Question about Whirlpool CA24WCR Thru-Wall/Window Air Conditioner
MY AIR CONDITIONER SHOWS Er IN THE WINDOW DISPLAY.WHAT IS PROBLEM.
When i switch on my ac its display shows ER nd ac isnt working
ER = ERROR. Need more info or please call a service tech
May 24, 2015 | Heating & Cooling
I need to know what the voltage for this unit
Model: REG-123H
  • UPC: 855326002968
  • Product Type: 12,000 BTU Window Air Conditioner & Heater
  • Product Dimensions: L: 24.00" x W: 24.00" x H: 16.00"
  • Product Weight: 88.00 lbs.
  • Product Color: White
  • Application: Used to cool individual rooms
  • Type: Window Air Conditioner
  • Warranty: 1 year; 5 years sealed system
  • Coverage Area: 550 square feet
  • Voltage: 230 volts
  • Heater: Yes
  • Air Flow: 266 CFM
  • Amps: 5.5 amps
  • Heating Capacity: 11000 BTUs
  • Frequency: 60 Hz
  • Cooling Capacity: 12000 BTUs
  • Dehumidifying Capacity: 3.6 pints
  • EER: 9.8
  • Heat Pump: No
  • Number of Fan Speeds: 3
  • Programmable Timer: Yes
  • Timer Length: 24 hour
  • Refrigerant Type: R-410A
  • Air Conditioner Type: Cool/Heat
  • Energy Star Rated: No
  • Air Filter: Yes
  • Built-In Air Purification System: No
  • Display Type: Digital
  • Remote Control: Yes
  • Adjustable Louvers: Yes
  • Adjustable Side Panels: Yes
  • Compatible Window Size: Min. Window
  • May 31, 2014 | Comfort-Aire RED-123 Air Conditioner
    Dawlance split air conditioner shows the eror in display f6
    Check the condensor fan motor. If less RPM replace capacitor. still continues, replace f.motor.
    Aug 25, 2012 | Dometic Heating & Cooling
    Unit shows e1 and will not turn on how do i reset it plus i have no remote for it
    The only way to reset this is to unplug or remove power to the unit, wait 30 seconds and return power, If this does not work changing the control/display board would be the next step.
    Jul 27, 2011 | Haier ESA3087 Thru-Wall/Window Air...
    Hello there, How to switch the display of
    Hold the up and down arrow together it will let you switch it to F or C
    Jul 18, 2011 | Danby DAC8007EE Wall/Window Air...
    After spraying off the unit the display shows e1
    Here is a tip that gives a further explanation of that E-1 code. The causes ofthe E-1 code can be varied depending or the brand of your air conditioner.
    Read through this tip... it will help you understand what is happening withyour window air conditioning unit and give you some things to try to help youget your problem resolved.
    E-1 Code on Window Air Conditioning Units
    heatman101
    Jul 12, 2011 | Haier ESA3125 Wall/Window Air Conditioner
    The meaning of display Error Code-E1
    E-1 Indoor unit room temp sensor faulty. Replace it.
    Oct 04, 2010 | Samsung AW0503B Air Conditioner
    Whirlpool CA24WCR Thru-Wall/Window Air Conditioner Logo
    26 people viewed this question
    Top Whirlpool Heating & Cooling Experts
    Dan Webster
    Dan Webster
    Bill Long
    Tim Whalen
    Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
