Question about Intertherm P3RA-060K Air Conditioner
Intertherm heatpump outside fan will not come on, replace fan motor and capacitor, fan will not come on what could it be
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 141 Answers
Some times heat pumps have a fan cycling switch to keep the head pressure normal in cool weather or check the defrost relay for the fan when a heat pump condenser gets frosted it will stop the fan and reverse into cooling mode for a few min. to melt the ice and this function is done by a relay or a printed circuit board if it goes bad you wont have voltage to the fan
Posted on Oct 01, 2010
Intertherm MGHA-070ABFC-05 will not run/cool
Multiple problems. Eliminate thermostat first. Remove face from wall and turn on breaker. If fan still runs you have a bad board or bad relay. If fan outside is running compressor should be too. These operate on same contactor. Verify you are getting 24 volts to coil side of contactor. If odf stops working and contactor remains pulled in you have a bad motor. If odf motor stops working the compressor will shut off due to overheating.
Jun 07, 2016 | Intertherm Heating & Cooling
Have an intertherm split system. Outside condenser compressor is starting, can hear freon flowing, but fan motor will not kick in. Gets hot then kicks breaker. Have replaced capacitor with factory part.
If that system is gas heat then you have 2 fan speeds Lo speed for heat and when ac is called for the motor speed shifts to hi with the use of a fan relay.
Some various fan relays in use today. themobilian_2285.jpgthemobilian_2286.jpg
May 02, 2011 | Heating & Cooling
Outside fan runs slow on my janitrol heatpump
If it has service ports on each side of the motor you need to add Zoomspout oil to the cotton wells.0942d92.jpg Check the capacitor if you have a seperate cap for the fan motor. Look for swelling that is a sure sign of cap failure.c51cc2e.jpgKill power at the outside unit before checking anything. 2550ebd.gif
Oct 07, 2010 | Heating & Cooling
Fan not working on outside AC unit
The buzzing noise is probably the fan motor. Is the compressor running? First make sure that there are no tripped breakers. After that kill the power and check the capacitor with a multimeter. If that checks good then check the fan motor windings with the multimeter. Let me know if you have any questions.
May 26, 2010 | Intertherm P3RA-060K Air Conditioner
Where is the capacitor located on a coleman heatpump
If you're talking about the outside fan, look where the wire goes into the outside unit. The capacitor will be somewhere near the circuit board and will be round or oval and metal or plastic. If you're talking about the inside unit it will be with the electrical control in the air handler. Write down where the wires go. The terminals on the capacitor will be marked and for the outside unit you will either have 1 that runs both the fan and compressor or a seperate one for each. If you have 1 that runs both the wires must be reconnected to the right terminals. They will be marked COM, FAN, HERM(stands for compressor). Take the old one with you to get a new one. Let me know what you find.
May 04, 2010 | Coleman Heating & Cooling
Rudd heatpump compressor runs outside fan dose
I don't think the fan on it' own crates the problem. Could you find out what should be and what actually is the flow through it. If you needed <!-- MOJAIZBA.COM LINK CODE START --> <a href="http://mojaizba.com/convert-units-of-flow" title="Flow units converter page on mojaizba.com - Convert flow units online. Use the calculator for making conversions from one flow unit measure into another flow-volume amount between; acre foot per: acre-ft/day, hour acre-ft/hr, year acre-ft/yr, bar/day barrel Oil per day, hour bar/hr, minute bar/min, second bar/sec flow, cubic centimeter per day cm3 / day, hour cu cm/h, minute cm3/min, second cm3/sec flow, cubic foot feet per day ft3/d, hour ft3 / hr, minute ft3/min, second cuft/sec, cubic inch per day in3/day, hour in3 / hr, cubic inch per minute cu.in/min, in3/sec, cubed meter per day m3/day, hour cu m/h, minute m3/min, second m3 / sec, cubic yard per day yd3/day, hour cu yd / h, yd3 / min, cu-yd/sec, gallon US gal/day, gal/h, gal/min, gal/s, gallon UK per day gal/d, gal/hr, gal/minute, gal/sec, hundred cubic feet foot per day 100 cu-ft/day, 100-ft3/hr, hundred cubic foot per minute flow 100ft3/min, 100 cubed ft/sec, kilogram per day - Petrol kg/day, hour Gasoline kg/h, kg/min, kg/s, liter per day l/day, l/hr, l/min, l/sec, milliliter per day ml/d, ml/h, ml/min, ml/sec flow, ounce US per day oz/d, oz/h, oz/min, oz/s, ounce UK per day oz/day, oz/hr, ounces/min, oz/sec, pound per day - Petrol flow lb/day, Gasoline lb/hr, lb/min, lb/sec. USA – Imperial UK and Metric SI system units of flow. Buy the JavaScript JS and HTML code for this web flow converter tool application for your website." target="_blank">flow units converter</a> <!-- MOJAIZBA.COM LINK CODE END --> for a unit you'are comfortable with here is one we use if it's necessary. Let me know that...
Mar 21, 2010 | Ruud Heating & Cooling
I have a Intertherm heat Pump. Everything turns on inside the house. Blows warm air and the outside Fan wont turn on. Both the outside copper pipes are same temp, neither hot nor cold. Don't know the modle...
If the fan outside doesn't work the compresor will overheat and shut off by the thermal protection inside the compressor , to fixed this you have to replace the fan motor and its capacitor.
Aug 26, 2009 | Heating & Cooling
WONT COOL OUTSIDE UNIT DOES NOT COME ON FAN BLOWS INSIDE
if the fan outside is turning on and inside fan is blowing too, then you have a compressor problem. could be a capacitor gone bad (or needing a hard start kit) to the entire compressor failure
May 03, 2009 | Intertherm P3RA-036K Air Conditioner
Fan on outside unit will not start on its own.
Either your fan motor or capacitor is bad. The capacitor provides the motor with a phase imbalance to start it spinning. If it is shutting off this is because the motor is over amping and getting hot. You can try replacing just the capacitor to see if this corrects the problem but most likely the motor is bad by this point. When you replace the motor, replace the capacitor as well!!!
Mar 26, 2009 | Intertherm Heating & Cooling
Intertherm P3RA-060K Air Conditioner Logo
273 people viewed this question
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Dan Webster
Dan Webster
Bill Long
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
