Question about Frigidaire GLEQ332A Electric Dryer
Dryer spins but no heat how do i fix that - Frigidaire GLEQ332A Electric Dryer
  • Frigidaire Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Sep 30, 2010
Samsung elec dryer, Model dv5451aew xaa 01. Drum not spinning. Belt ok. Dr Sw ok. Changed both fuses on heating element. Nothing.
Samsung dryer won't spin, belt is fine - Fixya
www.fixya.com/support/t8946132-samsung_dryer_won_39_t_spin_belt
Apr 14, 2011 - Question about Samsung DV218AEW Electric Dryer. 2 Answers ....Samsung dv410aer/xaa motor hums but drum will not spin. Mar 21, 2014 ...
How to Fix a Samsung Dryer: the Drum Won't Spin
www.ehow.com > Home
From time to time a dryer's drum can fail either by jamming up, a technical error ...Support US Samsung: The Dryer Drum Does Not Spin · Repair2000: How to .
Oct 16, 2015 | Samsung Dryers
Dryer is on and spins but does'nt heat up, what could the problem be?
probably the fuse in back of the machine, I had the same problem and that was the fix, easy to do.
Nov 15, 2011 | Dryers
Whirlpool imperial series dryer heats not spinning
This problem is almost always a broken belt. Yes you can do it yourself.
Go to repairclinic. com and put in your model number for the exploded view of your dryer. Locate the belt part number and belt orientation.
Jan 03, 2010 | Whirlpool Dryers
Whirlpool Dryer, Heats up, but will not spin.
Thermal fuse , is the small white plastic piece on the blower box . That , keeps the dryer from running . Thermal cut-off , is the small thermostat on the burner (element) box , which would keep the dryer from heating .
Jul 31, 2009 | Whirlpool LER5636P Electric Dryer
Inglis dryer-spinning,not heating,Inglis washer not spinning well
Your heating element is going out. Mine did this a few months ago. It is an easy fix. Look up the part online.
Apr 13, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Can you help me fix my LG dryer won't heat
either the heating element is goin out or your limit switches are going bad it has to be one or the other since they control the heat
Jan 24, 2009 | Maytag SDE2606 Electric Dryer
My kenmore dryer works, but the heat doesnt. How do i fix it?
your heat sensor went out its about a 9 dollar part to replace
Dec 22, 2008 | Kenmore 63942 Dryer
How old is the dryer? The heating element is probably no good.
It's possible to fix it yourself. Make sure it's unplugged before you start. You might want to check a parts store, or online to see what the heating element would cost. when this goes bad, the dryer will still spin, and the heat stops instantly. It's a little tricky taking the panels off, but there's not too much to a dryer. An electric motor that powers a belt to make it spin, the heating element, metal sides, top and bottom. Good Luck! Countrycurt0
Jul 25, 2008 | Whirlpool LER5636P Electric Dryer
Kenmore stackable
Dryer probably element or thermostat, washer sounds like a suspension arm collapsed. Price up the parts & then decide if its worth it! Regards
Apr 09, 2007 | Kenmore 98702 Stacked Washer/Dryer
Frigidaire GLEQ332A Electric Dryer Logo
55 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
