Question about Emerson Televison & Video
I have an Emerson 37 inch flat screen LCD. It stopped working like its not getting any power, I have had it for a little over a year.
freetek
  • 5568 Answers
SOURCE: Emerson flat screen tv with red stripe
The pixels on your screen are controlled by a matrix composed of switches that turn off and on to produce light.
They are located vertically and horizontally, row-wise and must function together to produce everything from black (everything turned on so no light, or very little, can escape) to layers that represent the three colors that are used alone or in combination to produce the millions of possible shades of each.
One of the switches that controls one of the vertical columns has failed and has turned on the entire column that allows red to display.
The problem switch (a semiconductor combined with many) is permanently turned on, probably part of the screen assembly itself, and was placed with others by robots.
The pin spacing on these 'chips' is very small and often makes the assembly unrepairable.
While LCD panels have fallen hugely in price, you may be looking at a parts cost (labor is probably not too bad) that may make you decide to replace the set.
Unfortunately, the once-proud Emerson name has sadly been degraded and there is a lot of their electronics available from companies that specialize in 'refurbished' products, an indication that they have a large failure rate.
Posted on Jul 07, 2008
  • 458 Answers
SOURCE: 37 inch LG LCD won't turn on due to power failure
Power failures can cause all types of problems, have you firstly checked the fuse in the mains plug? If that is ok then it may have blown an internal fuse in the power supply board, these are there to protect the rest of the circuit from power surges.
Posted on Mar 24, 2009
dsacco86
  • 1077 Answers
SOURCE: Emerson LC320EM82 S LCD TV I purchased this TV a
Your not alone with this problem.
I had to fix mine. The warranty is less than impressive.
The trouble is going to be the Power Supply/Backlight Inverter board.
This is the picture of yours:
11e1946.jpg This is board # BA71F0F01042. Replacement boards are hard to come by.
Fixing the board like I did seem to be the only option. If you need info on fixing it, let me know.
Posted on Jun 18, 2009
nicknovikov
  • 100 Answers
SOURCE: vertical green line on my emerson 22 inch lcd flat
looks like LCD drive board is bad.or panel itself...
Posted on Jul 13, 2009
SpideRaY
  • 687 Answers
SOURCE: need a romote code for HRS URC-383 for my emerson
If you are using Sky Remote then you can try to use these codes 0742, 0205 or 0206 for you Emerson TV which will work on all versions of the handset.
these are usually generic codes and may well work on the HRS URC-383 remote as well
Posted on Oct 10, 2009
My emerson 32 inch tv just shUT off in the middle of a movie. Now has no indicator lights. I tried to unplug it,checked breaker,changed outlet. ..nothing
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
https://www.youtube.com/watch?v=TR2iWN6b-LY LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Apr 18, 2015 | Emerson Televison & Video
I have a 50 inch Emerson tv model number LF501EM4F had a severe storm came through and now the TV does not work. I believe it's due to a lightning strike. Can it be repaired
- Flickering screen
- Dim screen
- Slow start
Black line through middle of emerson led tv screen
Sounds like panel fault. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Screen-shots to defective LCD panel are given. You can compare it to that of your TVs'.
Apr 23, 2014 | Emerson Televison & Video
Emerson LC320EM82 S LCD TV I purchased this TV a year and 3 weeks ago. It suddenly stopped powering on. When I turn it on the screen comes on for half a second with 3-4 inch white lines across middle of...
Jun 18, 2009 | Emerson LC320EM8 32 in. LCD TV
Remote control code for 32 inch lcd EMERSON TV
I succeeded is using the DirectTV remote control for the Emerson 42" plasma TV, by using a Samsung code. On my TV, was 10060. If this one does not work, there are a bunch of others that might work. Good luck
Feb 18, 2009 | Emerson Televison & Video
Lc320em82 emerson tv
I've had the same problem with mine. Only had it for 3 months and the warranty sucks. I found out that the inverter transformer goes bad on these LCD TVs. It takes 6 of those on my power inverter board to power my 32' screen. After replacing the one bad inverter transformer, it's working again. There should be a recall for this junk part.
Jan 01, 2009 | Emerson EWL3706 37 in. LCD Television
My emerson tv standby light is on the power light flashes twice
Mine stayed in stanby mode and all I had to do was to switch the plug to a different outlet. The power strip it was on wasn't providing enough power. It worked fine for a month before I had a problem.
Dec 04, 2008 | Emerson EWL3706 37 in. LCD Television
Emerson 32 inch lcd
i have your answer!!!!!!!!!!!!!!!!
use the PRODUCT WARRANTY call emerson and have it sent back, then your like oh wow it works like new( and it will be a new one) yay thank you so much guy on the net for telling me about the PRODUCT WARRANTY
Oct 21, 2008 | Emerson EWL3706 37 in. LCD Television
Televison & Video Logo
49 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
