Question about Acer Aspire 5100 Notebook
Losing Wireless Connectivety, when charging.
When I use my wireless broadband (Sky Netgear) everything works fine. Over the past year I have never had a problem until now. When I plug in my battery charger it stops my wireless connection. I thought this may be something to do with a powersurge, but even having the power plug in before turning the laptop on doesnt work (as wireless doesnt work when the laptop starts up). Ive spoken to Sky about htis problem and they think its to do with my laptop, does anyone know what it could be?? cheers.
Try to plug in the power cable alone, do it without the battery and see if your wireless works.  If your wireless works without the battery, and works with the cable alone it may be a battery conductivity problem.
Posted on May 25, 2008
I have a netgear wireless-g router wgr614 which i got with my virgin broadband but now iv changed to sky can i still use it ? cos it asks me for a pass code which i dont have can you help ? thanx
usually there is a reset button at the back. press it for 10 seconds and then let go. It is to reset everything to factory default. the code usually is "admin" or "Admin" without the quotation.
Feb 07, 2011 | NetGear WGR614 Wireless Router
I have Sky Broadband withe netgear router. Bought a netgear wireless adapter to use with my Advent PC. Installed everything. Good connection, but won't connect to internet. Keeps flicking from connected to...
HI,
Please follow the steps on a computer connected to the router so as to check the network key:
1. Open the browser(Internet Explorer or Mozilla Firefox).
2. Access the router usually http://192.168.0.1 else try http://www.routerlogin.com
3. Login to the router with the Username as admin and password as sky (unless you have changed it).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. Check if 'WEP (Wired Equivalent Privacy)' or 'WPA-PSK (Wi-Fi Protected Access Pre-Shared Key)' is selected under 'Security Options'.
6. If WPA-PSK is selected, copy the code entered in the passphrase.
7. If WEP is selected, copy the code entered in the key that has been checked.
This is the code required for connecting the wireless computer to the routers' wireless network.
In some cases, for security reasons the passphrase might show as asterisks. In this case type a new password and click apply. You will then have to use the same password for all the wireless devices connecting to the network.
scan for the wireless network on the computer with the adapter and connect to the network.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Aug 03, 2009 | NetGear WG111 802.11g/b Wireless Adapter
Sky netgear router
add your previus setting in your netgear router
fist you have contect with your pc and config and fist resert the all current seting
Mar 31, 2009 | NetGear RangeMax Dual-Band Wireless-N...
I have bought a laptop from someone and it has a edimax EW-7305Pg wireless LAN Cardbus. I am having problems connecting it to a netgear wireless router supplied by sky. I have sky broadband. I uninstalled...
is the mac address registered through your wireless router, your router maybe running wireless mac filter, if not try registering your wireless mac address on your router then try reconnecting your computer to your router.
Feb 01, 2009 | Computers & Internet
Wireless connection
i can't connect wireless int
Feb 01, 2009 | NetGear DG834G Router
Low signal from my wireless adaptor / router
Have you tried connecting the laptop in a different wireless network? Try changing the channel in your router and you may also upgrade the firmware of your router.
Oct 04, 2008 | NetGear WGR614 Wireless Router
Usb 2.0 wlan
I had exactly the same problem and had to go to the PC card Netgear WG511
for some reason the USB one conflicts with some things on certain laptops
I now am able to get the internet wirless on my laptop
good luck it nearly drove my crazy trying to get it to work!
hedgehog6865
Apr 02, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Blutoohth
Hiya, I have sky broadband too, with a Netgear wireless Router, your second pc needs a wireless card or usb wireless dongle to located wireless networks, once its installed you need the security key for the network, what equipment have you got?
Mar 25, 2008 | Computers & Internet
About wi-fi
Windows XP has a built in wifi configuration tool, previous versions of windows dont have this feature. But if you were to buy a wireless card it comes with software for wireless to work on all versions of windows from 98 - XP most if not all new laptops have wifi built in & that will be able to share your broadband connection through the netgear router. You can configure the laptop & pc to share files & printer between each other, easy way of doing that is by using the wireless network setup wizard which can be found in Start -> All Prograns -> Accessories -> Communications -> Wireless Network Setup Wizard.
Feb 10, 2008 | Computers & Internet
Acer Aspire 5100 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
