DISCONECT POWER BEFORE SERVICE. ALSO TURN WATER SUPPLY OFF.) try main box , garage. and water meter outside your house. good luck
Apr 02, 2010 | Sub-Zero 650 / O Bottom Freezer...
Ice maker stopped making ice. I emptied ice holding tray and since then, if will not make ice. I adjusted arm in hole correctly. Arm is down and is in correct position to make ice. Still no ice. Please...
Fill the ice maker with water. If it freezes and dumps the the water control valve on rear of the refrigerator and near floor is defective and will need replace. If the water just freezes then the ice maker thermostat is the problem, Let me know,Thanks Sea Breeze
Aug 17, 2009 | Refrigerators
After my ice dispenser jammed my ice maker stopped making ice
make sure you reassembled it correctly.
icemakers can be stubborn with their safety features and will not work if not propperly reassembled
Jul 30, 2009 | Whirlpool GS6NBEXR Side by Side...
Doesn't make ice
WATER SULLPY VALVE ON BACK BOTTOM IS BAD OR WATER SUPPLY TUBE TO ICE MAKER IS FROZEN,LET ME KNOW WHAT YOU FIND-MIKE
Nov 01, 2008 | Maytag MFF2557HES Stainless Steel French...
GE TFX22CR Ice Dispenser inoperative
Check the ice maker see it is in the right position, maybe you can try pull out the ice maker and clean it and push it back, make sure the position is right.
May 28, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice maker stopped working and no Water in Ice maker,,,
I had this same thing happen and I just fixed it! After returning from a long trip, I threw out the old ice (now mostly shrunk), but no new ice was being made. The tray where the ice is made was completely empty/dry (maybe any ice cubes there had "shrunk" away to nothing as well? perhaps part of what keeps the freezer "frost free"?).
So I filled the tray with water using a small measuring cup -- which is what the manufacturer suggests when the refrigerator is new. Now it's making ice again just fine! This might or might not work for you, but trying it won't cost you anything.
Aug 27, 2007 | KitchenAid Superba Architect KSCS25INSS...
My ice maker is leaking and would not stop making ice.
MAKE SURE THAT THE WATER SUPPLY SOLENOID VALVE IS NOT STUCK OPEN BY DEBRE. AS FOR THE HAIR DRIER ??? THERE IS A LIMIT T-STAT THAT PREVENTS THE ICE-CUBE MAKER HEATER WIRES OR PLATE FROM OVER HEATING. MAKE SURE TO LET THE IT COOL-OFF TO RE-SET THE SAFTY SWITCH. YOU CAN CHECK TO SEE IF SOLENOID IS ENERGIZED BY PLACING A METAL BUTTER KNIFE CLOSE TO THE TOP OF THE SOLENOID... YOU SHOULD FEEL THE MAGNETIC PULL FROM THE SOLENOID. ALWAYS MAKE SURE THAT YOU HAVE ADEQUATE WATER GOING INTO AND OUT OF THE WATER SOLENOID VALVE ... USUALLY LOCATED BEHIND THE FRIG WHERE THE ICE MAKER IS LOCATED.
Apr 21, 2007 | Whirlpool GD5SHAX Side by Side...
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
112 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
