Question about Fuji Computers & Internet
Sirs, Ouir fuji monitor type UD41H AET 2 ( monitor on offset machine ) has some problems. We want to know if you can supply us the board of this monitor : fuji electri japan 75 25914(2)G Thnk you for your help
Monitor image became offset to the right. How to fix this?
Have you tried telling the computer that you want a single display and not dual?
Dec 19, 2013 | ASUS VW192S Monitor
Black out
In most cases, the problem is caused by faulty filter capacitors in the power supply. You can open the back and replace the capacitors that look bulged and leaky or replace all the electrolytics in the power supply board. If it continues to turn off like that, the tubes are at the end of their service life.
If you have no desire to buy a new monitor at that point, the tubes are able to be replaced, but for overall simplicity- just order the replacements aet up for your specific monitor from Dell. Make sure they have the boots, the plastic attachments and connector for "drop in" use. If the tubes require connectors to be soldered on, it gets tedious and is not worth it from a standpoint of shop time..
Feb 12, 2012 | Dell E176FPB 17" TFT LCD Flat Panel...
Acer Monitor V193W has no signal
There are 2 basic reasons for the "No Signal" message.
  1. Loose video card inside the machine- if you're machine didn't come with on board video or if you are using an independent video card instead of on board video, the card can unseat at times, either due to movement of the machine or pulling on the video cord
  2. Loose connection between the video cord and/or monitor and/or machine. Unless the plugs on both ends are secure (including tightening both screws to prevent loss of connection), the cord can dislodge just enough to interrupt your connection, causing a "No Signal".
If neither of these is the case, try hooking up a different monitor (if equipped, you can use an HDMI cable to your TV) to see if the "No Signal" message persists.If using a different monitor works, the issue is your Acer Monitor.
Dec 07, 2011 | Acer Computers & Internet
My LG 26LH20 turns itseld off after about 2-3 seconds. TV is a little over 1 yr old. I t happened about 2 months ago and I thought it was the cable. had cable serviced, not the problem. now it's...
Tv turn itself off after 2-3 seconds the tv still audio voices?Yes,than the tv long board that call the LCD inverter board it is dead.Require change the tv long LCD inverter board,this board help the LCD screen panel to have a backlight to produced a picture or 2-3 seconds tv power died completely no power to tv all?Yes,than this problems the tv power supply board it is dying.That the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish long LCD inverter board or the tv power supply board for the replacement.
May 09, 2011 | LG 26LH20 LCD TV
MONITOR SHUTS DOWN : WILL RESTART AFTER A FEW MINUTES COOL DOWN.
purchasin757, What type monitor? If lcd type, may have 1 cold solder joint of some component lead on the "switch-mode-power-supply / inverter ballast circuit board, that goes "open" (intermittant) after it reaches a certain unspecified temperature/time period. Unit will need to be investigated by you or electronics technician to find common problem related to all brands of CCFL back-lit LCD monitors. How old did yu say your unit is??? May be that it also need some new electrolytic filter capacitors to be installed on the SMPS/ inverter board to make it servicable for 2 to 4 more years. Lots of video clips you should investigate at YOUTUBE before you return to fixya to do a customer reply and rating of this response to your post. You will also want to do a lot of readng in the fixya profiles of "budmrtn" "12fixlouie" for more info on this (your "black screen of death" symptom) common problem that affects not hundreds, but many thousands of lcd monitors. Let us know what you will do, after you research problem. 12fixlouie
Nov 02, 2010 | Hyundai Electronics Computers & Internet
Fugi 3500 flattens fresh batteries within minutes HELP PLEASE!!
There is a short citrcuit on t6he power board. Now don't quote me here but I think this model had a recall for this problem according to one of the photo buffs in my camera club;
If its still under warranty make a claim now!
Please rate ouir help++++Thanks for using FIXYA
Oct 10, 2009 | Fuji FinePix S9000 Zoom Digital Camera
I have Monitor Proview PL916S 900P It turns on
spc12b, Have you tried the flashlight test yet? How old is this monitor? Your monitor has a 2 types of power supplys in it. A switch-mode-power-supply and an "INVERTER" supply. One or both of them could be having a problem. The inverter needs DC from the smps to change it into AC to light up the cold-cathode-fluorescent-tubes that are hung in back of the lcd panel. Let me know results of flashlight test. After screen goes black, hold light 1-2" from screen at different angles. Let me know if you still can see the win-desktop screen even though it is still dark.. Bye for now. louie12fix on fixya or lmistyrel @aol.com
Aug 12, 2009 | Proview PL916S2 Monitor
Inverter board
just change the 4 bloated caps on the board (2)100mfd 16v and (2) 470mfd 16v
Mar 19, 2008 | AOC LM729 17" LCD Monitor
Computers & Internet Logo
130 people viewed this question
Top Fuji Computers & Internet Experts
Computer Links
Victorman
Victorman
rdjagger
Are you a Fuji Computer and Internet Expert? Answer questions, earn points and help others
