Question about Kitchen Ranges
I have an express 3200 bridge saw in my granite shop and it rotates and lifts up... but however now it does not rotate or lift up can you please tell me what could be the problem i have tried replacing the sensors on it but nothing works please help as fast as possible
  • 126 Answers
SOURCE: Brush won't spin when position of handle changes
The belt for this machine is very specific and only one size fits. It is not uncommon for vac shops to sell the wrong belt because the proper belt is not available from normal supply houses, so they will substitute something they think will work.
Also, assuming you do have the right belt, check the tension arm that drops down on the v-belt when the handle is brought back. This arm has a wheel/bearing with a plastic "tire" or trim that rolls on the belt to tighten it. Sometimes, this tire cracks and falls off and then the remaining bearing won't have the necessary tension to tighten up the belt.
Posted on Jan 27, 2008
SOURCE: Lifting the glass top to replace elements
I removed 2 screws under the front edge when you open the oven door
Posted on Jun 05, 2008
SOURCE: No spark in my 1992 Chevy Camaro RS 3.1L engine rotates but doesn't engage.
Hi Candie, if you have air, fuel and spark it should run. Getting to the fuel side-"is fuel getting into the engine?" Your ignition may work, your starter may work, fuel pump may work, but if you have an ignition key with a resistor inside it (little silver piece of metal in the plastic of the ignition key) the key, it could be bad and will shut down the fuel injector. It's part of the security system if some idiot tries to break the steering column to steal your car. It won't run.
I have a 92 Z28 with a 350 and I had to get a new ignition with resistor and correct resistor ohm key. About $400.00 bucks but if you search around Z28 forums there are ways to bypass this for less $$ if you want to.
Posted on Aug 22, 2008
SOURCE: Cannot remove oven pan
We had this problem a few years ago. It is a design defect, and it was fixed under warantee. The welds broke on the piece that was attached to the bottom of the pan.
Posted on Mar 01, 2009
canbruce75
  • 1776 Answers
SOURCE: Jayco lift system cable replacement
Try this link and see if it will help you any with the info that you need. Sure hope this helps you find resolution to the problem. Best wishes.
http://www.ehow.com/how_4708883_repair-jayco-camper-cables.html
Posted on Jul 23, 2009
I need to replace the filters for my vacuum but I cannot find them for model NV502. Help!
Which filter are you looking for? Is it the foam filter in the bottom of the unit or the HEPA exhaust filter?. Ive found both on Amazon. Amazon com 1 Shark NV500 HEPA Filter Fits Shark Rotator Pro Lift Away...
Mar 23, 2016 | Shark Rotator Professional Lift-Away...
Need the cam shaft specs Duration and Lift. 1971 Lincoln mark 111
go google and type in cam shaft specifications for ford v 8 engine
find a page that displays your engine size and the specifications will be there
what you want is expressed in degrees of rotation
Oct 03, 2015 | Lincoln Cars & Trucks
My Shark rotator is very hard to push at times, easy at other times. What makes it hard to push and how do I fix it?
Does it have a "brushes" lowering/higher switch?
Normally due to brushes being too low in particular on deep pile carpets??
check the actual fixings for the rotating brushes are ok and the brush not simply need "clicking" back into place?
Feb 12, 2015 | Shark Rotator Professional Lift-Away...
How do i open the waffle maker?
If it's the rotating type, it only opens when it's rotated in the correct orientation. The side with both Red and Green lights must be facing up. Simply rotate the handle to make these lights face upwards, and lift the handle up, which lifts only the top half of the waffle maker. If this doesn't work, it's probably defective.
Dec 28, 2014 | Kitchen Appliances - Others
Harmar AL435 wheelchair lift arm will not rotate in and out (fuse not blown) Winch and extendable arm work fine. Thanx for any help. Gary
Hallo, mayby late but I had last month the same problem. When you open the electric board wirh the rubber cover. It's on the side of the lift. When opend by the 4 screws you see the board. On the left side there is a red block with I think 6 or 8 white mini switches. First take a picture of the standing of these switches. After this you switch every switch a few times. After this your rotation will work again. It's ocydation of the switches. Succes. John from Holland.
Sep 10, 2013 | Harmar Hamar AL435 Lift - Axis III /...
Instructions on removing blade from jig saw model dw933
To remove a blade on this saw, lift the knob on the top of the saw and rotate the knob counterclockwise. This will open the blade clamp. The blade should slide out. To install a blade, slide a blade in, being sure the back of the blade fit against the support roller. Clamp the blade in place by turning the knob on top of the saw clockwise until you hear a clicking sound, then push the knob down.
Hope this helps.
Apr 26, 2011 | Garden
GE 15119 instructions please. The dial just says "time now." How do you know when light go on and off? Need directions. Can't believe there are none!
Here the help you need to set timer.
Rotate dial until current time lines up with black triangle located in center of dial
The black pointer remains stationary when you rotate outer dial
Now the outer edge of dial has 48 plastic segments that lift up
776e6ad.jpgHere are some segments lifted up on GE15207 timer
As I recall, segments-up timer OFF, segments-down timer ON
If you need more assistance, answer back and I will help
Oct 24, 2010 | Hardware & Accessories
Lost power,so I have to reset internal clock and I don't know how to do it.
On Intermatic timer
Lift dial and rotate dial until current time lines up with silver pointer.
On paragon timer
Lift dial and rotate until current time lines up with the word Time located to lower right of dial
If this doesn't solve the problem, please answer back and we'll get you going again.
Oct 23, 2010 | Intermatic T103 Indoor 120-Volt 40-amp...
How do I remove an engine from a 1999 Saab 95?
get rotating car lift. attach car to lift. rotate it upside down. motor will fall out and you're done!
Jul 18, 2010 | Cars & Trucks
How to lift blade on mikita 10 mitch saw
right side of saw is a spring loaded knob. push saw down and pull out knob - rotate knob 90 degrees.
Oct 14, 2009 | Makita 10" Compound Miter Saw LS1040
Kitchen Ranges Logo
78 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
