Question about Gateway (60.44K08.001) Laptop Heatsink
My gateway mt3707 keeps overheating and shutting down. the problem has been on going for a year now. i don't understand. i only have 30minutes to an hour before it happens. i don't have the money for a new computer. i hope you can help me fix this problem. thank you.
  • Gateway Master
  • 27,725 Answers
clean your computer of dust using a fine air blower from a compressor specifically around your central processing unit making sure there is no moisture in the air line
as dust will cause a lot of static which will make a computer overheat and cause lots of problems
hope this helps
Posted on Sep 30, 2010
Gateway laptop keeps shutting down
If there are no apparent software failure symptoms that are causing this, my best guess would be an overheating shutdown. Many laptops will get clogged with dirt because their intake fans are on the bottom and many users place them on laps, floors, and surfaces that allow dust and dirt to be sucked in easily. These clog up the heatsink that cools the processor. The unit has safeguards that shut down the unit if the processor gets too hot. Many units can be easily cleaned, but many others require a complicated tear-down to do this.
Sep 16, 2014 | Gateway Computers & Internet
Computer keeps shutting itself down
Make sure it is in a well ventilated area that does not restrict airflow. It might be overheating or the fan on the CPU is going.
Dec 08, 2010 | Gateway 300 C PC Desktop
I have a gateway MT3707 pc notebook. It randomly freezes (no blue screen) & I have to hold the power button down to shut down & reboot. Is this a driver issue or hardware failure... I'm thinking...
This could be a sign that your laptop is overheating. If you touch the laptop while it is running & you find it too hot, make sure that the fan is running properly & that the air ways are not blocked.
You can blow compressed air into the cooling vents of the fan. If you notice clouds of dust coming out, then it might be a good idea to disassemble the laptop, clean the fan & air ways, & reassemble it back. If the fan has failed & is no longer running, it might need to be replaced.
If none of this solves the problem, or is not the case, then you might have a bad motherboard.
Oct 13, 2010 | Gateway MT3705 Notebook
My gateway MT3707 touchpad is not working. how can i fix it?
Hi Evilryu,
Please check with the following link and check by changing the settings.http://support.gateway.com/s/Mobile/2007/Apache/1014142Rivr5.shtml
May 31, 2010 | Gateway (7000864) Keyboard
Laptop keeps shutting off by itself
When you encounter about this issue this is overheating problem maybe the CPU fan is not spinning and faulty already, you need to check the CPU fan and replace a new one.
Computers may not be smarter than people, but if they’re designed properly, they will shut themselves down before overheating to the extent that they do themselves damage. If the smart person keeps turning the notebook back on and figures out a way to foil the protection, the laptop is probably doomed.
Once a laptop shuts down for thermal event protection, it may refuse to power back up for a fixed period of time, five or ten minutes, or it may begin to boot and shut down immediately as soon as it boots to the point that it can figure out that its too hot.
The over-temperature protection is generally a BIOS rather than an operating system function, so one sign of an overheated laptop is one that shuts itself down while you’re using it and then refuses to boot as far as the operating system unless you leave it alone for an hour or so to cool down.
Unless you’ve been working in a very unfriendly environment, high temperatures, direct sunlight, etc, you should take even a single overheating shutdown as a warning to back up your data at the first opportunity and to give the cooling system a serious cleaning.
Oct 08, 2009 | Gateway (60.44K08.001) Laptop Heatsink
Need Power Button Board Part Number
You can contact with Mundo corp, gateway products will be available phone number:- 1888 278 7500
Sep 18, 2009 | Gateway MT3705 Notebook
My Samsung Home theatre shuts down automatically after working for around 30minutes. After 15minutes if I switch on works for 30minutes & shuts down again. When shutting down there is a disply PROTECTION.
sorry to telll you this mate, but i bought a samsung ht-tz 312 at
chrismas and that had the same problem,
only mine would switch its self off after about five mins
i took mine back and they swaped it saying it was a design fault
ps mine did this from new sjr2009@hotmail.co.uk
Apr 29, 2009 | Samsung HT-Z310T Theater System
Gateway mt3707
the inverter or backlight is on its way out, it won't bother the operating system but you can see nothing, with most inverters its the coil that goes which is fairly inexpensive to fix, if it is the inverter, thats a lot more expensive, what you can do for time being is plug an exteral monitor into the laptop so you use it.
hope this helps
regards
Nov 04, 2008 | Gateway MT3705 Notebook
Overhaeting
open the case, clean the fans and remove all dust from the comp. Also if u have oil the fans (special electonics oil)
Jan 27, 2008 | Gateway 7320GZ Notebook
Computers & Internet Logo
529 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
