Question about Car Audio & Video
My radio works but i can see the display for changing stations
    Top Expert:
  • Car Audio & ... Master
  • 75,817 Answers
There are tiny light bulbs attached to the circuit board of most radios that supply the illumination to the face, some can be easily changed like in Ford radio, others are hardwired to the circuit boards and require a skilled tech to replace them
Posted on Sep 30, 2010
How to reset car radio on 1997 rav4 after battery change.....
turn it to the station you want. the hold the button down it should peep then the station should be set
Jan 10, 2012 | Audio Players & Recorders
How do you auto preset radio stations?
Hello
[1] Press RADIO BAND.AUTO PRESET until the band you want appears on the display [direct power ON]. Each time you press the button the indication changes as follows. "FM" => "AM"
[2] Hold down TUNE+ or --ve until the frequency digits begin to change in the display.
The player automatically scans the radio frequencies and stops when it finda a clear station. If you can't tune in a station, press the button repeatedly to change the frequency step by step.
If FM band is noisy, press the MODE repeteadly until "MONO" appears in the display and the radio will play it monatural. If FM radio signal at your area is very weak, this type of noise may occur. OK.
Sep 28, 2011 | Sony CFD-S350 Radio/Cassette/CD Boombox
Changed battery now radio will work on am only when i push the am/fm button the display reads set1
When you replaced the battery, it reset the radio. You will need to reprogram the radio stations you want on fm. Find the radio station you want and then press the set button on the radio and then the corresponding number on your radio (ie: set1, set2, set3, set4 or set5)
Feb 27, 2011 | 1995 Jeep Grand Cherokee
RDS failure?
some stereos you have to input the name of the station yourself.
May 05, 2010 | Sony CDX-GT310 CD Player
How do I change the radio station on the radio alarm
Here is the full manual
http://www.timexaudio.com/pdf/T311IB57574_35.pdf
Here are the instructions from the manual.
Setting the Radio Alarm
1. Press and hold the
Radio Alarm Button. The display will flash and the Radio Alarm Indicator will
appear. If you do not begin setting the time within ten seconds of pressing the button, the display will stop
flashing and you will need to press the
Radio Alarm Button again.
2. While the display flashes, press the Reverse and  Forward Buttons to set the wake time. Hold a button
for a few seconds to set the time rapidly. Be sure to set the correct AM/PM time, as shown by the PM Indicator.
3. After setting the radio alarm time, you will need to select the station. First, press the  Radio Band Button
to select a radio frequency. Next, select a station using the Memory Set 1-6 Buttons. For more
information on programming radio stations into memory, see the Programming Radio Station Settings section
of this manual. Rotate the  Volume Thumbwheel to set the wake sound volume.
4. After setting the radio alarm wake time and sound, you will need to select the 7-5-2 setting. The 7-5-2 setting
lets you set the alarm for a full week, weekdays only, or the weekend. Before setting the alarm, be sure that
the correct date is set, as shown in the “Auto-Set” and Manual Time and Date Settings section of the manual.
While the display is still flashing, press the  Date/7-5-2 Button until the desired setting is shown.
5. After you have set the radio alarm wake time, sound, and 7-5-2 setting, press the  Enter Button. The
Radio Alarm Indicator will appear on the display, showing that the radio alarm has been set.
Aug 08, 2009 | Timex T311T Clock Radio
Pioneer deh4000ub radio wont save
Six stations for each band can be stored. 1 Press LIST.
Preset screen is displayed.
2 Use MULTI-CONTROL to store the selected
frequency in memory. Turn to change the preset number. Press and hold to store. You can also store the frequency in memory
by pushing and holding MULTI-CONTROL right.
3 Use MULTI-CONTROL to select the desired
station. Turn to change the station. Press to select.
You can also change the station by pushing MULTI-CONTROL up or down.
To return to the ordinary display, press BAND/ESC or LIST.
Jul 18, 2009 | Pioneer DEH-400UB Car CD/ MP3 Player
Radio display says SAFE and will not play music
You need your radio code its 4 numbers, you use your radio preset station button to change the # press the 1 station button till you put in your code then the # 2 preset station # then 3, then fourth preset. You should find your code in your service manual. when your code is in, press the + or - button on the station search, or refer to your manual. good luck
May 12, 2009 | 2002 Volkswagen Cabrio
No radio text display on vauxhall corsa
model cdr 2005 radio/cd player works fine except there is no display above where the radio station2_bing.gif/cd track number is supposed to be displayed. I have time and temperature as normal
May 07, 2009 | Car Audio & Video
Manually change radio stations?
Here is how to manually tune your radio.
1 Press the SOURCE button until a radio
frequency appears in the display.
2 Press the BAND button repeatedly until the
desired radio band is displayed.
Each press changes the band:
→ F1(FM1) → F2(FM2) → AM
3 Press the TUNE button repeatedly until "DX
SEEK" and "SEEK" disappear from the display.
NOTE
The initial mode is DX SEEK.
4 Press the g DN or f UP button to move
downward or upward one step respectively until
the desired station frequency is displayed.
NOTE
The ST indicator or STEREO indicator appears on the
display when a Stereo FM station is tuned in
You can also look at your manual here for any other ? you might have
http://akamaipix.crutchfield.com/Manuals/500/500CDM7874.PDF
Dec 17, 2008 | Alpine CDE-7858 CD Player
Skifi xm
click on the display button until it shows the channel name
Aug 19, 2008 | Delphi SKYFi3 XM Radio Receiver
Car Audio & Video Logo
29 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
