Question about Frigidaire FMT148GP Microwave Oven
Everything works but it will not heat. which is the most likey problem? i don't smell or hear anything unusual. 1) magnetron 2) diode 3) capacitor
  • Frigidaire Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Sep 30, 2010
Can't get to heat anything can't seem to set clock first Hamilton beach model hbp90d23al any suggestions
Step 1:
see this steps and diagram and fix it. God bless you
Microwave Doesn't Heat
1)Diode
The high voltage diode converts the A/C power output of the transformer to D/C, doubling the voltage to nearly 5,000 volts. This high voltage powers the magnetron which emits the energy that cooks the food. If the diode burns out, a lower A/C voltage reaches the magnetron, which is not sufficient to power the magnetron. When the diode fails it is often visibly burned out. If it appears to be good, it can be tested with a volt-Ohm meter capable of testing diodes. High voltage diodes frequently fail and are one of the most common points of failure in a microwave oven. A regular meter with a diode checker will not work to check these diodes. You have to use a meter with a 9 volt battery or put a 9 volt battery in series with the diode to check it.
Door Switch
If the microwave does not heat, one of the door switches might be defective. Microwave ovens normally have three door switches, if any of them fail the microwave does not turn on and does not heat. Check the switches for continuity with an Ohm meter.
Magnetron
If the microwave oven doesn't heat the magnetron tube might have burned out. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. If the microwave oven is turned on when it is empty this can cause the magnetron to burn out. Once it is burned out it has to be replaced, it's not repairable.
High Voltage Capacitor
If the microwave doesn't heat the high voltage capacitor might be defective. The high voltage capacitor works with the high voltage diode to convert the output of the transformer to DC voltage and to double the output voltage. If the capacitor is burned out the entire high voltage circuit stops working properly. The high voltage capacitor can be checked with a special VOM meter which has a capacitance testing capability. Be aware that the high voltage capacitor can retain a charge of more than 3,000 volts and can injure or kill a person if not handled properly. Only trained technicians should perform this type of testin
High Voltage Transformer
If the microwave does not heat, the high voltage transformer might be burned out. Microwave ovens produce a very high voltage in order to power the magnetron antenna, which emits the energy that cooks the food. When a high voltage transformer fails it will usually arch and have a burning smell
Thermal Fuse
If the microwave doesn't heat the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Thermoprotector
If the microwave doesn't heat the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.
Step 2:
Feb 07, 2013 | Microwave Ovens
Sanyo EM-SL40S microwave everything seems to be working fine but food doesn't get hot?
see this causes and fix it. GOD BLESS YOU
Power Diode
A diode is an electronic component that readily passes current in one direction only and blocks the flow of current in the opposing direction. If your microwave's diode has become defective, your microwave will not heat and you will hear a buzzing noise. Test the diode to determine if this is the cause of your problem. Replace it if it is defective.
A capacitor is an electrical device which stores electricity. A defective capacitor may be why your microwave is not heating but you are hearing a buzzing or humming noise. The capacitor will have to be tested to determine if this is the cause of your problem. A defective capacitor will have to be replaced before your microwave will work again. Make sure you discharge the capacitor before you test it, though.
Magnetron
A defective magnetron is the third possible cause of why your microwave is not heating, but you can hear a buzzing noise. Test your microwave's magnetron. Replace it if it is defective.
Thermoprotector If the microwave doesn't heat the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.
Main Control Board If the microwave doesn't heat the main control board may be defective. This is not common. When a microwave doesn't heat the problem is usually within the high voltage circuit; either the high voltage capacitor, diode, transformer or magnetron.
High Voltage Transformer If the microwave does not heat, the high voltage transformer might be burned out. Microwave ovens produce a very high voltage in order to power the magnetron antenna, which emits the energy that cooks the food.
Oct 01, 2012 | Microwave Ovens
It is making a funny noise plus has an electrical burning smell and won't heat.
The funny noise is usually called a humming sound. When the microwave begins to bring out this type of sound, it refuses to heat. Below is troubleshooting tip and a fix;
Investigate these three areas if your microwave won't heat and you hear a noise....
Power Diode
Testing a diode
NOTE: Before you test your diode, make sure your microwave is unplugged, and that you discharge the microwave's capacitor.
Whether it is shorted or open, a defective diode will most likely show some sign of defect. Defective diodes will usually emit an electrical burning smell, signifying its defectiveness. Also, it may have split in two, or it may exhibit a burned crack, or possibly even a blistered spot.
A shorted diode is indicated by a loud humming noise from the high voltage transformer, and no heat produced when a cook cycle is initiated. Whereas little or no heat produced in your microwave, with an absence of a humming noise is indicative of an open diode. In either case, the diode has to be replaced.
With your microwave unplugged, and your capacitor discharged, use extreme caution to remove the lead that leads to the capacitor. You can leave the ground connection attached. The side of the diode that goes to the ground is usually marked with a dot, stripe, or arrow. Set your ohmmeter to R x 10,000 or higher. Touch the positive meter probe to the anode and the negative meter probe to the cathode to measure the resistance across the diode terminals. Remember that the cathode is on the side that goes to the ground, which is often marked by a dot, stripe, or an arrow.
A normal diode, that is a non-defective diode, will read anywhere from 50,000 to 200,000 ohms. Differences in microwave make and model account for this large range in resistance readings.
Reverse the meter probes and measure resistance while touching the positive probe to the cathode and the negative probe to the anode. Reversing the probes like this should result in a reading of infinity. Unless a bleeder resistor is present. The presence of a bleeder resistor would produce a reading of the value of the resistor.
Magnetron
Testing a magnetron
NOTE: Before you test this component, make sure your microwave is unplugged, and that you have discharged the capacitor.
There are two tests to conduct in order to determine whether or not a magnetron has become defective. If you receive results other than what are detailed below, you will have to replace your microwave's magnetron. Each test is described for you here:
TEST 1: Locate your magnetron and label each of the wires attached to it so that you know which wires are to be replaced where. Set your ohmmeter to the lowest resistance scale. Take a resistance measurement between each of the magnetron's terminals by touching each probe to one terminal each. Reverse the probes and take a second resistance measurement. Each measurement should read less than one ohm.
TEST 2: Set your ohmmeter to its highest resistance scale. Touch one of the meter's probes to a magnetron terminal. Touch the other probe to the metal magnetron housing. Take special caution to not touch the two probes together. This could result in an inaccurate reading. This test should produce a reading of infinity - indicating an open circuit.
Read the tips on the below links on how to replace your microwave oven's diode and how to discharge the capacitor.
http://www.fixya.com/support/r7088355-replace_microwave_ovens_diode
http://www.fixya.com/support/r7088317-discharge_microwave_ovens_capacitor
I hope the above is helpful.
Apr 10, 2011 | GE Microwave Ovens
It just started making a louder humming noise and now it doesnt heat up anything at all? any suggestions?
Investigate these three areas if your microwave won't heat and you hear a loud buzzing or humming noise:
Power Diode
Testing a diode
Magnetron
Testing a magnetron
Take care.
Feb 15, 2011 | GE JVM1850 1000 Watts Microwave Oven
My microwave does not heat up any food at all but everything else works
Investigate these three areas if your microwave won't heat;
Power Diode
Testing a diode
Magnetron
Testing a magnetron
Good luck.
Feb 01, 2011 | Whirlpool MH1150XMQ Microwave Oven
Ge jvm 1653 won't heat
You've got a problem in the microwave circuit, which could be one or more of the following components -
1) HV diode
2) HV Capacitor
3) HV transformer
4) Magnetron
I am leaning to the diode, but it would take further investigation to determine for sure. Diodes are cheap, as if the capacitor, and replacing those first would not necessarily be in vain if it turns out to be the transformer or magnetron. And I would be most inclined to say it's the magnetron before I would think transformer.
Reply back what you find or if you have more questions.
Feb 04, 2009 | GE Microwave Ovens
Everything works except heat
Sounds like you've had a failure in the microwave portion of the unit.
Microwave not heating problems when the timer/controller board appears to function properly, are related to the following components -
1) Diode
2) Capacitor
3) Transformer
4) Magnetron
Jan 24, 2009 | GE JE1540 Microwave Oven
Microwave doesn't heat up
There are three solutions (source) =>
http://www.partselect.com/repair.aspx?appliance=microwave&part=no-heat
Power Diode
Magnetron
Dec 31, 2008 | Microwave Ovens
2 1/4 year old GE Spacemaker XL 1850 Microwave doesn't heat
Check this website:
http://www.partselect.com/microwave+no-heat+repair.htm
It sounds like it is either the power diode, the high voltage capacitor or the magnetron. If it is the magnetron, it may not be worth fixing as these can cost well over $100.
Do you hear a buzzing sound?
Dec 13, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
No heat
If you can't fel the cooling fan blowing air out the back, then that increases the chance you have a bad magnetron. Since this is 1-1/2 months old, it is still under warranty. I would call GE or Sears for warranty service. If you break any seals opening it up, you'll void the warranty. It's almost certainly not the capacitor, those virtually always short when they fail, resulting in a blown fuse. If the transformer's bad, there is often the smell of electrical burning, but the cooling fan may weaken the smell. Try smelling the fan exhaust after it has run. It's most likely the magnetron, from my experience, but it could be a shorted HV diode. Some GE models sem to have had a batch of bad magnetrons, but I don't know if they have publicly acknowledged that. Again, since it's under warranty, the best bet is to call the manufacturer or an authorized GE servicer. You can find those numbers in your owner's manual and need to have your sales receipt handy of course when you call. Good luck.
Oct 17, 2006 | GE JVM1650SH Microwave Oven
Frigidaire FMT148GP Microwave Oven Logo
109 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
