Question about Maytag Dishwashers
Mod# mdb7601aww.... When I press cycle key, say heavy duty, then close door the 2H light flashes. I press the start button and the unit will not start. I have shut it down electricly and get the same results. what can be the problem? The front panel with the start/delay buttons or the inside control panel? I like to figure this on out the first time because each of those parts are $100+.
Macmarkus
  • 2605 Answers
SOURCE: stays on 2H when turning on
Hi welcome to Fixya. You're right what you're describing is not delay start, but rather a problem with one of the heating component's and most likely the heater relay on the electronic control. The wash cycle has exceeded two hours without a temperature increase of the water and therefore the control "thinks" something is wrong. Whether there is or isn't remains to be seen. Likely if you let the unit operate from that point of displaying "2H" it will run and run for several hours and not heat the water. You can confirm this by pulling out the control and visually inspecting the printed circuit side of the control. Look for a burnt solder on the opposite side of the largest relay ( black or orange retangular box ). That will confirm the heater relay is faulty and the control either needs to be replaced or repaired if you are capable of resoldering the board. Let me know what you find and I'll try and assist you further if you require any. Thanks for visiting "fixya" today and good luck moving forward. macmarkus :)
Posted on Jun 27, 2010
VOTIT
  • 2071 Answers
SOURCE: whirlpool dish washer du931scgb1
This is the symptom of defected timer motor is need to replaced..
Hope this may help;
Regards,
VOTIT
Posted on Aug 01, 2008
RepairClinic
  • 32 Answers
SOURCE: Frigidaire PLD4460REC Dishwasher will not start
This is very likely due to a bad main electronic control board but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance. If possible use the meter and the wiring diagram to check input/output voltages looking for discrepancies between the diagram and the actual meter readings.
Go here for Frigidaire Dishwasher Parts: http://www.repairclinic.com/Frigidaire-Dishwasher-Parts
www.RepairClinic.com
Posted on Feb 03, 2009
SOURCE: I have an electrolux edw5505eps dishwasher. The
check out my thread on a similar issue. If your power button doesn't light and delay button does not light? Is the LCD screen display anything? check out my post several really good check lists.
Posted on Nov 26, 2009
SOURCE: Control panel lights but won't start
the front control panel fries out.. We had to have ours replaced after 7 months ... after that was replaced it only lasted 2 months... WE ARE VERY disappointed and will be calling once again tomorrow. The dishwasher is not even a year old yet!
Posted on Feb 28, 2010
Cae2743bq will not turn on all lights on and lid lock is lit up
Try this, worked for me! :)
New WHIRLPOOL Top Load Washer
Model #'s CAE2743BQ, CAE2763BQ
Cycle Selector Knob key dance: [CCW=Counter Clockwise and CW = Clockwise]
Start On "NORMAL"
1 step CCW (Left)
2 steps CW (Right, Right)
1 step CCW (Left)
1 step CW (Right)
Stay on "HEAVY DUTY"
(If unsuccessful LEDs will not flash, and you must return the selector to the Normal Cycle position and
wait 4-5 seconds before retrying. )
If you are successful in the process, all LEDs will be flashing
Toggle between HEAVY DUTY and NORMAL until ONLY the RINSE light is on, then press the
START button for about 30 seconds. Machine will then enter CALIBRATION mode for about 2 - 4
minutes. DO NOT RAISE THE LID
Sep 01, 2013 | Whirlpool Washing Machines
I have filled dishwasher selected temperature and the start light is flashing but nothing happens I think the m/c type is 7197
The Start/Resume light is flashing
This flashing light indicates that your cycle or start-up was interrupted.
Possible causes: The door opened during the cycle, or the power was interrupted.
To resume operation: Make sure the door is closed, and press Start/Resume.
The Clean light is flashing
You should call for service if the Clean light is flashing and the machine is inoperable. It is normal if the Clean light stays on after the cycle is complete. The Clean light is an indication that the dishwasher has been run and that the dishes inside it are clean. Once the door is opened after the cycle is complete, the light will shut off.
The lights are rapidly flashing
Any key that gets stuck will rapidly flash. Press the key a few times in order to release it or press Cancel.
The Rinse Only light is rapidly flashing
If multiple keys are stuck, the Rinse Only light will flash. Press each key, one at a time, to release the stuck keys, or press cancel.
Jun 28, 2011 | Dishwashers
Blinking lights, not washing
Usually blinking lights are indicating bad touch panel buttons. Remove kick plate, (black panel under door) and find service instructions there. It will tell you how to test button panel, as well as any codes flashing. Also will tell you hot to try a reset.
Jul 21, 2010 | KitchenAid Dishwashers
My frigidaire dishwasher model #fghd2433kf1
It is in a delay wash mode.
Disconnect power for 60 seconds.
Re-connect power.
Press the Cancel button.
Press the regular wash cycle and start the dw.
Jul 17, 2010 | Frigidaire Dishwashers
Mod #gu2500xtpb1 clean light flashes 7 times
Hi
Thanks for using FixYa. If the clean light flashes 7 times, pauses, then repeats--
When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence--
-high temp wash
-heated dry
-high temp wash
-heated dry
All the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes). You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 14, 2009 | Whirlpool 24 in. ADG7540 Built-in...
Wash cycle stuck
You can attempt to unplug the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). This is the main computer for the washer. Sometimes resetting it is all that is required to correct momentary program glitches. If the problem reoccurs following a CCU reset, then you have a legitimate problem. Let me know if you still experience problems. I hope this helps you.
Jul 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Touchpad--No Response
The "2H" is an error code indicating the control panel needs to be replaced.
May 08, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
General Electric Heavy Duty Dryer willnot start when start button
WARNING: High Voltage may bzzt you... careful.
Your dryer thinks that it is at the end of a dry cycle.
First thing to do is disconect the dryer from the 220v mains and let it sit for about 10 min.
then, spin the timer four or five times around and then stop it at a TIMED dry cycle, not an automatic cycle. (example: 60 minutes).
Plug unit back into the wall.
SLAM door on unit and press button again...
Mar 12, 2009 | Dryers
Whirlpool gold start button flashing dishwasher won't start
press sani and heat back and fourth then after all lights light close door and hit start then wait about 3 minutes. worked for me
Oct 12, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
24 people viewed this question
Top Maytag Dishwashers Experts
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
