Question about Karcher K2.26 Electric Power Washer
PRESSURE WASHER PULSES, - Karcher K2.26 Electric Power Washer
2 Suggested Answers
  • 32 Answers
SOURCE: hi,karcher hds hot pressure washer now pressure
what you need to do is, take the screw fitting which goes to the water tank off, then the one that goes from the water tank to the pump head .
then put the one that was in the first place going to the water tank on to the pump and force feed with water.
see if you can see water leaking from any where seals hose.
try running the machine to check the pressure.
if water leaking from pump head you need seals.
Posted on Jul 04, 2009
Connected to a pressure washer pump pulses even with biggest tip on wand
Could be an element of the pump isn't working.
My pressure washer has a 3 element pump and delivers a smooth output but did once have a problem where the pump was only using two elements and this resulted in a pulsing effect.
Mar 13, 2016 | Garden
Pressure washer itseld turns on
I'm guessing that you have a small electric washer. These come on when triggered.....or if there is a water leak on the high pressure outlet side, at a connector or the gun itself...or possibly some internal leak. It's not likely being worth the cost of a repair if it is something beyond a simple leak. Commonly, the washer will only come on in short pulses. Coming on and staying on would be an internal switch problem unless your high pressure leak is substantial. Leaks are usually just worn, split or missing o-rings at the connectors.
Oct 20, 2012 | Garden
I have a Karcher K3.540 pressure washer. Won't take up detergent and motor pulses ever second if vari-lance increased towards maximim. Motor runs ok at lower pressure but can take 1min to start wh
This fault is within the control head, under the detergent valve is a small spring loaded valve that acts to induce the detergent, this will have failed, the shaft of the component breaks off the disk base leaving a small hole in the centre of the disk. This is enough to allow pressure past the component. The machine will pulse when operated and will not induce the detergent. I've looked everywhere to find this part as I have a karcher with the same fault.
Jan 22, 2012 | Karcher Garden
My Karcher 2.99 starts and stops, (pulses) when th...
Is liquid leaking from the base, when the Pressure washer is on ?
I have the same Problem, the leak is from the seam of the Manifold housing. There is a small crack in the seam. A manufacturing defect.. A New Manifold Complete Replacement is $61.03, about the half the price what I paid for this pressure washer at Walmart... :( If under 1 year old, and you can find a receipt,Karcher will replace the whole Pressure washer under warranty.
May 21, 2010 | Karcher K2.26MR Electric Pressure Washer
Our pressure washer loses pressure for no reason and it pulses. the water pressure is fine.
your bypass valve that keeps pressure off the hose when the trigger isn't depressed is stuck open,and not letting the pump build pressure
Mar 18, 2010 | Garden
Loss of preasue and pulses in standby mode
Check the oil. This is what happens when it is low on oil with my pressure washer. Kind of a safety feature.
May 15, 2009 | Karcher Garden
Washer pulses
You need to bleed air by running unit with water on or your water pressure is low
Aug 02, 2008 | Electrical Supplies
Karcher K2.26 Electric Power Washer Logo
152 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
