Question about Baby Gear
Swing electric motor
I need a electric motor for a link-a-doos magical mobile swing the part
number on it is RF 500 TB-18280 OR R904 8Y12 MADE IN CHINA it has a dead spot in it . sometimes when you turn it off it wont start up again i have taken the swing apart and verified that it is the motor that is in need of replacement . a manufacturer or supplier of this part would be apreciated
  • mikeyvon Jun 02, 2008
    We are having the same problem. Took swing apart and our motor is unable to over come the torque when the gearing to make the swing swing is applied. Ours has a second part number of RD 03 46 09
  • Anonymous Feb 02, 2009
    Same problem here. I inherited a cradle swing that has all other functions working on it, just the motor is unable to start up. I took the swing apart and got the motor and exactly the same as Krash Dummy my motor has a dead spot on it. If you give a nudge with your hand it'll start up, but then you subject the motor to a lod and it dies. Mine has the same model number of RF-500TB-18280 and a second number under it of RD 05 5Y 22. I'd replace the part myself with a new one, but do you think I can find anyone in Australia in my local area that has one......
Type the rf number into google and it will list a whole bunch of companies that sell the motor.
ecbingoman
Posted on Feb 09, 2009
Where can I get the 48v 500watt bushless motor for my e wheel E36 3 wheel electric mobility scooter
500 Watt 48 Volt Electric Scooter Motor
This link shows a 48 v. 500 watt motor, but you should contact them to make sure the motor fits your particular scooter. I hope this helps.....
May 01, 2014 | Health & Beauty
I bought a used Graco baby swing (I think from about 2001) and I can't fiure out the buttons. There are four - low-timer- high - music. It has 6 speeds, 15 songs, and time listed on the front. I don't...
YOU NEED THE MODEL NUMBER then follow link below
LOOK FOR THE MODEL NUMBER
  • BOUNCER On the back of the vibration unit, below the battery compartment door
  • OPENTOP™ SWING Inside the battery compartment behind the batteries
  • WIND-UP SWING On the underside of the top housing- the piece of plastic that runs across the top of the swing and is right above the baby's head
  • TRADITIONAL SWING Under swing tray
  • TRAVEL LITE™ SWING On the bottom of the contoured plastic seat
  • SWEETPEACE™ NEWBORN SOOTHING CENTER On the bottom of the seat
  • DUETSOOTHE™ SWING + ROCKER On the underside of the housing
  • DUETCONNECT™ SWING + BOUNCER On the underside of the housing
  • DUETCONNECT™ DLX SWING + BOUNCER On arm with motor hub
  • LITTLE LOUNGER™ Inside leg near Rock Lock
  • DUET ROCKER™ Backside of front plastic panel with Graco Logo
  • GLIDING SWINGS Under motor housing unit (electronics hub on right hand side of swing)
  • SIMPLE SWAY™ INFANT SWING On tubing on bottom of unit
  • COZY DUET™ SWING + ROCKER Under battery hub on back of swing
  • DREAMGLIDER™ GLIDING SWING + SLEEPER On side hub with electronics
Product Instructions Search Results
Jan 01, 2018 | Graco Toys
Mobile not turning
Hi, do you have the mobile function turned on? When you're looking at the controls, the mobile is controlled by the dial on the bottom right; if it is set to either mobile (the four arrows chasing each other around in a circle) or mobile and lights (the four arrows below the image of the light) then the mobile should turn on when you turn the main swing dial to either stationary (the circle with another circle inside it) or to any of the "on" settings (any of the filled-in circles after that).
If the mobile isn't turning on but everything else is working, you probably have a bad mobile motor inside the swing that will need to be replaced. Taking it to a repair shop might be expensive -- you can sometimes find used swings on eBay for cheap and harvest the parts you need from one of them.
Dec 11, 2010 | Fisher Price Ocean Wonders Cradle Swing
Hayward super pump 1.5hp motor seized due to water damage. can it be repaired?
no...write down all the numbers on the ID plateand go get a new one...the numbers will make sure you get the exact motor you need...electric motors are general, based on the numbers...
Apr 10, 2010 | Hayward 3/4hp Super Pump Inground Pool...
Stopped receiving sky on second tv - does my samsung need a reset
I install a lot of magic eyes etc.
You have checked that the magic eye lights up when it is connected directly into the sky box. So your eye is working correctly.
the next step I would take is with your sky remote in your main room. press SERVICES, 4, 0,1, SELECT go to RF settings and check the rf channel and make sure the power is on. Take a mental note of the channel number.
Now go into the room where the link is feeding. Turn on the TV and go to channel number 6 press your MENU button and then go down to setup. go across to manual install and then down to the channel number type in what you retrieved from you box ie rf channel and then type it in and STORE.
If you go into your main room and just put the normal tv guide on ie blue screen. then check that your getting the sky into the other room. IF you are then great it just needed tuning in. IF not I would remake the coax connectors. as there may be a bit of copper braid touching the centre core. once this is done your sky should be on all you need to do now is put the eye back on. Once you have done this the red light should appear on your magic eye. if not go to your main box and follow the first instructions I gave you and turn the power off on the RF and then save and then go back in and turn it back on and save.
Hope this sorts out your problem
Cheers
Little Dish Fitter
Feb 27, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Downloading Instructions
Got it!
Here is the URL:
http://www.fisher-price.com/uk/babygear/product.asp?id=32501&sku=H4791&c=bgsw_tas
Nov 16, 2008 | Baby Gear
Looking for the screws for fisher price link a doo swing
This is still a current model, so try either eBay or Google shopping. I have just run a search and I can see a few shops in the UK selling it, so I know it is still available.
Aug 30, 2008 | Baby Gear
Rf2 outlet from sky hd box
on your sky remote
services
0 1 select
make sure the rf is set to on
Remember the channel rf number,
go to your television the link is to.
go to menu then setup and then manual tune
select the channel you want to view sky on. normally channel 6 on your analogue
then go to Channel type in whatever the rf setting was on your main sky box then press save.
that is your telly sorted out. if you have a magic eye connected at the link end you should see a red led light lit up.
if not remove the magic eye and connect it straight into the back of your sky box RF2
just to make sure that the eye is not at fault.
hope this helps
ill check in a day or two to see if you need more help.
Cheers
Little Dish Fitter
Nov 14, 2007 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Baby Gear Logo
1,072 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Baby Gear Expert? Answer questions, earn points and help others
