Question about Whirlpool Refrigerators
WATER COMING OUT BOTTOM OF FRIDGE - Whirlpool Refrigerators
    Brigadier General:
  • 3,513 Answers
Please check this link bellow to troubleshoot your problem when water is coming from the bottom of fridge:-
http://www.repairclinic.com/Refrigerator-Troubleshooting#Thebottomfrontoftherefrigeratororfreezerdoor
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Posted on Sep 30, 2010
I have mold! in the drain on bottom of fridge i assume because of the water dripping down the walls all the time?
Try to put a tray under the fridge to collect the dripping before handling the mold.
Dec 07, 2015 | Liebherr Refrigerators
Leaking water on floor appears to be coming out of fridge at bottom inside. after removing vegi crisper cannnot see whereits coming from suggestions please
does it have a water line, if so make sure that is not leaking. check bottom of freezer to make no standing ice or water is on the bottom.
Nov 29, 2015 | Refrigerators
Water leaks at bottom of fridge
The same thing happened to me then I noticed ice had formed at the bottom of our fridge. It was covering a drain hole so water was leaking out the front of fridge instead of going to the drain pan or wherever the hole goes. After I chipped out the ice and cleared the hole with warm water the leak stopped. I also fixed another leak coming from bottom of fridge caused by a loose brass connection on water line going to the door.
May 25, 2014 | Hotpoint HSS25GFP Side by Side...
Whirlpool refrigerator is leaking water
If the water is pooling around the bottom of the fridge I would pull the fridge out and pull the panel of the back of the fridge and check to make sure the black plastic drain pan is in place and the white or clear plastic hose coming from the bottom of the fridge is aimed at the drain pan, if they are not then that would be why you have water pooling up under the fridge. Generally the Walter gos into the drain pan after defrost and the heat from the discharge lie of the compresser evaporates the water and it should never overflow. Hope this helps
Sep 08, 2012 | Whirlpool GB2FHDXWS (63 cu ft) Top Freezer...
Bad smell from motor
You need to remove any spoiled food from the refrigerator and clean the interiors with hot water added with baking soda. You need to clean the door seals and remove the breaker strips. Also check for unusual wet insulation.
Hope this work
Jul 28, 2010 | Amana ABB1927DE Bottom Freezer...
Trickling water noise coming from the bottom of the fridge.
It may be nothing to be concerned about. The water produced during the defrost cycle drains into a pan at the bottom of the refrigerator. This water is then evaporated by heat from the refrigerant coils.
You may be hearing this water dripping into the pan from the tubing that carries it from the inside of the refrigerator.
Oct 10, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Heavy water leak in basement under fridge
Has this fridge got an ice maker???
Because ice makers require a water supply to make ice.
This could be where your water is coming from.
Jan 19, 2009 | Sub-Zero 650 / O Bottom Freezer...
There is water leaking from the bottom of the fridge
Hi!!! It seems that your drain line in the freezer section is plugged remove the bottom tray and check for ice or water if you do the unplugg your drain line with a hair dryer..good luck..
Jan 02, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
GE Refrigerator, Model TBX22ZA
the drain hole is blocked in the bottom of the fridge. if the water is not able to drain down the hole it will overflow into the fridge base. check any holes at the inside back of the fridge.
Jun 11, 2007 | Kenmore 26.0 cu. ft. Side-By-Side...
Refrigerators Logo
301 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
