Question about AO Smith A O Smith Motors Century 1hp 115v Thru - Bolt Lomart Motor - Bv90
Getting loud and leaking Where is the cheapest
Getting loud and leaking Where is the cheapest place to buy a 1hp with pump
    Novelist:
  • 116 Answers
Before you buy a whole new pump, you can replace, or rebuilt just the motor. Your problem is a little vague, are you running this on a pool pump? you said it's leaking. If it it is leaking at the pump shaft seal this is easy to replace, and if the motor is getting load the bearings are probably going out.. you can buy a motor online, or at any pools supply house and replace it yourself, or have them do it. If your not familiar with this type of work, I would recomend taking the motor, or the whole pump into a pool pump repair shop. they will completely rebuild it for you with a new or rebuilt motor depending on your preference. Hope this helps. If you need further assistance post a reply in the comments, and don't hesitate to leave a good thumb rating if you found this helpful. Thanks, and good Luck!
Posted on Sep 30, 2010
Testimonial: "excellent and quick response"
  • Derek
    Derek Sep 30, 2010
    wow, lot of spelling errors in that. Sorry guess I should have spell checked that first. Anyway, glad it helped!
I HAVE A BAD 1HP SUPER PUMP MOTOR CAN I CHANGE IT OUT TO A 1.5 HP SUPER PUMP MOTOR
yes it should be a direct swap ask the place you buy the new one from they will know for sure
Jun 25, 2014 | Hayward 1hp Super Pump In Ground
When pump runs it is very loud
depending on the noise, it could be cavitating, due to air leaking into the inlet side, or it could have faulty bearings. If its a screechy noise, then probably bearings.
Dec 10, 2013 | Goulds Pumps 1HP J10 Deep Well Cast-Iron...
I just installed a us pool pump motor eb841 1hp 3450rpm 208volt 56y and it is leaking water behind the square bell housing actually leaking bottom side of motor
There is a leaky water seal on the pump shaft housing between the pump and the motor.
The drain hole prevents water from going into the motor and this seal needs to be replaced before the motor is damaged.
Aug 19, 2012 | A O Smith Motors A O Smith 1hp 115/230v Ur...
Will a smith 1hp pump fit in place of a hayward 1hp
as long as the frame size matches i.e. 56J in this case then you should have NO issue with changing the motor mfg.
US Parts Center
Aug 18, 2011 | Hayward 2HP Pool Pump Motor A O Smith...
Just purchased a new super pump 1hp, but it is
Can you be more descriptive? My guesses are that the motor is wired wrong, the motor is defective, There is a leak in the supply line or the pump and air is getting into the pump, causing the pump to cavitate.
Jun 02, 2010 | Hayward 1HP Super Pump II Inground Pool...
Squealing bearing
Thank you for posting your question here on Fixya.com.
The seal would be cheap assurance since it is likely what caused the bearing to fail in the first place. The impeller only needs to be replaced if it is cracked in such a way that the seal can not properly seat and prevent water from leaking. Generally speaking, it does not have to be replaced. You can get the bearings and seal from a local electric motor repair shop or pool store that offers repair services.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Feb 14, 2010 | A O Smith Motors A O Smith 1hp 115/230v Ur...
AO Smith A O Smith Motors Century 1hp 115v Thru - Bolt Lomart Motor - Bv90 Logo
199 people viewed this question
Top AO Smith Pool & Spa Experts
Jay Finke
Jay Finke
Steve
Larry Maranto
Are you an AO Smith Pool and Spa Expert? Answer questions, earn points and help others
