Question about GE 24 in. GLD6260LSS Stainless Steel Built-in Dishwasher
The dishwasher won't fill with water. We took the water inlet valve off and cleaned the filter screen. The dishwasher worked about 2 times and started doing the same thing. We then replaced the water inlet valve and again, the dishwasher worked a couple of times and now we're back to it not filling again. What could the problem be?
    Problem Solver:
  • 5 Answers
Check the float assembly, that will trip and stop water from coming in. May have soap or grime holding it up.
Posted on Sep 30, 2010
My dishwasher won't fill with water. and keeps running even when the door is open.
A defective switch may interfere with your dishwasher's filling ability. Yourdishwasher may not be filling with water simply because the water valve's filter screens are dirty and debris-filled. Gain access to your water inlet valve and try cleaning it out. This might be enough to solve the problem.
Dishwasher Repair Guide - Dishwasher won't fill with water..
or try this link..
dishwasher won fill with water Google Search
Oct 27, 2017 | Dishwashers
Bosch dishwasher doesn't work. water not coming
Hi Gilgol, The link below is a Bosh Dishwasher list of error codes, I believe your error code is E3....CHEERS..
http://removeandreplace.com/2015/10/09/bosch-dishwasher-error-codes-how-to-clear-what-to-check/
Bosch Dishwasher Error Code E3
Fault Condition: Not filling with water
Repair or Check: If the water supply cut-off valve on the dishwasher is completely open but the dishwasher will not fill with water then shut off the water supply and unplug the dishwasher. Remove the water fill line and check to see if the water inlet screen valve is plugged up. If so then replace the water valve. Cleaning the screen can make the issue worse so always replace if the screen is clogged. The valve can get stuck open from gunk and therefore flood or overfill.
Parts Required: Water inlet valve
Bosch Water Inlet Valve Assembly for Dishwasher
Apr 02, 2016 | Bosch Dishwashers
What is error message e15
What brand dishwasher? Model number might help too.
If it is a Bosch this might be the answer.
The E15 fault code means that the dishwasher is not receiving water through the water supply hose, or at least that what the machine thinks anyway.
E15= Check Water Inlet supply*
This can be caused by several reasons.
1. The filters in your inlet hose or inlet valve are blocked and need cleaning.
2. The inlet water supply valve is faulty and worn out, not allowing water in fast enough in relation to the set amount of time it takes to fill the machine for washing etc..
3. The water supply isnt turned on fully underneath the sink?
You will need to undo the water inlet hose from under the sink and check to see if there is a filter in that end of the hose and check to see if it needs cleaning. It will be of the wire Gauss type.
If not, then you will need to uninstall the dishwasher and pull it out from the cabinet to check the inlet valve where the inlet hose connects to at the bottom rear of the machine.
The valve itself will have a filter, where the hose attaches to. Undo the hose and visually check the filter in the valve for blockage/restrictions.
If the above brings no results, then you probably need a new inlet valve for the dishwasher.
Sep 04, 2014 | Dishwashers
Aeg favorit 40010vi dishwasher won't fill with water
I have a similar issue on oko favorit 50700. I have checked the flow from the inlet hose into a bucket and it really seems ok, so I think maybe a problem at the inlet to the machine? Plea update if you get a fix!
Mar 24, 2013 | AEG Dishwashers
Won't fill with water
Hello & Welcome to FixYa
Dishwasher not filling problem is caused by clogged inlet valve, first try to clean the inlet valve and the water line coming to the inlet valve. If the issue returns replacing the water inlet valve is recommended repair. Please get back to me if you have any other questions.
Kevin
Dec 20, 2011 | Baumatic 18 in. BFD46 Free-standing...
Maytag MDB6000AWA doesn't fill with water
I had the same problem. Check and clean the sediment screen in the "water inlet valve". If this isn't plugged it is probably the solenoid on the same valve. I replaced the water inlet valve, took apart the inside apparatus of the dishwasher and gave it a good cleaning and this fixed the problem. The valve cost me $60.00CDN delivered to my door. You can order it online for as little as $30-$40.
Mike B.
Nov 09, 2011 | Maytag 24 in. MDB6600A Jetclean II...
Hi
When the Dishwasher won't fill you'll need to check for the water inlet hose, the water inlet valve and the float switch assembly. When the water fills your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the float switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Aug 30, 2011 | Kenmore Dishwashers
Switch dishwasher on and starts up ok but when it comes to pumping water in it stops and does not do anything else.
Hello
Investigate these five areas if your dishwasher won't fill with water:
As water is filling your dishwasher, a float rises along with it. When the float reaches a predetermined level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Check your float assembly. Replace it if you need to.
The water that fills your dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with your dishwasher's filling ability.
Your dishwasher may not be filling with water simply because the water valve's filter screens are dirty and debris-filled. Gain access to your water inlet valve and try cleaning it out. This might be enough to solve the problem. You can learn how to access your water inlet valve in the replace a dishwasher water inlet valve section.
Alternatively, your water inlet valve could be defective altogether. That could be the reason your dishwasher is not filling. Test it for continuity. If it is not functioning as it should, replace it.
Your dishwasher's drain valve is regulated by a drain solenoid. If the solenoid is malfunctioning, it may not allow the drain valve to funtion properly, which in turn could be the reason your dishwasher is not filling with water. Investigate your drain valve and test the solenoid. If the solenoid is faulty, replace it.
Aug 22, 2011 | Dishwashers
Hotpoint Super Plus 7821 dishwasher isn't drawing water, please help thank you
Hello
Water Inlet Valve
Aug 03, 2011 | Dishwashers
Item: Whirlpool Ultra Dishwasher Age: 3 yrs Problem: Not enough water to effectively wash the dishes. State: When the dishwasher is started, the fill valve opens as normal. Only about 1/2 the amount of...
Larry,
The float is generally for overflow conditions and will interrupt power to the fill valve solenoid.
If you are not filling completely in the time allowed by the timer, it is most likely a flow restriction in the water supply. Barring other obvious restrictions, the fill valve has filter screens on the inlet side of the fill valve, which is generally the cause of your symptoms. Be careful if you attempt to clean the screens, as the fill valves are very sensitive to debris, and can become stuck open if sediment gets past the screen. I usually replace the fill valve to avoid future problems.
Hope this helps.
Oct 30, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
GE 24 in. GLD6260LSS Stainless Steel Built-in Dishwasher Logo
111 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
