Question about Microsoft Xbox 360 Console
Please help I am able to turn on my 360 4-5 times. Each of these times I am able to play it as much as possible. After the 4-5 good times it must sit for 5 days before it can be played again. Any help would be great, thanks.
    Sergeant:
    Champion:
  • 427 Answers
The problem is probably overheating. The soldered joints have probably gone bad and need to be replaced. The console will need to be repaired.
Posted on May 26, 2008
When play the xbox360 for a while, its stops and not able to continue playing unless i turn it off.
Yes this is the freezing problem you will need to send it back and get it fixed.
Or the other option that you have is to use a good repair guide and fix it yourself from home.
If you send it in you will be looking at about a 4 week wait and then having to pay out $150 for the repair.
If you want to fix it from home you should use a good Xbox 360 Repair guide.
I hope this helps you and if so can you please rate this so it will help others.
Feb 15, 2011 | Microsoft Xbox 360 Console
I cant play for more than five minuted without the console turning off and the rrod (two lights) showing up. What can I do? I let it sit for about 7 hours but it did not help one bit. Please help me.
try letting it sit,check the cords are in good and depending how long you've had your xbox u might have a warranty at xbox.com but if you dont go to this site to fix it http://www.wiredextreme.com/count.php?refer=2119
Jun 12, 2010 | Microsoft Xbox 360 Console
Xbox 360 possibly overheating?
You can attach an intercooler at the back of the 360 and this will help keep cool
you will also need to do something called a reflow, we us a proper infra red reflow over which in turn re-seats the solder and rectifies these sorts of problems. if you simply just put some paste on your not solving the problem.
once reflowed the machine should work tip top again
if you run a search on google you should be able to find guides on reflowing your mainboard and it is possible to use a heatgun BUT is not so reliable.
regards
FixMyConsole.
May 08, 2009 | Microsoft Xbox 360 Console
During game play,game shuts off and two red rings appear/
its very possible your xbox is having overheating problems. I had the same issue with mine, and i had to send it back to microsoft 2 different times, but after that it worked fine. I would try sending it back to microsoft, and see what happens from there.
Mar 30, 2009 | Microsoft Xbox 360 Console
360 wont turn on
Hi there, This issue may be caused by your power supply and or console not getting good enough ventilation or air vents clogged with dust causing over heating. Check power supply and keep in wide open area same with console (not sitting on carpet). If over heating is the issue you may have warped your motherboard, what happens is the Graphics processing unit (GPU) and or Central processing unit (CPU) get extremely hot causing the mobo to warp and the solder becomes loose and break. Even the fan may be the culprit, the fan uses a lot of power and produces a fair amount of heat that can cause the system to over heat. Please contact microsoft and get system repair if problem persist.
Dec 10, 2008 | Microsoft Xbox 360 Console
Xbox 360 two red lights in left quadrant
well dust can accumilates in the wierdest ways.
try blowing the air holes with a compress air cans. or take it apart and clean the inside. dust can build up with 3 months of playing depends on your area if you have pets or smokers in the area, dust comes from all sorts.
so try keeping your XBOX360 cooled as possible and keep it cleaned.
i use a air compressor when cleaning mine i try to clean it like every 3-4 months depending on how much I play it.
So keep it clean also red lights could mean no video device connected too, so check your video / audio connector.
Jun 06, 2008 | Microsoft Xbox 360 Console
My 360 wont turn on!
Let it sit for a while and try again, it may have overheated. If that doesn't work try another outlet and double check your power connections; at the back of the system and the wall outlet.
If your still having problems, I hope your a good liar. Good luck!
Jan 02, 2008 | Sony PlayStation Portable (PSP) Console
Lights Flashing On Xbox 360 Controller
So the sytem is working but the controller isn't connecting? Try fresh batteries, try removing things that might interfere with the controller (cell phones, large metal things between the controller and the xbox, portable house phones, bluetooth devices), try another controller if possible (borrow one).
Jan 01, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
23 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
