Emerson VCR/DVD--eating the tape and ejecting tape, but not playing the tape
    President:
  • 2,777 Answers
The most common cause is dirty, old, deteriorated rubber parts - particularly the idler tire - preventing the tape from being fully wound back into the cassette.
I personally would just get rid of that player if it were me, but if you really want to try, you can clean it out...
Things to clean: 1. Capstan and pinch roller. These collect a lot of crud mostly oxide which flakes off of (old rental) tapes. Use as many Q-tips (wet but not dripping with alcohol) as necessary to remove all foreign matter from the capstan (the shiny shaft that pulls the tape through the VCR for play and record). Just don't get impatient and use something sharp - the crud will come off with the Q-tips and maybe some help from a fingernail. Clean the pinch roller (presses against the capstan in Play, Record, and Search mode CUE and REVIEW) and until no more black stuff comes off. Use as many Q-tips as necessary until no more black gunk collects on Q-tip. If the pinch roller is still hard, shiny or cracked, it will probably need replacement. Many are available for about $6 from the sources listed at the end of this document. It is sometimes possible to put the pinch roller in an electric drill, drill press, or lathe, and carefully file off the hard shiny dried out rubber surface layer, but only use a last resort - and this fix is probably temporary at best. 2. Various guideposts including the roller guides (the white rollers on metal posts which are near the video head drum when in play or record mode). When in FF or REW, or with no tape present, these move on tracks to a position toward the front of the VCR. Note that the roller guides with the white rollers and tilted metal posts will be fairly loose when in the unloaded position (but you should not be able to lift them off the tracks). When actually playing or recording a tape, they will be snug against the stoppers at the end of the tracks. 3. Idler tire (idler swings between reels and transfers motor power to reels - clean until no more black stuff comes off. A dirty or worn idler tire is probably the single most common VCR problem. If the idler tire appears cracked, glazed, or dried out, it will need to be replaced. About $.50-$1.00. As a temporary measure, you can usually turn the tire inside-out and replace it. The protected inner (now outer) surface will grip well enough to restore functionality until a replacement tire arrives - and verify the diagnosis as to the cause of your problem. Also, the idler assembly includes a slip clutch. If this weakens, the idler may not have enough force to press on the reel table edges. If it becomes too tight, there may be audio, video, or crickled tape problems and/or excess wear of the idler tire. When in doubt, the entire idler assembly is often available as a replacement part. They can often be disassembled and adjusted if necessary. 4. Reel table edges - surface on the reel tables where the idler contacts. 5. Audio/control head (right side) and full erase head, (left side). Q-tips and alcohol are ok for these. 6. Anything else that the tape contacts on its exciting journey through your machine. 7. Rubber belts. Access to some of these will probably require the removal of the bottom cover. After noting where each belt goes, remove them individually (if possible) and clean with alcohol and Q-tips or lint free cloth. Dry quickly to avoid degrading the rubber from contact with the alcohol. If a belt is trapped by some assembly and not easy to remove, use the Q-tip on the belt and/or pulley in place. However, if it is stretched, flabby, or damaged, you will need to figure out how to free it. Make sure that there are no twists when a square cut belt or replacement is installed on its pulleys. On some models, you may need to unscrew circuit board(s) blocking access to either the top or bottom of the tape transport. Make notes of what went where - particularly different types of screws and routing of wires. Any belts that appear loose, flabby or do not return instantly to their relaxed size when stretched by 25% or so will need to be replaced and may be the cause of your problems. Belts cost about $.30-$2.00 and complete replacement belt kits are often available by model for $3.-$12. Meanwhile, the belts will function better once they are cleaned, maybe just enough to get by until your replacements arrive.
Posted on Sep 30, 2010
Cassette tap in my vcr get eating
The unit has a bad transport mechanism--it among other things moves the tape in play etc and when ejected winds the tape back into the cassette.
Could be bad belt/s or a bad idler made of rubber that does this type of function.
If a old unit may be better to replace if you can find one new.
Apr 16, 2012 | Magnavox ZV427MG9 DVD Recorder VCR
VCR won't eject tape or play & powers off
It sounds as though it's jammed. If you're mechanically inclined you can unplug the unit, take the cover off, and manually eject it. Just look for the motor that drives the load basket and manually spin the shaft. The guide-posts should retract towards the tape and the basket will then lift and eject. Just be aware that whatever bit of tape that's out of the cassette won't spool back in. You will have to do that bu hand once it's out.
When you're done, plug it back in and let it cycle then put an old cheap tape in and see if it works. If not, take it in for repair.
Nov 08, 2007 | Emerson EWR20V4 DVD Recorder/VCR
VCR KEEPS BEING EJECTED
From the description this a tape end sensor problem, or the take up reel is not working.
Mar 14, 2012 | Emerson EWR20V4 DVD Recorder/VCR
Power goes off when a cassette is inserted. Tried cleaning heads but it won't even run that. When power is turned back on the cassette is immediately ejected.
Good day!!!
Most common problems
  • VCR refuses to FF or REW and shuts off.
  • VCR shuts off entering PLAY or REC or at random during PLAY or REC.
  • VCR eats tapes.
  • VCR doesn't accept tapes or ejects them without cause.
  • Sound is wavery, fluctuating, or muddy.
The cause for all of these is very often a bad idler tire or other dirty, worn, or tired rubber parts
Sep 12, 2011 | Philips Magnavox DVD/VCR Dual Player
TV DVD VCR combo eats tapes and now won't eject DVD's
Its shot, time to get a new one. dvd players are now only $20
do you have a newer lcd tv. Id say look into getting an upconverter,itll play your dvds at 1080 :) better picture.
Feb 27, 2009 | Philips Magnavox MWD200G DVD Player
VCR problem in EWR2OV4
When a VCR eats a tape, it can be cause by a couple things.
1. There is a rubber wheel called a "pincher wheel" that compresses the tape against the "capstan". The capstan is a shiny metal spindle. The pincher wheel can become worn and/or dirty from the oxide coating off of the tape. You can try cleaning the pincher wheel and capstan with alcohol or try using a re-grip solution on the pincher wheel. Last thing to do is replace the pincher wheel. Look to see that the pincher wheel is doing its job by pulling the tape through.
2. There is a small tire wheel called an idler tire. This tire pivots between the sending and pickup reels of the player. Its also used during fast forward & rewind as well as play. If the tire is worn, the tape won't be wound up as fast on the take-up reel as the sending reel during play. This means more tape is coming out than can be wound up. You can try using a re-grip solution on the idler tire or replace it.
Let me know if you need more information as to where to purchase these parts.
- Jim
Jan 29, 2008 | Emerson EWR20V4 DVD Recorder/VCR
VCR stops, ejects, eats tapes
clean the heads and retime the gears.
Nov 24, 2007 | Symphonic WF802
Vcr eating and/or ejects tape
Tape heads should be cleaned first and gears lubricated. This job can be done at home if you purchase lithium grease and are very careful not to get it on the heads or spools. Greasing should only be done if you are confident in opening it up. Otherwise, seek a cheap professional.
Oct 26, 2007 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Eating tapes and then refuses to work
try opening the case. then, using your fingers, roll the gear that drives the tape eject mechanism until a full tape eject limit is reached. power up and try
Nov 16, 2006 | Symphonic SL260A S-VHS VCR
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
Electro Med Services...
