Question about Admiral Refrigerators
Motor runs all the time - Admiral Refrigerators
    Brigadier General:
  • 3,513 Answers
If the compressor motor is running all the time, then your fridge may be running out of refrigerant - and is dying slowly. However - if it turns on and off ,then it could be the sensor in the freezer needs replacing. You can buy this yourself and is just a plug-in, and a cheap fix for you.
If this doesn't solve the problem, it will be the control board is out of tolerance. You may be able to tweak it - or could be preset.
Try a new sensor first. Sometimes corrosion on the connectors is enough to cause problems. Take out and replace or swap with the refrigerator sensor. Also if the compressor motor is running all the time, it usually means something is wrong. Normally the thermostat in the refrigerator causes the motor to cycle on and off to maintain a constant temperature inside the refrigerator.
Please check the link thoroughly to have a detailed idea:-
http://monsterguide.net/how-to-repair-a-refrigerator
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Posted on Sep 30, 2010
A.c. cooling fan runs constantly on high even with ignition off and key out
A/C - Heater blower motor ! What make , model and year vehicle ? Manual or automatic climate control ? Could be a bad blower motor control module , a high blow relay contacts stuck closed .
Mar 28, 2017 | Cars & Trucks
Everything works. But the fan runs all the time on or off. 25/7
Condenser Fan Motor Operation ' FAQ ' Sub-Zero and Wolf
www.subzero-wolf.com/.../condenser-fan-motor-operation
Sub?ZeroShould the condenser fan motor on a Sub-Zero run continuously? Why does the fanmotor run all the time? ... Refrigerator or Freezer Fan Switch Information.
Refrigerator Condenser Fan Is Always Running ' Home ...
homeguides.sfgate.com > Insurance & Inspections > Insurance Basics
Refrigerator motors sometimes need troubleshooting over time. ... If the fan isn't shutting off there could be several reasons. ... reason a condenser fan is continuallyrunning within a refrigerator is the thermostat. ... All Fields are required. Name.
Oct 30, 2015 | Refrigerators
Motor does not run properly
What motor are you talking about the fuser motor, paper draw motor, the finisher motor, the transfer motor, the drum motor, the developer motor, corona wire transfer cleaning motor. I can go on.
Replacing developer and toner has nothing to do with the motor running,
Aug 06, 2014 | Sharp AR-5320 Black and White Copier
Motor runs. Warms up over 10 mins and overloads trip.
feel motor when running if real hot replace pump motor dont forget to replace seals also
Apr 05, 2014 | Pool & Spa
Blower motor runs all time
Either the blower motor relay is stuck closed and running all the time.Relay should be under the hood. Look in the owners manual for the location. Also does it shut off with key or continue to run, Most likely a stuck blower motor relay.
Jun 14, 2012 | 2005 Buick LeSabre
My wipers run slow from time to time. Other times
try to find the wiper motor when it is running.i am not sure where it is. some wiper motors are inside the cowling under the wiper arms making it hard to get to. if you see it try connecting a seperate wire,positively to the metal of the motor and a good engine ground or back to the battery.if it works fine now try to locate the original ground wire connection,it may be right next to the motor screwed into the body or the wipermotor mounting itself.
Feb 28, 2010 | 2000 Hyundai Sonata
Does the fan is on all the time?
old subzeros the CONDENSER FAN MOTOR RUNS OLD THE TIME. SAME WHIT THE EVAPORATOR FAN MOTOR. RUNS ALL THE TIME. now fos systems whit 2 compressor the condenser fan motor run for both compressor. only stop when both compressor stop......
Nov 25, 2009 | Sub-Zero 611 / O Bottom Freezer...
Modle 80 washer question?
ck motor wiring connection for burnt or dark connections also possible bad timer ..have known timer to cause motor to run both speeds at same time this causes motor to overheat and shut off
Aug 16, 2008 | Kenmore 22422 Top Load Washer
Refrigerators Logo
71 people viewed this question
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
jdthefixer
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
