Question about Sharp AL 1631 Copier
Flash the number 4 then H - Sharp AL 1631 Copier
  • 1,110 Answers
To reset the H4 condition on just about any Sharp AL series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
Some model's use 2 other initial codes, so you may need to use one of these 2 alternate codes to get your display to go blank. The rest of the procedure is the same.
Alternate codes are: #, * , C, * or pound,star,C,star and also
#, Interupt, C, Interupt
If done correctly the display should go blank.
Now key in 14 as if you were going to make 14 copies.
Now press the print button.
The machine should reset and the code should be gone.
9 times out of 10 this is a false code that pops up due to power surges or noise.
If the code comes back this means you have a heater lamp or thermal fuse (more common) failure in the fusing area and will need service.
This is content from my tip posted on the subject which you can get with this link:
http://www.fixya.com/support/r3798833-sharp_al_series_copier_h4_h_4_service
Good Luck and Thank You for using Fixya.
WheatlandServices
Posted on Sep 30, 2010
How to do a self diagnostics code test on a Chrysler Concorde LXI 2001
put key in ignition turn key to start position then off then to start then off then start and leave on. count the check engine light flashes. the first number will be a long flash then the numbers after will be short flashes, then a pause and then the next code will flash with the first number a long flash then followed by short flashes. count the flashes. if the first flash is a single flash and the next flash is say 3 quick flashes then this is code 13. these are a 4 number code system like 1013 is the same as a code 13. I hope you understand as its difficult until you get the hang of it. Chrysler has a code at the beginning to indicate codes starting and one at the end to indicated codes ending. and will repeat the cycle 3 times. it maybe easier to get them pulled using a code reader.
Mar 10, 2013 | 2001 Chrysler Concorde
How can I make conference call or joint call fron vtech cordless phone
To make two-party call on your Panasonic phone and ask the person on the other line to wait for a moment.
  • Check to see if your Panasonic phone has a flash key feature. If it does, press the flash key down and wait until you hear the confirmation tone. If the Panasonic phone you're using does not have a flash key, hold down the the hook switch for half a second, then release. Dial the number of the third person in your conference call. If you're inviting someone in-house to be a part of your conference call, dial their extension number instead. If you're dialing an outside line you may need to dial 9 before dialing the number.
  • Wait for the new addition to the conference call to answer and then press the Flash key again. Wait an additional two or three seconds before pressing the number three on your telephone keypad. Start your conference call. Once you've pressed the flash key followed by the number 3, as in Step 4, your conference call is established. If you wish to add additional participants simply repeat Steps 3 and 4.
    Regards
  • Jun 30, 2011 | Vtech Cordless 6041 Phone
    When using a jumper wire to retrieve ABS trouble codes on a 2002 Trooper 4 wheel drive how is the DLC numbered? I mean which pins do I jump? And when I do jump, Will the ABS light flash te codes....
    ok, there are 16 pins in the DLC you want to jump #4 and #12 as you look at the connector from left to right top row is 1-8 bottom row from left to right 9-16, both rows the 4th pin jump them together. then count the flashes all codes are 2 diget ( example flash-flash pause flash-flash = code 22 )
    Feb 17, 2011 | 2002 Isuzu Trooper
    I have an Alpine 7510T recevier/cassette player in my Toyota Town Ace. The battery was replaced & the unit has locked. I have the security code but can't enter it correctly to unlick the unit. What...
    put the ignition on to just before starting the engine then add each number while u wait for the flash in between each number ie 1 flash 2 flash 3 flash 3 flash 4 flash 5 flash.
    Sep 06, 2010 | Alpine TDM-7561 Cassette Player
    We are trying to move the chair and the service light keeps coming on
    The service light indicates a problem. Count the number of flashes. ie flashes 4 times pauses flashes 4 times etc. If you have the owners manual the flash code section will tell you what the number of flashes mean: 3 flashes left motor 4 flashes right motor. You will have to contact a service company to repair the chair once you find out what flash code you have. If Medicare pirchaed the chair then they will pay for most of the repair cost. Hope this helps
    Aug 25, 2010 | Electric Mobility Invacare Pronto M41...
    I want to set the time and date on my calculator and need help Please give me the directions
    1)Press TIME/DATE and then SET (The first digit of the month will flash)2)Enter the month MM using the number keys.
    (The first digit of the date will flash)
    3)Enter the date DD using the number keys.
    (The first digit of the year will flash)
    4)Enter the year YYYY using the number keys.
    5)Press SET to confirm the date.
    6)Press TIME/DATE and then SET. Enter the time using the number keys and press 12/24 to switch between 12-hour or 24-hour clock.
    7)Press AM/PM to toggle morning or afternoon and press SET to confirm the time.
    Oct 24, 2009 | Victor 1208-2 Calculator
    Megan Radio Codes
    you can only put the code in if 4 zeros are shown if there are 4 dashes leave the radio on till the 4 zeros show can take over an hour then using the remote next to the steering wheel r/h side use the wheel to move the number up/down to the right number then press the button on the bottem to move to the next number after all numbers press and hold the bottom button to enter the code
    Sep 02, 2009 | 2000 Renault 181
    Start light flashing wont start cycle, what does it mean
    count the number of flashes- this indicates fault ie will flash 4 times stop, flash 4 times stop. To clear fault, hold start button for 3 secs. Try running another fast cycle- if fault reoccurs count flashes: Number of flashes:1=NTC fault, 2=Flood switch activated, 3=Heating fault, 4=drain fault, 6=water inlet fault, 7=flow meter fault, 8=water level fault
    Aug 06, 2009 | Whirlpool Dishwashers
    Error code e10
    Communication failure =E10
    1. Rotate the CYCLE SELECT KNOB to the 3 O’clock
    position.
    2. Press and hold the Select and Pause Cancel
    buttons simultaneously for (6) seconds.
    3. Immediately after, press and hold the START and
    Pause Cancel
    buttons simultaneously for (4)
    seconds.
    4. Rotate the CYCLE SELECT KNOB to the 2 O’clock
    position.
    The STATUS indicator lights will flash the number of
    times for the first digit of the code and the START indicator
    light will flash the number of times for the second digit.
    The code is obtained by counting the number of times
    the lights flash. Example E24: the STATUS indicator
    lights would flash twice indicating the 2 and the START
    indicator light will flash four times indicating the 4. The
    STATUS indicator lights and the START indicator light
    will start flashing at the same time. The control will then
    pause for 2 seconds, then repeat the code.
    Troubleshoot the problem by using the chart on next
    page.
    To move to the next code, press the OPTIONS button.
    To clear code, press the Select botton.
    To exit this mode, simultaneously press and hold the
    Select and Pause Cancel buttons for (6) seconds to
    reset.
    if this does not work need to replace control
    Sep 07, 2008 | Frigidaire Washing Machines
    Nixon cool pix 8.0mp
    I believe that means the range is from 4 seconds exposure to 1/1000 second exposure time, and does not refer to the number of flashes.
    Some cameras will flash several times before the main flash while taking a picture if it is set to red-eye reduction (because the first 3 flashes make the subject's pupils go smaller).
    Under normal flash photography, there will be only one flash.
    If you set the camera to automatic, it will do most ofthe work for you.
    Jul 14, 2008 | Nikon COOLPIX S200 Digital Camera
    Sharp AL 1631 Copier Logo
    119 people viewed this question
    Top Sharp Office Equipment & Supplies Experts
    Anthony Karuku
    CheckitRight
    CheckitRight
    jasbo
    jasbo
    Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
