Question about Sharp EL-531VB Calculator
How do you calculate logarithm base 2 on the Sharp el-531w
vladp995
  • 81 Answers
SOURCE: how to calculate
It's very simple: the calculators have a default base 10 so that log x it's log x base 10 so here is some logs:
log x base y = log x / log y
log (x*y) = log x + log y
log (x/y) = log x - log y
Hope it's helped
Posted on Jul 06, 2009
SOURCE: FIX numbers
If you press the setup key then 1 under FSE it will say TAB (0-9)? enter the amount of decimal places you want and it will change that for you.
Posted on Apr 20, 2008
  • 90 Answers
SOURCE: SHARP EL-531W HOW DO YOU CALCULATE MEAN,STANDARD
for the mean, just add them together and divide answer by the amount of figures you put in. as for the others, i'm not sure a standard scientific calculator will do that
Posted on Jun 11, 2009
  • 8073 Answers
SOURCE: how do I use sharp EL 531W to solve quadratic equations?
This calculator does not have a program to which you give the equation, and which returns the solutions. Sorry. You have to use the formulas you learned.
Let the equation be ax^2 +bx+c=0
You compute the discriminant Callit disc.
disc= (b^2-4*a*c)
1. If discriminant is larger than zero you have two solutions. Let us call them x1 and x2.
Then x1=(-b+square root of disc)/(2*a)
and x2= (-b-square root of disc)/(2*a)
2. If disc=0 , square root of disc =0 and x1=x2=-b/(2*a)
3. If disc is negative, there are no real solutions.
To find the solutions you replace a, b, and c by their numerical values, to calculate disc, its square root, and calculate X1 and X2.
Hope it helps.
Posted on Sep 17, 2009
SOURCE: I have a Sharp EL-531W.All keys work except for sin cos tan hyp.
No solution, but I have the exact same problem with a Sharp EL-531W calculator. Doesn't matter whether mode is degrees, radians, etc., and resetting with button in back has no effect.
Posted on Aug 19, 2010
Log2(0.25)=-2
You can compute the logarithm of x to any base by computing log(x)/log(b) or ln(x)/ln(b). So, press
ln . 2 5 / ln 2 = or
log . 2 5 / log 2 =
Oct 01, 2013 | Sharp EL-531VB Calculator
I cant figure out what is the shift key on my calculator. I have a Sharp EL-531W. I tried the 2NDF key and its not coming out right.
Regardless, that is the markings on the SHIFT key on Sharp Calculators. The 2ndF key accesses the functions that are marked on the face of the calculator, not on the top of the keys.
Sep 16, 2011 | Sharp EL-531VB Calculator
How to calculate logarithms using SHARP EL-531WH
you can press the "log" button or the "ln" for logarithmic calculations. the difference is just that "ln" calculates log on base "e".
Feb 18, 2011 | Sharp EL-531VB Calculator
Feb 26, 2010 | Sharp EL-501WBBL Calculator
Dow to get complex mode in EL-531W
This calculator has no Complex calculations feature. You cannot therefore enable it.The only solution is to get a calculator that has this function.
Nov 28, 2009 | Sharp EL-531VB Calculator
SHARP EL-531W HOW DO YOU CALCULATE MEAN,STANDARD DEVATION FREQUENCY OF 95,80,80,75,75,50
Jun 11, 2009 | Sharp EL-531VB Calculator
Sharp EL 531w . the calculator doesn't turn on.
Press the reset button on the back. If that does not work, batteries may be dead. Once you replace them press [ON/C].
Hope it helps.
Apr 15, 2009 | Sharp EL-531VB Calculator
How to calculate
Hope it's helped
Apr 09, 2009 | Sharp EL-520WBBK Calculator
Compound interest
http://www.sharpusa.com/files/cal_man_EL531_509.pdf.
Feb 16, 2008 | Sharp EL-531VB Calculator
FIX numbers
Dec 06, 2007 | Sharp EL-531VB Calculator
Sharp EL-531VB Calculator Logo
2,342 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
