Question about Canon PowerShot SD550 / IXUS 750 Digital Camera
Video In Fast Motion
I accidently changed the speed in which the movies playback how do I change it back ? It goes really fast
  • 22 Answers
Press play??
Posted on Jun 16, 2008
Why do Netflix movies keep stopping?
It could possibly be a slow internet connection speed. Netflix posted requirements. This is a good site to check your speed. http://www.speedtest.net/ Internet Connection Speed Recommendations Below are the Internet download speed recommendations per stream for playing movies and TV shows through Netflix.
  • 0.5 Megabits per second - Required broadband connection speed
  • 1.5 Megabits per second - Recommended broadband connection speed
  • 3.0 Megabits per second - Recommended for SD quality
  • 5.0 Megabits per second - Recommended for HD quality
  • 25 Megabits per second - Recommended for Ultra HD quality
HD Video Quality
Movies and TV shows we have available in high definition will play in 720p or better with a fast enough internet connection. To watch Netflix in HD, ensure you have a HD plan, then set your video quality setting to High in the Playback Settings for your account.
Netflix Bandwidth Usage
Higher quality video uses more bandwidth than lower-quality video. If your service provider applies a bandwidth or data cap to your Internet service, you canManage Bandwidth Usage by changing the video quality settings to Low or Medium to consume less data.
Oct 01, 2014 | Netflix
Canon ixus 75
Unfortunately, no. By recording in fast mode, the camera captured fewer frames than usual. When played back at the normal speed, the action appears faster than normal. Because the camera recorded fewer frames, there is no way to make up for the images that were not captured. You could slow down the playback, but the result would be a jerky, jumpy video.
Now, if you had accidentally captured the video in slow motion, you could then throw away some of the intervening frames and recreate a normal-speed video.
Feb 15, 2012 | Canon PowerShot SD750 / IXUS 75 Digital...
My g9 was playing video clips very fast. i changed the setting back to "standard" and can record/play new videos correctly; however, the video clip that i previously recorded before i changed the setting...
I believe the setting you changed set the RECORD method, not playback. The video is recorded that way. There are some Video software out there that can rerecord a video at a slower pace, but do you want to spend the money? Try Ulead.com for a low cost program.
Apr 17, 2010 | Canon PowerShot G9 Digital Camera
Vizio SV470M, picture is moving too fast
This is often called the "Soap Opera" effect...I had a similar problem and found that changing the settings helped tremendously. Here are the settings I use:
Picture Mode: Movie
Backlight: 18
Brightness: 49
Contrast: 52
Color: 42
Tint: 2
Sharpness: 3
Advanced Video
Noise Reduction: strong
Color enhancement: off
Advanced Adaptive Luma: Off
Enhanced Contrast Rato: off
Color Temperature: Normal
Red: 121
Green: 128
Blue: 118
Smooth Motion Effect: low
Real Cinema Mode: Precision
Also, there's a great thread on the Soap Opera effect here:
http://www.hometheaterforum.com/forum/thread/291611/the-soap-opera-effect-on-modern-displays
Feb 25, 2010 | Vizio SV470M LCD TV
Canon PowerShot SD 870 IS Movie playback speed is too fast!
You've got it on Time Lapse video. Turn on, slide to video, press func. set button, toggle to standard instead of time lapse. Maybe next time try your owners manual. Of course you all are probably like my mom and just get a new camera, put in the batteries and start taking pictures. These stupid expensive cameras have too many options and get messed up too easily with the wrong press of the button. Try a simple cheap on next time.
Feb 14, 2009 | Canon PowerShot SD870 IS Digital Camera
Recorded video segment plays back in fast motion. How do i reset
This is a really simple problem and easy to solve.  Unfortunately the videos you've recorded cannot be changed back because they have been recorded in Time Lapse mode.
With the camera switched on in Video Mode turn the control dial on the back (this is the dial to the right of the LCD screen).  This will change the settings from TIME LAPSE to STANDARD.  There are actually 6 different modes but the best one for normal videos is STANDARD.  There is a HIGH RESOLUTION setting,  however these record fewer frames per second (fps) so whilst the quality is better per frame,  there are half the amount of fps so the the movie will look at bit jerky.
It's really easy to accidentally twist the dial when holding the camera,  so always check the icon in the top right of the LCD before recording to make sure its just a yellow camera in a yellow square.
This should be problem solved for all future recordings.
Jan 23, 2009 | Canon PowerShot G9 Digital Camera
Remote problem
Hi There,
On the front panel:
REV Button (DVD)
Press to view the DVD picture in fast reverse motion
or to reverse playback of an Audio CD.
Press to skip Chapters or Tracks.
FWD Button (DVD)
Press to fast forward the Disc. Press PAUSE, then
press this button to begin slow motion playback.
Press this button repeatedly to change the forward
speed of slow motion.
I hope this helps,.
If not, feel free to conact me.
Thanks,
Mike
Nov 03, 2008 | Emerson EWD2203 DVD Player/VCR
Sound and video playback do not match
No button or any control to rectifier this problem. Depend the movies quality when you fast forward the system control and audio video processing or it call out MPEG2 chipset they run like double speed sometimes it not fast enough then you end up with sound and video not SYNC however you can fix that by remove AC lead for 30sec then plug in back now it should work OK or when you fast forward use X8 or X16 NOT X32 times specialy with DVD copy
Alternatifly if your DVD player still under warranty it might have a update firmware to correct this problem
Cheers
Nov 01, 2008 | Philips DVP5140 DVD Player
I have a canon SD 580. When I playback the video clip it's always in fast forward mode and I can't play it normal speed. Any help?
Make sure you are shooting your movies in "Standard" mode. If you have the mode set to something else, especially "Time Lapse", the playback may not match 'natural' motion.
In any case, you can control the speed of the playback. When you first enter the movie playback mode, there should be a movie control bar along the bottom of the LCD. Instead of the "Play" button, select the "Slow Motion Playback" button (single arrow with single bar next to the normal Play button), and control the speed with the left or right arrows on the multi-controller.
May 02, 2008 | Cameras
Canon PowerShot SD550 / IXUS 750 Digital Camera Logo
90 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
