3AC38O363ABB59A34845E05286 LIVEBOX WILL NOT CONNECT TO BELKIN WIRELESS GUSB ADAPTER
  • Anonymous May 04, 2009
    Dont buy a livebox.
    Some idiot somware said "Let's make a router half as powerfull and twice the size"
    Sergeant:
  • 458 Answers
We need more information to answer this.
Posted on May 29, 2008
Can you explain to an idiot, which exactly what is the correct way to connect Powerline Adapters to orange livebox, I have connected Powerline Adapter to yellow ethernet socket is this correct with the...
Plug the PowerLine adapter into the wall
Plug one end of the ethernet cable into PowerLine wall adapter
Plug the other end of the ethernet cable into the Orange LiveBox
Plug the Orange LiveBox power adapter into the wall
Mar 09, 2010 | Powerline Ethernet Network Adapter
Wireless connection using livebox and belkin usb adaptor
You most likely need to reconfigure the livebox settings. The Livebox lost the settings because it was unplugged too long. Most router settings can be accessed by typing in 192.168.1.1 or 192.168.0.1 in the URL address bar of any web browser. From there, make sure that all other switches and devices on the network are on the same network. Meaning if your Livebox default gateway is 192.168.1.1 make that the switch that other devices are connecting to the network through are assigned the IP address 192.168.1.x where x is any number other than 1. I hope this help, I know its not comprehensive enough but once I'm a 'Guide' you will be able to chat with. Then we can have conversation via IM Chat. This is my area of expertise.
Jun 17, 2009 | IBM (34L1209) Network Adapter
X box 360 wont connect to orange livebox!!!
there could be a problem with the xbox wireless adpter which it maybe a fautly item
Feb 18, 2009 | Microsoft Xbox 360 Console
I'm trying to connect a 2nd desktop using a Belkin wireless usb mod: F5D7050eaE via an Inventel wireless modem mod:DV4210-WU product name Livebox-07F8 when I get to the security code insertion box and...
although is unlikely the both of devices work.. you may be running into compatibility issues.. have you checked the inentel wireless modem documeentation?.. and is it a a modem or a router?
Sep 21, 2008 | Belkin Computers & Internet
Belkin F5D7050
http://www.belkin.com/au/support/
and then look for the driver you want from there
Aug 06, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
Belkin wireless adapter g usb
WPA is safer as all in all it's a lot harder to crack due to being a lot more characters in the passkey. The easiest thing to do would be explain how i have mine set up. And you could compare the 2.. As i have XP Desktop & Vista aswell. So your Laptop connects ok now but is still an unsecure network.. On your Dektop. When you try to connect. Are you entering the 26 character key on the bottom of the livebox?
The main thing to realise with the Livebox is everything is reversible.. And to not worry about changing something..
So let's get this started, When you open up the " Connect To A Network " you can see your Livebox-XXXX. Next to that does it say "Unsecured Connection"? If this is the case then your Livebox is still not properly configured.. What i would recommend doing is starting a fresh with the Livebox, and i explain how to set it all up from Default. icon_smile.gif
IF you don't remember your internet login details then go to "Configuration.adsl" and click My Services then Internet. Your info will be in there. Hopefully you remember your password.. icon_smile.gif
If you don't know how to do a reset of your liveox. Press and hold the "1" button on the back of your livebox. Unplug it from the mains whilst still holding the "1" for 10 seconds. Then plug it back in. [ still holding the "1" ] The lights will flash a bit and after a minute or two it will go back to normal.
Go back to "configuration.adsl"
Username: Admin
Password: Password
If i start from the top section and work down it should make it easier to follow:
My Services>Internet>Connection Parameters Filled In..
Phone Over ADSL> Nothing needs changing
Digital TV> Nothing Needs Changing.
Liveprinter> Nothing Needs Changing.
Submit
Security> Associated Devices> Will Be Empty
Firewall> Medium
Wireless Connection> Channel Number> 11
Security Key(WPA-TKIP)> Same As What's On Bottom Of Livebox.
Enable Wireless Lan> Ticked.
Submit
Configuration> Update> v5.10.7-uk
Administrator> Change the password while you're there..
Submit
Advanced> Wireless> Pairing Time> 10 minutes should be fine.
Your Livebox name can be left as it is.
WPA Security Only
Wi-Fi Easy Pairing.. Might aswell leave it on..
Submit
Now if we set up your laptop first.
Go into Connect To A Network. Your Livebox should be there. It also SHOULD say Secured Network. If there is a Red Cross then you will need to do what i suggested yesterday on my previous post.
Go back to connect.. Enter the 26 char. passkey with caps lock on.. And you should be connected no problem.
Now for the Desktop.
when you log on.. In the taskbar in the bottom right should be something to do with wireless networks. Double click this.. If it mentions something about using the software that came with the device.. Then use the software.. If not then windowsXP will show your network. Double click it.. Enter the same 26 character code.. And you SHOULD be connected.
Let me know if that works.. Sorry for the really long post, but detail is something i do quite well... icon_smile.gif
May 26, 2008 | Computers & Internet
Set up
which key are we talking about .is it the wep key
Dec 07, 2007 | Belkin (F5D7050) 802.11a/g/b Wireless...
Orange Livebox and NIC
Sounds like an internal problem with the Orange Livebox NIC controller.
If you have an other router Lynksys/belkin you could try it would isolate the problem definitively
Nov 26, 2007 | Powerline Ethernet Network Adapter
Connecting powerline ethernet adapters through orange livebox
Try to eliminate the problem into smaller parts. Try networking the two via the same power outlet via a multiple power board first in the same room. I don't have much experience with these powerline ethernet but i'm sure the configuration of these will be very similar as wireless router / access points and wireless adapter cards. However what I do know is that your power outlets need to be on the same "phase" of your electrical power system, so if you do this test I suggest (from one outlet board) you know the equipment works and your setup procedure works. then try seperating again and if it still doesnt work, check if your power outlets are wired on seperate phases (depends if your house has 3 phase wiring incoming to your home or not). Try another room or another outlet.
Oct 13, 2007 | Powerline Ethernet Network Adapter
Computers & Internet Logo
David Payne
David Payne
