Question about GE JBS03 Electric Kitchen Range
What is the oven made of? I have a cleaner but it says not to use on aluminum. Is this stainless or aluminum?
  • GE Master
  • 43,501 Answers
Alum. is to soft to be durable in an oven...they do not use that in ovens...
heatman101
Posted on Sep 30, 2010
How can we clean the baked on food from the oven racks and rack holders? Stainless steel cleaner does not touch it.
To clean the stainless steel without marking it you can first try non-caustic oven cleaner, if you use normal oven cleaner the acid in the cleaner will etch "eat" the surface of the stainless steel
May 05, 2011 | Electrolux 30" Built-In Single Electric...
I have the porcelain coated pans and the kids burnt chilled cheese and just can't seem to get it clean now
You can use spray-on oven cleaner, such as "Easy Off" or any similar store brand. Do not use oven cleaner on Aluminum pans, pans with non-stick coatings, or pots/pans with plastic or rubber handles. Wear rubber gloves when working with oven cleaner. It is a very powerful cleaner and can burn your skin.
  1. Put the pan in your empty kitchen sink.
  2. Spray it on generously with oven cleaner.
  3. Leave it overnight, 8 hours or so.
  4. In the morning thoroughly rinse and wipe all the areas you sprayed, including the sink.
You should have a clean pan and a clean sink. Refer to the oven cleaner's label for further instructions and safety hazards. Choose the type of oven cleaner that suits your needs. In my experience, "Fume Free" oven cleaners take longer and don't work as well. Seemingly, the more noxiously fumed cleaners, ie ones containing Lye (Sodium Hydroxide), work better and faster.
This works for porcelain coated pots/pans, stainless steel, steel, glass, etc. Do not use oven cleaner on aluminum pans, pans with non-stick coatings, or pots/pans with plastic or rubberized handles.
Apr 02, 2011 | Vacuums
How to clean the oven
The inside of the oven can be cleaned with regular soap and water. Dawn works well on built up grease. if you have very stubborn stains easy off makes a low fume oven cleaner, but try hot soapy water first. the outside can be cleaned with any stainless steel cleaner or window cleaner.
Nov 20, 2010 | Dacor Epicure EO127 Stainless Steel Dual...
I have discoloration on my kitchen aid stainless steel oven top on the strip of stainless just above the controls. I have tried vinegar, baking soda and dishwashing liquid, oven cleaner(not heavy duty Easy...
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
This stuff really works!!
Aug 22, 2009 | KitchenAid Cooktops
We have a SMEG self cleaning oven however the glass door is filthy and we are seeking the best approach to clean it without damaging
Purchase 3M stainless cleaner for the stainless parts, do not use spray and wipe or similar as it removes the marking or etching indicators (temp. etc)
You can use oven cleaner on the glass, but try not to let it go on the stainless parts yet again.
Hope this helps?
Jun 21, 2009 | Smeg DO81CSS Electric Double Oven
New cooktop. spilled food how to I clean it up
I need more information. Smoothtop? Gas? Electric? Stainless steel? Smoothtop, scrape what you can off with a plastic credit card or something similar. If necessary use a razor blade. Finish cleaning with a liquit polishing top cleaner made for smooth top ranges. Regular use will leave a smooth finish that will make it easier to clean. Us only a plastic pad or other non abrasives. Regular porcelain top. clean up as best you can with a dish rag. scrape with a plastic tool. Use oven cleaner if necessary. Don't get oven cleaner on painted or aluminum items. It will remove numbers, writing etc and badly stain aluminum.
Jul 08, 2008 | Whirlpool Kitchen Ranges
Stove cleaning
The filter in the jenn air can be run through the dishwasher. clean the outside of the oven as best as you can before you start the self clean cycle. NEVER!!! use oven cleaner inside a self cleaning oven. or on the gasket. . You can use a degreaser or oven cleaner on the cooktop on any stainless steel, procelain or chrome surface. Don't get oven cleaner on painted or aluminum surfaces. Rinse off very well.
Jul 05, 2008 | Kitchen Ranges
Cleaning area around burners
Try regular oven cleaner (not the overnight kind) . This will work if there are no aluminum or painted parts. Don't do this if the instruction manuel says not to.
Jun 12, 2008 | Jenn-Air JGC9430ADS Gas Cooktop
Alum stuck in oven
what i suggest to another customer is to get some of that new easy off that's made for self cleaning ovens and soak it in that for awhile the customer never respond back so i didn't know if it worked now as far as getting i cant say only as the foil is not a warranty issue you really don't need it in a self cleaning oven
Jan 17, 2008 | LG LRE30755 Electric Kitchen Range
GE JBS03 Electric Kitchen Range Logo
80 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
