Question about Epson Computers & Internet
Pulled paper out of a paper jam.did I ruin it?? No printing...cost more to fix it, than get a different one? valrobinson36@yahoo.com
What model
Posted on Sep 30, 2010
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
Paper jam
Your having a hardware issue and you need to have it serviced.
We know that having a printer serviced/fixed costs more than buying a new one, check out this link http://www.epson.com/loyalty .
Mar 27, 2008 | Epson Stylus C86 InkJet Printer
Fix repeated paper jams on Lexmark 901 Pro
If you are getting a jam and there is no paper visible then a likely cause is a false jam that is caused when the paper is not picked up from the tray at the start of printing. Send a print job and listen closely. If you can hear the pickup rollers turning but no paper is being pulled into the printer then either the rollers are dirty or are worn and need to be replaced. Trying printing from a different tray or the manual feed tray to eliminate a fault with a different component on the printer.
Oct 14, 2014 | Lexmark X Office Equipment & Supplies
Paper jam at exit
Besides setting it for card stock both in its internal menu and the pc's menu, are you setting it for legal size paper? The timing will be thrown off if that step is missed. It will stop pulling the paper because it is looking for 8.5 x 11" paper. I would test with less expensive card stock to also make sure a shard of the decal paper did not get left in the paper path. The card stock should help dislodge any debris in the paper path.
Apr 01, 2014 | Xerox Phaser 6125 Laser Printer
Hi, there is continous paper jam flashing light indicated at the printer (epson 600). i have checked but i found nothing jammed. i wounder i could be the reason. your support is...
Sorry - no solution, except to perhaps agree with the guy who says throw it out the window. I only wish I wasn't just on the first floor. This thing does more jamming than printing. It claims a jam when there is none. Infuriating.
Nov 06, 2010 | Epson WorkForce 600 All-In-One InkJet...
I have a brother mfc 7420 and every time I print it tells me paper jam, I pull the paper tray out fix the paper push start it tells me paper then I have to pull out the cartridge and pull out the paper...
Sounds like there is something in the paper track that's causing this to jam. Its not always easy to get small particles cleared just by removing the jammed paper.
This may not help everyone that I send it to, but it is worth a try.
I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press
the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer.
The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Sep 20, 2010 | Brother MFC 7420 All-In-One Laser Printer
Printer Problem...
There is a jam somewhere preventing the proper routing of the paper. Try following it through and isolate the problem
Jun 16, 2010 | HP PSC 1510 All-In-One InkJet Printer
Paper pulls to the right, jams, won't print, tried different paper still won't print
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Hope that helps!
PREM
May 26, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Paper jam
This is bad news for these printers. Paper jams tend to ruin the print head. To get the paper out, first remove the print head and ink, if possible. Then go in back of the printer and at the bottom there's a piece that can be pulled out. That piece is hard to get in so take very careful not of how it looks as you pull it out so you can put it in the same way. The piece is sunk into the printer a bit and you got to pull by both ends of it. From there you should be able to pull the paper out. When done, put that piece back in and put the print head and ink back into the printer. The reason for removing it is to minimize any further damage it might get from pulling on the paper under it. Also be sure to put the print head on a paper towel and do not put the circuit board/contacts of it touching anything.
Mar 28, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Printing
Do not continue this way, you are sure to ruin your paper sensor or the like. Most probably you have a paper jam inside near the carriage or roller. Open at front, check inside for paper jam.
Jan 22, 2008 | Canon PIXMA MP180 All-In-One InkJet...
Computers & Internet Logo
Top Epson Computers & Internet Experts
teamtech
teamtech
Are you an Epson Computer and Internet Expert? Answer questions, earn points and help others
