Question about Brother HL 5040 Laser Printer
Badly jammed Brother HL 5040 B&W laser printer
I have a paper jammed Brother HL 5040 B&W laser printer. The jammed is broken off inside the printer and there is no access to remove the paper. It can't even be seen so it will need to be taken apart. I am looking for a free guide on how to do it and put it back together.
Bill at billdobbins@buysellhomesmn.com
  • YY98 Dec 21, 2008
    I have a HL-5040 with the same problem, keeping jam paper in the position difficult to be removed until taken apart.
    New Friend:
I refilled the ink tank immediately after seeing low blank ink flashing on its window. The low blank ink continuously flashes even after I refilled it. What to do?
Posted on Jan 24, 2016
If you remove the drum unit and cartridge it will all come out in one go.
Open the right hand end. The black T700 cartrige will be seen and it looks as if it is screwed in. However it is NOT just get a firm grip and pull the entire unit out (It snaps in and is quite tight... keep pulling it will come and there are no clips to break as you pull)
As it is removed, all the paper will come out in one go. A bit daunting if you have not done it before. Refit is the exact reverse, push it in quite firmly and it will latch back in place with a pleasing clunk! Hope that helps.
Posted on Jan 24, 2009
When I turn on the printer the light paper flashes
The paper light flashing because there is some paper inside the printer. Open the front cover and remove the cartridge and look inside for the jammed paper. Remove the jammed paper and insert the cartridge , closed the front cover and switch on the printer.
It will help you to solve the problem.
Jul 22, 2010 | Brother HL-2040 Laser Printer
Paper jam in brother laser printer Hl 2140 can help plse?
Here is the solution------
1. Open the Front cover of the printer. 2.Remove the cartridge and look inside the printer for jammed paper. 3.If any jammed paper found remove it. 4.Insert the cartridge again. 5.Closed the front cover.
It will help to solve your printer problem..
Jun 03, 2010 | Brother HL-2040 Laser Printer
HL-5250DN Laser Printer: We have a brother 5250 laser printer. Trying to...
The problem coming because there is some paper jam in side the printer. Remove the toner cartridge and look inside the printer for any paper jam.
I hope it will help to solve your printer problem.
May 18, 2010 | Brother HL 5250DN Laser Printer
I cannot get my brother HL-5140 laser printer to print anything!!!!!! I have tried all troubleshooting suggestions.light on status is red
There is some paper jam inside the printer .Please remove the cartridge and look inside the printer for paper jam. If paper jam is there , remove the paper . I hope it will help to solve the printer problem.
Jan 25, 2010 | Brother HL 5140 Laser Printer
Brother Laser 5040 says there is no paper when there is plenty of paper. Have checked for jams and recently replaced drum and toner.
Unplug the printer for about ten minutes. This will clear the NVRAM in the printer. That is where the paper jam's are stored if they get stuck in the printer.
Dec 17, 2009 | Brother HL 5040 Laser Printer
How to clear paper jam in HL 5040 laser printer
Clearing paper jam in a printer is simple almost seven step procedure.
i. Put off the printer.
ii. Open all the covers/shutters on the printer (usually one in front or top and one at the back.
iii. Now pull out the cartridge carefully.
iv. Site the paper that has jammed and pull it out in the opposite direction of its movement. (Pulling the paper in the opposite direction is important for the printer mechanism).
v. Return the cartridge and press it firmly inside.
vi. Close all covers.
Power on your printer and you should be able to print again.
Dec 04, 2009 | Brother HL 5040 Laser Printer
I have a paper jam on a HL-5040 where I can see the paper under the toner/drum. The Brother site suggests pulling the paper up and out once the paper tray is removed, but my sheet of paper won't budge at...
I consulted the Brother site again but this time I researched just how to remove the drum. This page has nice drawings that show how to just pull it straight out! They explained the blue button on the right is just for holding the toner in the drum. They also showed, a very important piece of information, where to place the hands as well. I did it slowly because the jammed paper seemed to be 'stuck' to it. It came out easily, with no real force required. I removed the paper and slid the drum back into place. Quite simple once I could see how to do it without risking damage to the printer!
Apr 08, 2009 | Brother HL 5040 Laser Printer
Brother HL 5040 Laser Printer Logo
210 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
