Question about Magic Chef Chest Freezer MCCF5WBX
How do i add freon to system - Magic Chef Chest Freezer MCCF5WBX
  • Magic Chef Master
  • 8,220 Answers
Get a saddle valve like THIS ONE. Sand down the suction line or compressor ear and attach the valve. Connect hoses to the valve and add some freon. The low side pressure should be around
5 PSI.
Posted on Sep 30, 2010
    President:
  • 1,218 Answers
Good day,
If it's a newer model it would use R134A, if older R12.
In either case if it's developed a leak, and the leak cannot be found and repaired, then the machine is terminal.
Recharging a freezer is like putting air in a flat tire. It'll just leak back out.
The only exception would be if the machine is under 5 years of age, in which case it would be under factory warranty.
ISN'T GETTING COLD NEED TO KNOW HOW TO ADD FREON PLEASE ?
Unless you have a lot of expensive refrigeration tools and a license to recover and buy freon, then you need a serviceman.
Dec 21, 2015 | Amana Freezers
How to refill R134 Freon
you have first put in a line tap. If the freezer system has been open it must be put in vac. to get moisture out. Then with interior coil exposed put in a few oz and start compressor. with compressor running add while watching interior coil/ you add slow til coil frosts to 3/4 then your done
Oct 26, 2013 | Amana 19.7 cu. ft. / 558 liter Upright...
What to do if you have a freon leak in the freezer
charge with detail (that is a Freon with Red dy solution to help locate your system leak) locate leak, repair using silver solder, evacuate system completely, pull vacuum down to 27" plus Lbs. vacuum, close system to hold vac pressure, monitor pressure for 30 minute or so, if vacuum hold pressure then you have successfully fixed your system leak, next hook up your system to the manifold gages assembly to a Freon supply source, all this while retainning your vacuum pressure, slowly crack open the valve on the manifold to allow the new freon to enter your system until you see pressure building up in you system, next monitor the discharge line i.e. the bigger line until you see frost extending outside of your freezer unit toward your compressor assembly, then close the freon supply valve, wait for a while to see if the frost line recede into the unit box, if it does not recede but stay out of the box or extend some more then you must must release some freon slowly a very small amount at the time until the frost line has regressed into your freezer box. this should complete your repair, good luck
Apr 24, 2012 | Kenmore 20.3 cu. ft. / 575 liter Upright...
We have a Master-Bilt DC8 Ice Cream Storage freezer. It starts gradually warming about three weeks after we defrost it. Defrosting fixes it for a short time. We've had a repairman who replaced a part and...
Hi, It sounds to as though you may have a small refrigerant leak in the system. I wish I knew the part he replaced, it must have been in the refrigerant circuit to have to add freon, or it was low in the beginning. They are sealed systems and only require freon if they develop a leak. I think what I would recommend at this point is for them to check the charge again. If it is low, by E.P.A. law's, they need to add dye to locate and repair leaks the second time around, if it is low only. Maybe you can let me know what part was replaced, that would be somewhat helpful.
Sincerely,
Shastalaker7
PS How are you defrosting this box? Most low temperature boxes have a defrost clock on them. Yours may not.
Feb 06, 2010 | Master Bilt Commercial Freezer DD-66CG
Frigidaire stand up frost proof w/ temp alarm / 98' model. Compressor running, no power problem. Removed interior panel and found that evaporator coils not getting cool. When switch for alarm is pushed on...
If your compressor is running with no freon, It should be very hot. Check if it is. And if it is and the freon has leaked out. Then you must find the leak in the system before you add more freon. If you dont this will be an ongoing problem. The freon will leak out after any length of time. This is a very hard task to find the leak, and you will be money ahead to buy another if you dont find the leak than to re charge every year or so.
Jun 29, 2009 | Frigidaire Freezer Refrigeration White...
Frigidaire Chest Freezer Model LffC1466DW4. Inside coils are frozen and copper pipes underneath are frozen. I have let set unplugged for 2 days and tried again. Ice forms within a few hours. How do you...
you dont want to add any more freon to it to start with
it either has to much in it or the thermostat is not turning it off and making it run to long, you need to see what temperature you are getting in the freezer and what suction pressure the unit is running on to determine if it is over charged
Apr 29, 2009 | Frigidaire Freezers
Kelvinator freezer is not freezing!
you mean it cools but not as afreezer ok, rework again the system properly vaccum and slowly charge it but please watch out the proper amperage of the compressor or might be the compressor motor now is weak, how old this unit,sir.thankyou
Aug 05, 2008 | Kelvinator 12 cu. ft. / 340 liter Chest...
Need to add freon
  • if you are tapping into a sealed system, then you use the larger of the two copper lines coming out of the side of the compressor (this is the low pressure line, the compressor pulls from this side).
  • clean off the copper tubing with some fine sandpaper before installing your tap.
  • it is very easy to over fill a system with freon, so i would recommend pulling down the system to -30 psi and holding for at least 20 minutes. then add a known amount of freon to the system.
  • let it run for a while, it will take a little time to get the temperatures down.
Jul 02, 2008 | Whirlpool 15.2 cu. ft. / 430 liter Upright...
Magic Chef Chest Freezer MCCF5WBX Logo
549 people viewed this question
Top Magic Chef Freezers Experts
Dan Webster
Dan Webster
AJMAL KHAN
Tom Chichester
Are you a Magic Chef Freezer Expert? Answer questions, earn points and help others
