Question about Mitsubishi WS-55513 55" Rear Projection HDTV
I have a 73" the colors are showing blurry what do i need to do fix this problem
    Guru:
  • 417 Answers
Rear Projection tv's pictures are made by Projection of light which is produced from a set of bulbs in the base of the unit that shine up on to the screen,bit like @ the cinima.
these get dirt & dust on them which makes the picture go dull or blurry,not sure about your model,but if you get the manual it will tell you how to get to these bulbs & clean them.
Posted on Sep 30, 2010
Yea i have a gateway 450sx4 laptop and when i turn it on it stays black for a while and when the screen finally turns on it blurry and its different colors and it just shows lines how can i fix this?
It's likely that your screen is "fried" (faulty) ... try to connect your laptop to an external VGA monitor, and see if the screen shows up (on the external monitor) properly. You may have to toggle the output display (device) from computer screen to external monitor ..using Fn+F3.
If it displays on your external monitor properly, it means your laptop screen is no good. You can replace the laptop screen, or just continue to use the external monitor.
If it does the same (blurry & different color, etc.) on your external monitor, then, your video card/module on your laptop is bad. This usually happens less often.
Aug 11, 2010 | Gateway 450SX4 Notebook
Machine showing on display 73
73 pc connected in on monitor through device and u select this pc and show the display,
Apr 29, 2010 | Brother DCP 165C Compact Color Inkjet...
Blurry picture
Sounds like convergence failure. (Colored shadows of images.)
Apr 13, 2010 | Televison & Video
Blurry after Installing Colro Wheel?
Hi,since you are getting the new silver air pressure version you will need to put an jumper to the dmd board,why because gold version spins different than sliver and that will produce the tv to have color discoloration or bluryness.Good luck and God bless you!
Oct 06, 2009 | Samsung HLR5064W DLP Projection TV
Blurry and colors are seperated red green white
if you are viewing from a projection tv, chances are you have to go thru the menu of the tv to 'picture tuning'. here it gives you different things that could be fixed. one to look for is 'lamp alignment'. It should show all the colors and lines with directions to bring them into focus. This should fix the blurriness and 3-d red/green/white separations. hope this helps you!
Aug 16, 2009 | Philips Magnavox 51MP392H Rear Projection...
Blurry picture and 3 lines on tv curving down
what colors appear on those lines...
you need to take it to a rep shop your convergence outputs are bad...where are you located at?..are you access on yahoo messenger...I can direct you to your problem you can fix it yourself I will show you how pin point on web cam..step by step...email me my email addr is jpactech@yahoo.com
Jan 11, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Blurry, Multi-Color, Multi-Line
covergence problems and its not adjustable you need work done on the convergence board or a new board and realignment which can be timely.
Nov 01, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Daewoo DP42SM coloring missing blue tint on dvd playback only
I don't know are you familiar with electronic,if you are you can fix it by yourself.The problem is in video process board,the one in metal cage.What you need to do is to remove the board from the set,remove the cage, then to replace all SMD capacitors!!!And do not put SMD as replacement put the normal capacitors same values they can be fited.You should aslo replace capacitors at the PSU and check 170V,160V and 70V and adjust them after the replacement.PSU is easy part but the video board is tricky one but it can be done
Feb 15, 2008 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Lcd is blery
What you describe may be caused by several different faults. Do the pictures from the camera show the same blurry washed out look? It may be either the aperture is stuck wide open, or the shutter may be similarly stuck open. Can you describe the symptoms further?
Mar 06, 2007 | Canon PowerShot S410 / IXUS 430 Digital...
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
74 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
