Question about Electronics ESD 767 Radar Detector
The laser alert sounds almost constantly in the Ford Edge but not in other vehichles.
How do i get sound to work for recieving text messages
Depends on the phone, but on iPhone there is a very small lever on the top left edge above the volume UP button.
You should also check Settings - Sounds - Text Messages
COMMENT below my name with make and model.
Aug 02, 2016 | Cell Phones
Laser alert constantly goes off
Laser is very sensitive to false alarms often set off when driving by an airport, or military base. Set your laser on City Mode and pay attention exactly where it goes off. Mine goes off constantly in the same place which is a air force base in Tucson, AZ. Unless you drive like crazy shut it off in the city although the cops like to use a hand held one in school zones. In 6 years of driving in Arizona I have had one real laser alert, and other than false alerts, real ones are far and few in between. Check when and where the unit alerts and use different sensitivity settings. One more thing, if your laser warning goes off you already have the ticket since the cops use them at close range unlike the radar bands. Hope this helps.
Sep 29, 2014 | 2012 Pro Sti Magnum Dash Mount Radar...
The car is turned off but the parking light will not turn off. Why
Had a similar problem with an explorer. When u lock the vehichle with the fob does the horn honk twice? If it does the vehichle thinks there is a door open. I found a broken ground wire inside the driver side front door harness. Used a scotch lock to fix it and problem was over
Aug 01, 2014 | 2007 Ford Edge SEL Plus
ALL MY PRINTS HAVE A VERY BLACK, 1/4" WIDE LINE ON THE RIGHT EDGE OF THE PRINT, FROM THE VERY TOP TO THE VERY BOTTOM
This printer has a laser cover that you can slide out and clean. What you are describing sounds like there is spilled toner on the lens which causes a constant mark down the page.
From my memory, if you open the front cover, on the right hand side of the printer there is a little window that allows you to slide out the optic cover of the laser. This will have some toner on it so if you just clean it with off with a a soft cloth then I am sure that the problem will be solved.
Jun 09, 2011 | Minolta magicolor 2400W Laser Printer
Turns on for a minute then seems the power is gone and making constant sound
make sure its power cord is plugin to the wall outlet, it makes constant sound to alert that it has no power supplied and its batterry could be drained in time
Oct 19, 2009 | CyberPower (CP800AVR) UPS System
Brother mfc 7420 constant paper jam
need a little more info on this. does the paper look like it catches on something? is there any nicks or anything on the lead edge?
razors
Jan 07, 2009 | Brother MFC 7420 All-In-One Laser Printer
False laser alerts
Bel has a firmware fix to solve these issues. It if free if your RD still is in warranty. Of course, covering the rear laser sensor may solve the problem. That isn't a really bad idea since the rear laser sensor on all radar detectors is pretty much useless anyway.
Jun 06, 2008 | Pro RX65 Radar Detector
Motorola Razr 3a cell phone
menu,media,ringtones, and now change the miss call alert to silent
Mar 30, 2008 | Motorola Mobility RAZR V3
Electronics ESD 767 Radar Detector Logo
26 people viewed this question
Top Cobra Vehicle Parts & Accessories Experts
John Nolan
Jason
Are you a Cobra Vehicle Part and Accessory Expert? Answer questions, earn points and help others
