Question about Brother HL-2040 Laser Printer
HL-2040 Laser printer hangs at 32%
My problem started when I changed the toner cartridge and couldn't getthe printer to recognize the cartridge. I used the solution suggestedon another post where you turn the power off, open the door, hold thebutton down, press go 2x, then go 5xs (who ever thougth of THATsolution....) but now after I have reconnected everything I am gettinghung up at soemwhere around 24 to 32%. I tried shutting down andrestarting to no avail. I am using a USB hub and all the otherperipherals on it work fine. I have switched over to my backup printeran HP Inkjet and then I can print. But I like my laser printer's printsso much better! Any suggestions?
  • madpt Jun 05, 2008
    I still get hung up abaout 32% and will get a message : "GenericClasswaiting for device" DOes anyone know what this means? ANd any other possible solutions?
    Genius:
  • 3,587 Answers
One suggestion..this printer likes it better when it's on a direct usb connection..
Posted on May 25, 2008
How do I remove the toner cartridge on HL 2040 ?
Open front cover and pull out the toner cartridge with drum unit. To release toner cartridge from drum unit just push blue lever down and lift up toner cartridge.
Feb 01, 2011 | Brother HL-2040 Laser Printer
How do i change the toner on m my HL 2040 brother printer
How to Change a Toner Cart in a Brother HL 2040
The Brother HL 2040 laser printer has a toner cartridge that supplies toner to the drum assembly so that the printer can print properly. When the LED on the front of the printer indicates you are low on toner, you will need to replace the toner cartridge to maintain good print quality. Fortunately, the toner cartridge can be replaced without any special tools.
Instructions
Things You'll Need:
* Replacement toner cartridge (part number TN350 or TN360)
* Paper towel or scrap paper
Grasp the front cover of the printer and pull it toward you to open the toner door. Reach into the printer and grab the combined toner cartridge/drum assembly. Lift up slightly and pull it out of the front of the printer.
Place the cartridge and drum on a paper towel, spare sheet of paper, rag or other surface that can get dirty. Loose toner particles may spill from the cartridge.
Press the blue locking lever on the cartridge/drum unit to unlock the toner cartridge from the drum. Lift the toner cartridge up and away from the drum unit. Dispose of the old toner cartridge in accordance with your local regulations. Seal it in a plastic bag to keep loose toner from spilling.
Gently shake your new toner cartridge back and forth a few times to distribute the toner evenly across the width of the cartridge. Remove the plastic protective cover from the bottom of the cartridge.
Place the new toner cartridge onto the drum unit and press it down gently until it locks into place. The blue locking lever will automatically click into place. Verify that the toner cartridge is securely connected to the drum.
Locate the corona wire cleaner tab at the front of the drum unit. Slide it back and forth several times to improve the print quality of the drum. Set the tab back in the home position when finished.
Slide the combined toner cartridge/drum unit back into the printer and close the front cover.
Hope it helps...
Dec 02, 2010 | Brother HL-2040 Laser Printer
PROBLEM
You must determine what the problem: the printer or cartridge. If this problem started after refilling the cartridge means a cartridge forgot to put the flag is reset. It is done very simply: removed the side cover of the cartridge and the flag of one unit in the top position.
If the cartridge is all right, for example, you put a new cartridge and the problem persists, then to examine the sensor for detection of a new toner in the printer. Get the toner and drum cartridges. Inside the printer at the top left you will see a white leg sensor. About her. It should be on the spring and should not hang in one position. That's all:)
Jul 27, 2010 | Brother HL-2040 Laser Printer
I have a Brother HL-2040. One whole side of the printed document is faded and blank. How can I fix this problem? I am making the assumption that the toner is not empty since the light is not on. Is...
I wouldn't assume that you aren't out of/low on toner.
Try taking out the toner cartridge and tap/shake it to disperse the toner that is left in it. If that changes the way it is printing, it is about time to replace that cartridge.
Jul 07, 2009 | Digital Products Brother HL-2040 Laser...
Nothing prints
If you replace a new toner and sitll not working then you should push and hold on start buttom for 1 min
Feb 23, 2009 | Brother HL-2040 Laser Printer
Brother HL 2040 toner light flashing
Push the start buttom and hold for 30 sec.
Nov 26, 2008 | Brother HL-2040 Laser Printer
Brother HL 2040 won't print
Sounds like the toner cartridge is faulty. I would change the cartridge.
Nov 19, 2008 | Brother HL-2040 Laser Printer
Changing the toner on a brother HL-2040 in my office
It should be one unit??? look at the toner cartridge and look for a shiny cylinder that is the drum.
you can google brother hl2040 drum and click on images on the top right of google to see what it looks like
Aug 21, 2008 | Brother HL-2040 Laser Printer
50 Copies Per Toner Cartridge?
sounds just like the 'idiot' lights for oil changes on your car..how about this..100 copies from replacement, does the light go on?
http://tinyurl.com/6qcpgy
Aug 18, 2008 | Brother HL-2040 Laser Printer
I put a new toner cartridge in and the toner light remains on and will not print.
Actully i have hl-2040 brother printer
the problem is no lights are on
ready light not started plz give
me suggession my mail id is gmcharankar@yahoo.co.in
Jan 08, 2008 | Brother HL-2040 Laser Printer
Brother HL-2040 Laser Printer Logo
42 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
