Question about Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft. Conquest Side-By-Side Refrigerator w/ In-Door-Ice Ice Dispensi...
My refrigerator still isn't cooling. Should I be concerned everything seems to be working fine the air just isn't cold enough. I plugged it in at 530pm yesterday
    Brigadier General:
  • 3,513 Answers
One of the reasons that your refrigerator may not cool properly is the condenser fan malfunctioning. The condenser fan is located on the bottom of the unit. Inspect the fan to make sure that the blades are in good condition and that it is turning with no obstructions. If the fan is not working or is damaged, simply disconnect the wiring and the fan by unscrewing it and replacing it with a new unit.
Please check this link bellow to troubleshoot your problem when the unit is not cooling:-
http://www.repairclinic.com/Refrigerator-Troubleshooting#Itsnotcool
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Posted on Sep 30, 2010
Amana fridge is not cold but freezer is working
If freezer is ok and cooling ( 5 degrees or less) one thing you might want to check is that the flow of cold air to refrigerator is not obstructed by the items in your freezer. The ductwork has to be available. Also check the opening of the damper if fridge is not cold enough. And is the fan operating at full speed - are the bearings dirty and slowing it down?
Also check your freezer temp - there are degrees of freezing. Water freezes at 32 degrees but a good freezer should go down to about zero. And the colder your freezer air is the colder your fridge will be.
Sep 21, 2017 | Refrigerators
My GE model GSH25JFTCBB side by side is not cooling in the fridge side. Freezer seems to be doing fine. What could be wrong
you could have a defrost problem,a bad damper,bad computer board.first thing,open the freezer door,do you hear the fan blowing in there?you should,if not the evap fan motor is bad,if it's blowing touch the back inside wall of the freezer to see if any frost or like snow is on it,from the bottom up in the freezer remove the second bin of food and touch the back inside wall with your hand,if it has frost or snow you have a defrost problem,bad defrost thermostat,heater,sensor or board,if there isn't anything on the wall then you have a bad damper,all that happens is the evaporator coil in the freezer gets cold,then the evaporator fan in the freezer blows the cold air over into the fridge section,you have a damper in your machine that opens and closes when it's cold enough or when it needs to get colder,the door on the damper isn't opening to let the cold air in when it calls for cold air.if you can write back and let me know what you find and hopefully we can get it fixed.
Sep 15, 2012 | GE Refrigerators
Hi, I have a Samsung refrigerator and the top part isn't cold enough and the freezer is working perfectly fine. I need help fixing the fan.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 03, 2011 | Samsung Refrigerators
Freezer appears to be working, but not the refrigerator section - at most that will only get to 50 degrees. Manually switching to propane makes no difference.
Sounds like your cooling fan is out. If the freezer is fine and the fridge isn't, then the cooling fan isn't blowing the cold air the the fridge. Or you could have ice obstructing the airflow.
Jul 01, 2011 | Refrigerators
Freezer seems to be working fine. refrigator does not seem to be cold enough
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 01, 2010 | Frigidaire FRT17G4B Top Freezer...
Fan running, weak air, fridge not cold enough, freezer working fi
it sound that your fridge is cloged of ice if so defrost it by unpluging it for the day to defrost completlyb with freezer door open then replace defrost timer if to much ice is formed on coil air does not cuculate properly thanks from gille
Feb 15, 2009 | Kenmore 64254 / 64252 / 64259 Top Freezer...
The freezer works very well but the refrigerator is not cool enough
check if fan in freezer is running , stryo is air diverter leave alone. ck frz temp rkm
Jul 11, 2008 | Frigidaire FRT21P5A Top Freezer...
Refrigerators Logo
80 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
