Question about Hunter (90121) Stand (Pedestal) Fan
I just purchased this fan from Target. It doesn't turn on. I unscrewed some screws and ...there is no connection from the base to the fan. There seems to be a lot missing from the motor too. My guess is someone bought it and removed all the wiring. I love the look, the brand, and it's what I need. There are no more left at Target. How much would it cost to mail it to Hunter to get fixed?
  • 490 Answers
More than it's worth by a lot. I would go to target with the target SKU and have them find one at a different store and have it brought in for you. If it is the last one in all the world there is a reason. If you like the look, copy all its model numbers and such take a good picture of it and see if you can find one on the web. The shipping on the fan would be around 50 dollars and hunter would charge you full shop rate and parts as it is not their responsibility but Target's. If you wait too long you will have some trouble returning it, so I would choose your course of action soon. Hunter can help you find who has the model for sale if it's not one made specifically for Target. Good luck, Farmerbear at FixYa.com
Posted on Sep 30, 2010
I'm using the single serve mixer and it's stuck on the base and won't come off!
follow this steps and fix it. God bless you
  1. Unplug the blender and remove the jar. Undo the screws securing the baseplate. Separate the baseplate and attached motor collar from the base housing.
  2. To remove the switch housing, remove the decorative facing to get at the top screws. Remove the lower screws from inside the blender base.
  3. Hold the fan to keep the motor shaft from turning as you unscrew the drive stud. Remove the shield and any washers. Unscrew the fan nut to remove the fan.
  4. Disengage the strain-relief fitting from the housing. Remove the wire connector joining the power cord and the lead to the brush housing.
  5. Label and disconnect the lead wires from the switch block. Remove the motor mounting bolts and lift out the motor if necessary.
  6. To free brushes, remove the leads attached to the brush housing. Use a screwdriver to press lead terminal through the slot in housing. The brush spring may pop out (don't lose it!).
Nov 04, 2013 | Blenders
I replace the screen on my gateaway mt 6916 and cant install the video controler driver
Instructions
Prepare the laptop for disassembly. Shut down the laptop completely, then wait a few minutes before removing the battery and unplugging the AC adapter. Turn the laptop over and lay it down on a flat surface so that the battery area is facing away from you and the hard drive is located at the bottom left corner.
Remove the hard drive cover. Remove the two screws located on the left side of the hard drive cover, then lift the cover to remove it completely from the unit.
Remove the memory cover. Unscrew the eight screws holding the memory board in place; this cover is located above the Gateway product sticker.
Disconnect the Wi-Fi adaptor. Remove the Wi-Fi cover by unscrewing the single screw holding the Wi-Fi adapter in place; this is located directly above the hard drive. Remove the two cables connecting the wireless card to the adapter and snap the card out of the holder.
5
Remove the memory modules. Gateway computers typically have two memory modules located in the center of the motherboard; lift these out gently with your fingers and set them aside.
6
Release the heat sink. Unscrew the four screws around the heat sink assembly; this unit is located to the left of the ventilation fan and is surrounded by a copper base. Carefully lift the heat sink and the cooling fan off the unit and unplug the cable attaching it.
7
Remove the CD/DVD drive. Unscrew the small screw located to the left of the CD/DVD drive, then push the drive out to remove it from the laptop completely.
8
Remove all screws around the base of the laptop. You will now be left with a total of 18 screws located around the edge of the base of the laptop, and in between the stickers and hardware components in the center. Remove all of these carefully and set aside in a safe place.
9
Prepare the cover for removal. Turn the laptop up on its edge so that the back of the laptop is facing you; you will see two screws on the hinges of the computer. Unscrew these and set them aside.
10
Remove the hinge cover. Open the laptop so that the screen is laying flat; use the flathead screwdriver to pry open the hinge cover and pull it off gently with your fingers.
11
Remove the keyboard. Lift up the keyboard and reach behind it to release the cable. You will need to tug gently on the cable to unhook it from the motherboard.
12
Unhook the LCD screen from the notebook. Unplug the Wi-Fi antenna cables located on the right side of the motherboard directly under the screen, then unplug the video cable located directly under the hinge cover. Remove the pair of screws located to the left and right of the LCD screen and gently lift the LCD screen off the notebook's base unit.
13
Remove the system board. Turn the base unit over and unscrew the five screws securing the motherboard to the base. Two of these are located near the hinge cover, and two are located beneath and to the right of the hard drive unit. The fifth is located a few inches below the top right edge of the laptop.
14
Disconnect the motherboard. Lift the system board, then unhook the cable connecting it to the base unit.
Jan 10, 2013 | Gateway DX4200-09 PC Desktop
My laptop shuts down in 5-10 mins.
Instructions
Purchase a new fan for the Sony Vaio model you have by checking the owner's manual of your computer or consult the Sony website for the correct part number.
Remove the power cord from your computer and then remove the battery. Unlock the battery and slide it from the bottom of the laptop. Allow it to sit for 5-10 minutes after removing the battery.
Turn the computer with the left side facing toward you and locate the only screw found on the left side and remove it. Remove the panel by sliding it toward you and set it aside.
Slide the panel covering the power buttons to the left and detach the ribbon cable connecting it to the motherboard and then remove the panel gently.
5
Remove the keyboard by unscrewing the small screw directly above the keyboard. Once the screw is removed, gently lift the keyboard and detach the small cord connecting it to the motherboard. Set the keyboard aside.
6
Remove the plate under the keyboard by unscrewing the three screws and lift the plate out.
7
Disconnect the cooler fan from the motherboard by pressing the connectors in and removing them from the sockets. Once the connections have been removed, lift the cooling fan up out of the computer.
8
Replace the old fan with the new one you purchased and attach the two connectors. Reinstall the metal plate back on top of the fan and attach the screws.
Jan 10, 2013 | Dell Inspiron 1545 Notebook
How do i remove back and reinstall fan?
Welcome to Fixya
Here's the procedure:
1. Shutdown the laptop and remove the AC adapter. Disconnect any devices, such as a printer or external DVD-ROM or drive, that are attached to the laptop
2. Remove the laptop battery. Turn the laptop upside down, slide the battery release latch and then pull the battery out of the bay.
3. Unscrew the hard drive cover. Grab the hard drive tab and shift the hard drive to the left to unplug it. Lift the hard drive out of the bay.
4. Unscrew and remove the PCI memory cover, the optical drive cover, and switch cover.
5. Unscrew the two screws that hold the keyboard to the base, these are located in the middle of the rear panel. Flip the laptop over so it is right side up, open and remove the keyboard by using the keyboard release switches located above the keyboard. Next, unplug the Toshiba Qosmio E15-AV101 Fan cable.
6. Close the laptop and turn it over so it is bottom up. Unscrew the display assembly screws located under the laptop screen hinges. Turn the laptop over so it is right side up. Open the laptop and unplug the display assembly cable and disconnect the wireless antenna from the display assembly. Unscrew the display assembly from the laptop base and remove.
7. Unplug the mouse pad cable. Turn the laptop over so the bottom side is up and unscrew the base screws which are located along all four sides of the laptop base. Gently remove the base of the laptop.
8. Turn the laptop over so it is right side up. Unplug the fan cable from the circuit board. Unscrew the screws holding the Toshiba Qosmio E15-AV101 CPU fan assembly to the laptop. Lift the fan assembly out of the laptop.
9. Insert the new Toshiba Qosmio E15-AV101 CPU fan assembly into the lap top. Screw the assembly unit to the lap top and plug the Toshiba Qosmio E15-AV101 CPU cooling fan cable into the circuit board.
10. Reassemble the laptop by repeating the previous steps in reverse order.
Thank you for using Fixya!
May 10, 2011 | Toshiba QOSMIO E15-AV101 Notebook
Where can I find a schematic or instructions to open my toshiba satellite u205-s5067 laptop. I want to clean/replace my fan.
Taking apart a laptop to change the fan is a relatively simple task. Just keep track of where all the screws go and follow these steps:
5. Unscrew the two screws that hold the keyboard to the base, these are located in the middle of the rear panel. Flip the laptop over so it is right side up, open and remove the keyboard by using the keyboard release switches located above the keyboard. Next, unplug the Toshiba Satellite U205-S5067 Fan cable.
8. Turn the laptop over so it is right side up. Unplug the fan cable from the circuit board. Unscrew the screws holding the Toshiba Satellite U205-S5067 CPU fan assembly to the laptop. Lift the fan assembly out of the laptop.
9. Insert the new Toshiba Satellite U205-S5067 CPU fan assembly into the lap top. Screw the assembly unit to the lap top and plug the Toshiba Satellite U205-S5067 CPU cooling fan cable into the circuit board.
Hope this helps.
Apr 05, 2011 | Computers & Internet
Misassembled black 18" Holmes stand fan with remote (HSF1809R)
Hello cdelune. Glad to see you fixed the problem but Im having the exact same issue with the fan! Not sure what to do with the pole with the frayed ends and how to connect it with the plastic falanges. Ive been at it a while now so do you think you could help me out and post exactly what you did to fix it? Thanks.
Jul 25, 2010 | Holmes Products Dryers
Fan top back of unit is on and off continuely and making noise as in a failing bearing. I have removed the retaining screws, however the wiring has no disconnect to permit removal from the fan. Otherwise...
Unplug unit. Find name plate info on back of fan. It may be a 6 watt stamped CW. The rotation on small watt motors is based on looking at it from the "lead" end or rear of motor. You will have to cut the cord, WHEN UNIT IS UNPLUGGED. A new fan motor can be connected to the old cord with wire nuts. Install old blade on new fan motor.
Nov 02, 2009 | Danby DWC283BLS Wine Cooler
Robot coupe r 301 ultra
Remove the base the screws are under the rubber feet,on top of the machine there are three screw caps remove these with a bradel, unscrew screws with large torx screw driver, remove spindle anti clockwise by locking out fan at base. for all Robot coupe parts go to http://www.catering-machines.com/
Jun 06, 2008 | Food Processors
Request for diagram of this piece of equipment
well what you do is: find the circuit breaker to the lights that control the particular fan and shut it off! then at the ceiling if your fan is hanging by a rod then you can unscrew the 4 screws at the base of the fan and let the base drop to the fan and you should see the wires blue red or black and white there the black wire that is connected to the small wires from the fan goes down to you switch. I hope this helps you.
For caution: make sure to turn off the breaker so you do not shock yourself.
May 28, 2008 | Hampton Bay 04345 Cruiser Ceiling Fan
Hunter (90121) Stand (Pedestal) Fan Logo
113 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
