Question about Magic Chef Chest Freezer MCCF5WBX
Lights up and runs but wont freeze compressor gets warm but not hot how do you ck the feon
  • 316 Answers
As a do it yourselfer you will not have the tools, knowledge or experience to check the precise amount of refrigerant. You would have to recover the refrigerant into a recovery bag to weigh the amount. However, if you put an ampmeter around the lead going to the common terminal of the compressor, you can determine if in fact the compressor itself is running, or trying to start itself. If it is running, yet not cooling enough or at all, you likely do have a leak of refrigerant, and to properly repair your freezer would be very expensive.
Posted on Sep 30, 2010
My 26lb silver portable ice maker wont make ice?? Any suggestions???
does it run? does the compressor run, does the fan run, is the air flowing across the outside radiator, is the air comiing out warm? is there a waterpump and does it run? Does anything get cold and does anything get hot?, it should be. These are my suggestions to look for in your unit
Dec 31, 2014 | Igloo Cooler Igloo Portable Countertop Ice...
Compressor runs but wont cool
Make sure the compressor is running it should be vibrating and get warm after a few minutes. If it is indeed running the smaller tube to the compressor should be getting warm if not it could very well be the compressor has stopped pumping. If the fans are not running they could be controlled from the control board and will come on when the sensors on the evaporator get to a certain temperature. I does sound like the compressor is the problem.
Apr 04, 2014 | Samsung RFG297AAWP 28.5 Cu. Ft. French...
Fan does not come on nor does door light. Also will run to cold temp when it cycles off cabinet warms up very quickly
have you checked the door switch for each door? the lights should still work in defrost mode but not fans or compressor.
Jan 08, 2014 | True T23F Commercial Freezer
On a up right freezer the red light comes on and stays on and everytihng defrost what could be wrong
I want you to feel the top of the compressor to see if hot or too hot to keep your hand on the top. Click Here for a photo of the=> FFU2124D System Components item 30 is the 216649315_Relay-and-Overload-Kit item number 55 is the=> 5304464438 Run Capacitor
If the compressor is too hot to keep your hand on top it may be the=> 216649315_Relay-and-Overload-Kit
Let me know if the compressor is hot and we will know the compressor is trying to start but cannot. Replacing these parts will possibly solve the problem of your freezer being on but not freezing everything, We need to make sure the compressor is running, Thanks Sea Breeze
Nov 28, 2012 | Frigidaire 20.6 cu. ft. / 583 liter...
The freezer won't run so how us it that the compressor is very hot after several hours?
ice cream is always the last to freeze and a temp of minus -10 degrees is usually required to get it to get hard. if you put the ice cream in the door it will be especially tough to freeze. a good thermometor is a good investment as you can observe the temps. usually ten degrees or 20 degrees is what they run. yes they do cycle on and off as long as they hold temps thats good. the outside of the freezer gets warm because the hot compressed refrigerant is spread through piping near its surface giving up its heat of compression . setting the stat to max will freeze the ice cream eventually but utility bill suffers . good luck
Sep 10, 2012 | Danby 3.6 cu. ft. / 102 liter Chest...
Sub zero freezer - 501 f
It is likely the condenser fan is not functioning. You may need to open the compressor access panel to check. If you can hear the compressor running, and the condenser feels warm, the fan should be running. If it isn't, it probably needs to be replaced. Another symptom is the area around the doors feels warm.
Jun 19, 2012 | Sub-Zero Freezers
Kenmore Refrigerator Ice Maker
ck condensor fan motor that cools compressor under unit. yoder loop runs through center divider and causes gaskets to get hot
Aug 26, 2009 | Kenmore Freezers
Loud bang
John,
What you are hearing is popping caused by thermal expansion inside the evaporator enclosure during its' defrost cycle.
Depending on your make and model, it'll go into defrost every 8 to 12 hours of compressor "run time". That is, the defrost timer "monitors" how long the compressor runs and after it accumulates the pre-set "run time", the timer then shuts the compressor off and initiates its' programmed defrost routine. This routine lasts for 20-30 minutes, or until the defrost thermostat opens.
The defrost routine sends 120 volts to a heating element in the evaporator compartment which gets red hot. This sudden temperature change (from below freezing to warm) causes the cabinet to expand slightly. That's when you hear the "Pop".
I hope this helps, John. Thanks for using FixYa, and don't forget to rate my answer.
SG
Apr 02, 2009 | Freezers
Wont freeze
When changing the battery it should be a alakline. Also try unplugging the unit and then back in again. Check to see if the sides are getting warm which will indicate the compressor is running. Make sure the compressor is running. Check to see if thermostat is up high enough. The unit may have an electronic board that may be the problem. And lastly, it could have a sealed system problem, like a freon leak. You didn't say how old the unit is.
Aug 30, 2008 | Kenmore 8.8 cu. ft. / 249 liter Chest...
Used frigidaire
look around the back of the freeze and at the bottom you will see a small black compressor .Put your hand on it and if it is running you will feel it vibrating. If it vibrating but running very hot them it means you have no gas in the system so the freezer won't freeze. If the compressor is cold and not running then it could be eaither the relay on the compressor or the board on the front either way you will need to get an engineer in
Dec 11, 2007 | Frigidaire 5 cu. ft. / 142 liter Chest...
Magic Chef Chest Freezer MCCF5WBX Logo
214 people viewed this question
Top Magic Chef Freezers Experts
Dan Webster
Dan Webster
AJMAL KHAN
Tom Chichester
Are you a Magic Chef Freezer Expert? Answer questions, earn points and help others
