Question about HP vs19 (Silver) 19" LCD Monitor
OSD LOCKOUT I HAVE RECENTLY MOVED HOUSE AND WHEN I PUT MY PC BACK TOGETHER MY MONITOR WONT ALLOW ME TO TURN UP YHE SOUND OR ACCESS THE MENU IT KEEPS COMING UP WITH THE PHRASE "OSD LOCKOUT" CAN ANY BODY TELL ME HOW TO GET IT WORKING AGAIN PLEASE
  • 1 more comment
  • tomcarlson0 Jul 12, 2008
    osd is in locked, and cannot unlock
  • SGRANT87 Oct 07, 2008
    My monitor won't allow me to turn up the volume. It keep saying OSD LOCKOUT. HELP!!!
  • niecey770 Dec 13, 2008
    i have a hp w1907 monitor and it keeps flashing auto adjustment in progress after set it on the recommended settings this has been going on 1 month now helppppppppppppppppppppppp
  • 3,037 Answers
If you hold down the menu button, this should unlock the OSD, please let me know if this doesn't work and I will look into this further and see what else we can try. Please let me know if you have any other questions or concerns and I would be glad to help
Have a good day
Posted on May 25, 2008
I just fixed this problem on my computer. Hold the MENU button down on your monitor for approx. 15 seconds. Once the contrast/brightness, etc. screen pops up, your problem should be fixed. Just hit MENU a few more times to skip through the MENU options until it finally hits EXIT and you're good to go!
Posted on Jan 01, 2009
OSD locked, holding the menu button for approx. 15 seconds un locked the OSD,
THANKS 100% cure on first try
Posted on Oct 08, 2008
Limewire was accidently deleted by my young daughter and i am finding it difficult to install it
Need OSD Lock out removed permently Please
have you tried the following steps:
  • Press and hold the "Power" key on your monitor to turn it on. Press the "Menu" button for 15 to 20 seconds to cancel the OSD lockout message.
  • Press the "Power" button on your monitor for several seconds until you see the OSD lockout message disappear. Unplug and re-plug your monitor power cable back into the outlet if the OSD lockout message is still displayed.
  • Turn your computer's monitor off. Press the "Menu" button for 15 to 20 seconds and power your monitor back on.
  • Read more : http://www.ehow.com/how_10015851_fix-osd-lockouts.html
    Apr 09, 2015 | Microsoft Windows 7 Home Premium 64BIT...
    Brightness/contrast locked
    All computer monitors, whether they are LCD or CRT style, have a built-in feature called the on-screen display (OSD) lockout that prevents users from viewing any images on the monitor. If your computer screen has accidentally been set to the OSD lockout setting, there are several ways you can remove the lockout.
    Power off your computer and then remove the monitor cable from the port on the back side of the computer case. Reattach the cable and make sure the pins are correctly screwed in. Power the computer back on and check to see if the OSD lockout message is still being displayed. Check the manual that came with your computer or monitor and locate the troubleshooting section if you are still receiving the OSD lockout message. Find the OSD lockout heading and read the method that your particular model uses to remove the lockout. Attempt generic lockout removal procedures if you no longer have the manual that came with your monitor. Press and hold the "Menu" button located at the bottom of your monitor for 15 seconds and wait to see if the OSD lockout message disappears. Press the "Menu" button again if the lockout message remains on the screen. Use the arrow buttons to navigate through the main menu options. Highlight the "Settings" or "OSD Menu" option and then hit the Menu key again to access the new list of settings. Scroll down to the "OSD Lock" heading. Use the arrow keys to change the setting to "No." Hit the Menu key again to return to the main menu. Scroll to the "Exit" setting and then hit the Menu key a final time to exit the menu setting and remove the OSD lockout.
    Mar 02, 2013 | Dell Inspiron 580 Desktop Computer...
    OSD Locks Automatically
    hope this helps
    Jun 07, 2012 | HP Computers & Internet
    Osd main controler lockd
    Hi there.
    OSD Lockout or On Screen Display Lockout message is that irritating on-screen message that sometimes pops up when you switch on your monitor. This completely locks all monitor settings.
    This problem has most likely happened to everybody at some stage or another. Everything has worked fine until now you turn on your monitor and have a message glaring you in the face displaying something about "OSD Lockout". This doesn't allow you to change any of your monitors settings, including the setting intended to turn off this message. While this problem mainly happens on HP monitors from my looking around I know that others have encountered it on other brands as well. The fixes I provide below should work on those monitors too so don't fear if your monitor isn't an HP model.
    The HP Fixes
    FIX 1
    Plug in the monitor and power it up. Hold down the monitor's Power button until you get a message saying "OSD Unlocked". If the problem persists after OSD is unlocked then unplug the monitor from the wall, wait a few seconds (just to be sure I'd give it anything around 20-30 seconds) and then try again.
    FIX 2
    Instead of holding down the Power button, turn on the monitor and hold down the Menu button for 10-20 seconds. This should unlock the OSD.
    FIX 3
    Turn off the monitor, press down the Menu button and then turn on the monitor. Wait 10-20 seconds. This should unlock the OSD.
    FIX 4
    The Menu button may be stuck in a pressed in position. To get it "unstuck" you'll usually need to open up the monitor. If your not a seasoned veteran at opening up electronics (and knowing where all the screws go back into) then this could be tricky unless you know what you're doing. Unfortunately there are too many models of monitors for me to give a step by step instruction guide for you. If you have warranty this is where you should use it, I suggest you contact the manufacturer.
    The AOC Fixes
    FIX 1
    Turn off the monitor, hold menu and power button together for 10 seconds then turn back on.
    Currently these are the most commeon fixes.
    ~ Slasher_X
    Sep 28, 2011 | Philips 190B6CB/27 19" LCD
    HP 2009m monitor. OSD lockout keeps appearing on
    OSD (On Screen Display) lockout. To resolve the issue you can hold the power button of the monitor until you get another message something similar to "OSD unlocked"
    try holding menu button also if it doesnt workout
    Nov 30, 2009 | HP 2009M Monitor
    OSD Lockout bananas
    Please try to Turn the monitor off. Hold down the Menu button while the monitor is turned off, then press the Power button again to turn the monitor back on. This should unlock your OSD menu and remove that message from your screen. best regards
    May 23, 2009 | HP w1907 LCD Monitor
    HP 1740 popup of OSD Lockout
    Dont take apart the monitor!?!?! Hold the Menu button for about 15 seconds, the manual said 10 but i found by holding menu for 15 seconds it removes the OSD lockout.
    Dec 11, 2008 | Computers & Internet
    OSD LOCKOUT
    1. Replaced the Micro switchs.
    2. press the menu switch 15 to 20 secunds.
    Nov 02, 2008 | Computers & Internet
    Osd lockout
    hold the MENU button for ten seconds to unlock or lock the OSD
    Jul 29, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
    OSD LOCKOUT
    Turn the screen off with the power button.
    Then press and hold "AUTO" and then press the power button at the same time. Your power button should go amber. Release both buttons.
    This should put you into the factory service menu by pressing the menu button where you can reset the whole monitor back to factory settings.
    When you are finished, just exit the menu, turn the monitor off with th epower button again, and back on normally.
    Hope it helps.
    Feb 14, 2008 | Acer AL1715 (Black, Silver) 17" LCD...
    HP vs19 (Silver) 19" LCD Monitor Logo
    843 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
