Question about Vizio L42HDTV 42 in. LCD Television
I have a vizio 42L hdtv10A at first it would turn on for a second then the picture would go out and I would have only sound. When I turned it off and let it sit till I hear a click then tirn it on I would get a picture plus sound. Then the some of side buttons quit working. Now nothing, no picture or sound. It is out of warranty and I would like to give a shot at fixing it myself since it would cost more then its worth to send to to a repair man. I looked online about a f3 fuse but my doesn't have a f3, I did find f1 and f2. Also where is a filler cap located?
BigLou1958
  • 104 Answers
SOURCE: Vizio L32 HDTV - Blew Out, No Power
Yes, I do in home warranty work on vizeo, it sounds like you need a power board and perhaps a main board. The power board is what pooped.
Posted on Nov 15, 2008
  • 4 Answers
SOURCE: only vizio light come on then nothing. have to unplug to turn off
there a problem on power side.. chage the ic and the resistor going to ic and check also the signal diode.
Posted on Jan 03, 2009
SOURCE: only vizio light on
RJW34 I have a 37" Viizio LCD that has a similar problem. I power it up and I get a lit screen but it's blank. No controls work except power on and off.
Posted on Feb 20, 2009
  • 139 Answers
SOURCE: Vizio VW32L HDTV10A stopped responding with Vizio
Change the batteries in your remote. If your cat was laying on a button it could have drained them.
Here's tip - you can use your camera on your cell phone to see the IR signal coming out of your remote. Point the remote at your cam and press "On" or any button. You should see a bright flash with every key stroke.
Posted on Mar 06, 2009
  • 111 Answers
SOURCE: I have a mfg date 2007 Vizio VW37L HDTV10A turned
This can happen. are the lights on? if not, it most likely id the power source inside the tv itself. make sure your wall outlets are working properly as well, but if they are, then you want to get you tv fixed. this can be a relatively low cost repair, but shop around
Posted on May 03, 2010
Snow on screen with no picture.loud noise on audio
42" Vizio TV flickering strobing easy way to repair VW42L ...
? 2:49
https://www.youtube.com/watch?v=Qba7_YHnXwM
Dec 2, 2013 - Uploaded by ozzysslayer
42" Vizio TV flickering strobing easy way to repair VW42L HDTV10A LCD TV ... EASY How to Fix Samsung LCD TV Flashing Flickering Screen!Missing: vp422hdtv10a ‎snow
Vizio Replacement Boards - ecoustics.com
www.ecoustics.com > ... > Plasma & LCD TV Forum
Apr 15, 2009 - I have a vizio p42hdtv10A that just went into a black screen. .... I have a Vizio VP422 HDTV10A that will not stay on or show a picture. I removed ... Vizio vp422 hdtv10a
Dec 20, 2011
May 13, 2011
More results from www.ecoustics.com
Dec 30, 2015 | Vizio VP422HDTV10A 42 inch 720p LCD HDTV
Vizio vx37l hdtv10a
If recently bought, take it back as a default.good luck..
Dec 07, 2013 | Televison & Video
No picture no sound on a Vizio HDTV10A. The green light comes on then turns to amber after a couple of seconds
your Main board went bad, common issue with these units. Need to be replaced, in tv land it called main board in computer world mother board. your unit has only two boards power board and that is good cause you get a amber to green to amber led. good luck Vizio field tech
Feb 01, 2013 | Vizio 32" l32 hdtv 10a high definition...
Have a vizio vx 42l on the bench. amber light only no power up have my standby 5vdc and my 3.3vdc power button is sending a high pulse to the main mod but i dont get pson to the power supply mod suspect...
This is your mainboard needing replaced! Simple as that!
The main sends the pson signal and without it...you have a dead tv.
Please rate if this helped :)
Mar 10, 2011 | Vizio 42 in. LCD TV
I have a 42 inch Gallevia model GV 42L. When TV is initially turned on blue screen comes up for about 2 seconds, it then goes black and a screeching noise comes through both speakers on the TV. No...
The power source has failed - the sound is the source that autooscillates because even its protections have been damaged and are no longer capable of safely shut it down.
It's a big failure so call a repairman, ther's nothing more you can do.
Aug 31, 2010 | Vizio SV470XVT 47 in. LCD TV
We have sound but no picture
reset the unit by shortening the battery side...or you you just reset the unit by turning it off and after 10 to 15 seconds, turn it on again
Nov 13, 2009 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Vizio L42HDTV 42 in. LCD Television Logo
85 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
