Question about General Electric Stove/Oven/Range Chrome Timer Knob Set - WB3X459
The oven and the left side of the ranges do not function.I have tried to change the fuses but it did not help. Are there hidden fuses beside the ones at the bottom of the panel?
    President:
  • 1,311 Answers
First, you need to provide the model number of the stove. Second, have you checked to make sure you have power on both legs of the 220V feed to the stove?
Posted on Sep 30, 2010
Kichenaid khhs179ll1 fuse
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You can view a YouTube video showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Jan 30, 2013 | KitchenAid KCMS145J Microwave Oven
Microwave wont start shows door on display
When it shows a door error and won't start, that's usually a door switch or door switch mount. My help file on door switches is here.
BUT - assuming your model is the KEMS308SSS01,02,03,04, or 05, it is probably the type that has the overdesigned door sensor circuit, as shown in the diagram below:
In this case, the other likely culprits (besides the door switch) are the 20A fuse, the 15A fuse, the "cavity TOD ("thermal overload device" - thermal cutout / thermostat) and the magnetron TOD.
It also contains the diagram above.
There's a YouTube video available showing how to remove a typical over the range control panel assembly in under 5 minutes. mini_manual_behind_grille_small.jpgdee77f7.jpg
Accessing the oven cavity TOD for testing and possible replacement will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download Kitchenaid / Whirlpool owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Dec 27, 2012 | KitchenAid Kems308Sss 30" Microwave...
Model MHV350E....replacing lamps and shorted-out....power to receptacle but no power to unit.
Whenever the cooktop lamps blow or when they are removed or installed while the oven has power, the filaments can internally short, causing a surge which can blow the microwave's fuse and damage the circuit board.
I would suggest that you first check and replace the fuse in the oven.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If replacing the fuse does not restore all functions, we regularly repair these controller assemblies nationwide by mail for $39.95 postpaid with a one-year guarantee.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Dec 08, 2010 | Amana Microwave Ovens
Hi ..Our Microwave stopped working. It is a GE Microwave- Convection Oven in wall combo with control panels for both ovens shared. Convection oven works fine. Microwave has no power...it is dead. ...
There is often a fuse and a magnetron thermal fuse or thermostat.
You can find links to helpful exploded view diagrams and order parts here.
Dec 02, 2010 | GE JE1460 Microwave Oven
Connection of safety switches that control the doors and other functions for the microwave to work!!!
Our door switch help file is here.
Sep 30, 2010 | Amana ACM1580 Convection Microwave Oven
Jenn Air Microwave builtin oven has no display and will not turn on. Had the power to the oven checked and it's ok. The oven stop working when it was on. The oven is 17 years old.
You should check the internal fuse as well as the oven cavity thermostat / thermal cutout and the magnetron's thermostat / thermal cutout.
Aug 23, 2010 | Jenn-Air JMC7000 Microwave Oven
How to change fuse on je2160sf02 ge microwave
Also at our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
I would also suspect the thermostat associated with your magnetron.
Feel free to contact me directly (and please remind me of your full model number) for more information & help or see our Web site.
William E. "Ed" Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
May 27, 2010 | GE JE2160 Microwave Oven
KitchenAid microwave #kcms135gss just stopped working no clock display , changed to diff outlet still nothing
You probably have a blown internal fuse or thermostat (one is on the top of the cavity and one is on the magnetron).
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
You can find links to helpful exploded view diagrams and part ordering help here. I'd recommend that your bookmark this link to your favorites.
Dec 05, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
How do you replace the fuse in a microwave oven.
Be sure the oven is unplugged or the breaker is off.
d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
You can also find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Let us know if we can help further.
Jun 04, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Blown Fuse on a Microwave
You can usually find exploded views and order parts by entering your model number at the Sears parts site.
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
Let us know if you need further help with torubleshooting.
Nov 28, 2008 | Kenmore 62702 Microwave Oven
General Electric Stove/Oven/Range Chrome Timer Knob Set - WB3X459 Logo
116 people viewed this question
Top General Electric Hardware & Accessories Experts
jdthefixer
pawnpower
Are you a General Electric Hardware and Accessory Expert? Answer questions, earn points and help others
